Hot Rods GM small block 400 oil pressure problem
Discussion in 'The Hokey Ass Message Board' started by paleot, Jul 28, 2021.
  1. paleot
    paleot
    from louisiana
    Rebuilt small block 400 had good oil pressure, after running for break in lost oil pressure. No knocks or rattles both sets of rockers pumping oil fine. dropped pan and changed oil pump no change. things I have checked hidden oil gallery plug is there,all plugs in oil gallery behind cam gear and the back of block plenty of oil pressure at oil filter. all new cam bearings installed at good machine shop.Motor has been run for a long period with no damage, just no pressure out of oil pressure sender hole. what in the world can it be?
  2. the gauge? try a known good one
  3. Oil pump drive shaft? Distributor gear meshing with the cam? You pulled the distributor and ran the pump with a drill?
  4. iagsxr
    iagsxr
    If the rockers are oiling I'd try another gauge.
    When you say the hidden oil gallery plug you mean the one under the rear main cap?
  5. kevinrevin
    kevinrevin
    from East Texas
    ”...no pressure out of the oil pressure sender hole.."
    Have you removed the fitting for the line to the gauge? Is there something clogging up the line or below the fitting?
  6. 19Eddy30
    19Eddy30
    from VA
    Any oil leaks showing ?
    Gm block or after market?
    Is cam a small base circle?
    Diagnose problem without running the engine.
    What distributor are you using?
    Distributor also completes oil circuit.
    Oil ports on rear of block near rear cam plug & under timing cover.
    Have you try oil port up @ front of block near top of timing cover ?( I think all sb have , not @ shop to verify)
    There is also a oil port under head @ rear , top of block deck , I seen not installed some times .
    Like previous post above , take a old distributor & make a priming tool , and you have to use the housing to complete the oil circuit , use drill watch oil flow @ push rods / Rocker
    mad mikey likes this.
  7. "No pressure out of the oil pressure sender hole". Are you making that ***umption based on no pressure showing on your gauge or did you actually remove the fitting and check with either a primer or by starting the engine? A buddy used teflon tape during the install of his oil pressure gauge and then started having issues with fluctuating oil pressure. Turns out there was a flap of teflon tape blocking the hole in the fitting. Sometimes it would cover the hole, sometimes it wouldn't. Removed the flap and all was well.
    Warning ... when starting an engine with no fitting, you will get a VERY strong stream of oil if pressure is reaching that port. I forgot that fitting when my engine was on a test stand and the oil hit the ceiling of the garage :D:rolleyes:
    Deuces, SEAAIRE354 and mad mikey like this.
  8. Deuces
    Deuces
    Some folks don't know how to use Teflon tape on a pipe thread....:rolleyes:
    I use that stuff all the time.... Never a problem!....;)
    TA DAD and egads like this.
  9. paleot
    paleot
    from louisiana
    Every thing mentioned in previous posts has been checked, GM block only thing I don't know about is the small base circle cam.Oil line fitting has been pulled no restriction there. This motor is in a street stock dirt track car, the owner has ran the motor for several hours with no noticeable damage.Pan was pulled new oil pump installed no shavings in pan pulled rear main when changing pump hidden plug is there. both sets of rockers are definitely oiling .
  10. iagsxr
    iagsxr
    Circle track motor so it has the oil restricted to the top right? What's it have for restricters in it?
    You snag the o-ring on a restricter and plug the pressure port?
  11. iagsxr
    iagsxr
    That and I'd have already ran a mechanic's wire down the pressure port then started the engine with nothing screwed into it
  12. gary macdonald
    gary macdonald
    Oil pan too close to the pickup ?
  13. pprather
    pprather
    Still not sure if oil is coming out of sending unit hole near distributor. What is status?
  14. malibumonte78
    malibumonte78
    I am fighting the same issue right now. Fresh rebuilt 400 no oil pressure at hot idle after break-in. Tried going with a 15W40 oil and that didn't help. Switched gauges to a vintage Stewart Warner gauge and it was reading around 20 psi at hot idle so we thought we were ok. Bought a new gauge to match the others in the car and it read low, replaced the line in case it had a kink and it still read low. Tried two more gauges and they all read low. So I guess the old SW gauge was the one that was wrong. Pan wont drop in car so I am about to pull the motor to look at the bearings and see how they look and was thinking about trying a HV HP Oil Pump. I hope you get yours figured out so I can get mine figured out too!
    bantam likes this.
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    Have you guys tried checking the pressure at the port above the filter or the port above the timing chain ?
    egads likes this.
  16. Wrench97
    Wrench97
    That p***age is a straight shot from the oil filter.
    mad mikey and iagsxr like this.
  17. jaracer
    jaracer
    A HV HP oil pump will only mask the real problem. You need to figure out where you are losing oil pressure. I've got an old 350 daily driver with a mechanical gauge and it has about 15 psi hot idle and 45 at any speed above about 40 mph.
  18. iagsxr
    iagsxr
    I wasn't picturing the oil path correctly.
    If it has oil pressure at the port above the filter and not at the top of the block it can only be the hidden galley plug or a physical obstruction in the port.
  19. paleot
    paleot
    from louisiana
    jagsxrr first thing we did was check the plugin the hidden galley, it is there.
  20. paleot
    paleot
    from louisiana
    pprather, no oil coming out of sending unit hole! both sets of rockers oiling big time. the guy that owns the car has ran the motor for several hours against my advice. when we pulled the rear main down to check hidden gallery plug rear main is perfect no damage at all.
    pprather likes this.
  21. paleot
    paleot
    from louisiana
    born to lose we pulled sender NO OIL!
  22. gary macdonald
    gary macdonald
    Is the oil pan too close to the pickup . Did you use a pan gasket or just sealant ? Is the oil pan sump dented or bowed on the sides ? Factory oil pickup installed properly?
    Remove pan , remove plugs , put 5-6 qts in a 5 gal bucket with oil and place the oil pump pickup in the bucket of oil and crank motor . Youll see if and where its leaking , fast .
  23. 33 cdan man
    33 cdan man
    I had a rear cam bearing that wasn't positioned properly. Had pressure when cold but as the oil thinned pressure dropped off.
  24. Kevin Ardinger
    Kevin Ardinger
    Are you sure it doesn’t have standard bearings on a .010 under crank? Or .010 bearings on a.020 crank?
    Desoto291Hemi likes this.
  25. Joe H
    Joe H
    It wouldn't have oil at the rockers if it was loosing oil in the bearings, the rockers are last in line for oil, and it sure wouldn't run for a couple hours without pressure. If nothing else, screw in a mechanical gaugs in every port that has oil and see if you get any readings.
    mad mikey and Desoto291Hemi like this.
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Remove sender or oil line fitting then prime with an oil pump primer while poking hole with a wire to see what happens.
  27. hemihotrod66
    hemihotrod66
    Change the pressure relief spring in the oil pump...
    mad mikey and Elcohaulic like this.
  28. Moedog07
    Moedog07
    Was there a solution to the oil pressure issue?
    Truck64 likes this.
  29. Truck64
    Truck64
    from Ioway
  30. paleot
    paleot
    from louisiana
    none that I know of He put it aside for a future teardown
