'32 frame and a '27 RPU body......
Discussion in 'The Hokey Ass Message Board' started by CTFuzz, Aug 12, 2006.
  1. Will a '27 Roadster pick up body fit a '32 frame??.............has anyone done it?? Seems like the frame would be too wide................just thinking out loud............:eek:
  2. Splinter
    Splinter
    There's a coupla threads on this- A bodies on Deuce frames-try the search function and see whatcha get...Lotta good info here.
  3. '27 is a 'T' not an 'A'.................found nothing in a search, Thanks
  4. ol fueler
    ol fueler
    No its not , BUT a 27 T fits an A frame with no mods, so the Mods to a 32 Frame for an A should be helpful. It will have to be narrowed or at least pinched in the front.
  5. snortonnorton
    snortonnorton
    from Florida
    now i'm confused, A 27 isn't a T? or can it be both?
  6. ol fueler
    ol fueler
    That did look a bit odd after I read it again. A 27 IS a T . What I was trying to say is a 27 T is NOT an A but a 27 T WILL FIT an A frame .
  7. McFly
    McFly
    Look up some of Nimrod's posts.
  8. Here is one from my downloaded "Idea Cars" picture file.
      58.1 KB
  9. Thanks guys......................I would like to hear from someone that has actually done it. any and all pictures are welcome..................
  10. Nimrod
    Nimrod
    Mine's channeled a couple inches...so the frame had to be narrower than stock. It ended up being about 3" narrower than stock at the front spreader bar and about an inch wider that stock at the rear. Thats how the contour of the rails ended up matching the body the best.
    I've pictures of highboy T's from the '40's on stock width '32 frames...the top edge of the frame shows about the whole length of the body and looks funny. The lower edge of the '26-7 T's are narrower than a model A.
      53.6 KB
  11. Nimrod
    Nimrod
    Here are a couple more pictures.
    One of the car sitin on the rails (but narrower than stock width).
    One upside down before I started cutting the body.
    And one rightside up again channeled.
    I kinda miss my old big shop!
    -Jeff
      63.8 KB
      40.7 KB
      41 KB
  12. leon renaud
    leon renaud
    from N.E. Ct.
    I read in a Model A restorers magazine that Ford made the A frame fit the 27T body because he wasen't sure the A bodies would be ready in time, and planned to use T bodies on the A running gear if nessarry to get cars to the public if the A bodys weren't ready in time.
  13. Thanks Nimrod.............Thats what I needed to know.....your ride looks kick*** bythe way.
    CT.
  14. nailheadroadster
    nailheadroadster
    Hey CT, I went about it a bit different. Since T's don't exactly have a ****load of foot room, I figured I would widen the body to fit the frame. Mine has a 32 frame and K-member with A front and rear crossmembers. I cut the cowl down the middle and added 3 1/2". Obviously, the dash and other parts had to be done too, but the result is much more roomier than a stock T and the vast majority of people don't even realize it.
  15. Hay Nailhead..............after reading Nimrod's post, that's exactly what came to mind. How 'bout some pictures??............Thanks
    CT.
  16. Ragtop
    Ragtop
    The late Tom Senter was originally planning to use a 27 T body on deuce rails but found the T a little small for his Height and ended up doing a Deuce Hiboy, but I have a pic somewhere on his ch***is with the T body in place. The ch***is would have required a little narrowing. Still a cool pic. I'll try to find it later tonight and post. These things look great!
  17. fab32
    fab32
    Nailheadroadster, What you did was almosrt exactly what Jon Hall of Shadowrods has done with his new XL27 body. It's a '27 T roadster body sized to fit on a stock dimensioned '32 frame. It's a beautiful piece but like any quality product it''s priced accordingly.
    Frank
  18. Bruce Lancaster
    Bruce Lancaster
    There are pics of a real old timey one in a '53 or 4 R&C Bonneville issue--'27 pickup on '32 V8 frame, called a "T-V8". This thing was the tow car in a long story on a tow to Bonneville. I don't think this car was really even viewed as a rod, just as something thrown together to make a truck out of the stuff in the back yard, and was very rough and crude, but it was an appealing little car nonetheless. Mebbe someone here knows how to post pictures...
  19. nailheadroadster
    nailheadroadster
    Here are a couple of pics for you CT. Basically cut it down the middle then stood there staring at the body while my buddy said "You sure you know what yer doin?" At the wise old age of 23 I promptly replied "Nope, all I know is that it's gotta fit that frame." I had the holy grail of frames and a narrow 26 roadster body wasn't gonna stop me from using it! Basically, it turned out to be about 3 1/2" I hadta add to middle of the cowl then I just ended up pie cuttin it towards the back. The rear dimensions, past the seat back, are stock. It's probably not even close to the best fit out there, but it works for me.
  20. Thanks...............!!!
  21. Ragtop
    Ragtop
    Here's the pic I was talking about. Like I said, Tom ended up using a Deuce body so He never got around to narrowing the frame, but it sure looks good like it is. This pic is from Oct. 1977 !001 Custom and Rod ideas. Too bad this magazine isn't around now - it always had some cool stuff.
  22. Bruce Lancaster
    Bruce Lancaster
    Ragtop, have you ever looked at the masthead/list of writers in the last few "1001's" edited by Senter?? Checkitout--best thing in the magazine!
  23. Hey Nailhead, got any construction photos?
  24. Ragtop
    Ragtop
    The only books I have are pretty old - mid to late 70's but I see Magoo, Brennan. Middle linebacker?
  25. VespaJay
    VespaJay
  26. Irish Dan
    Irish Dan
    Doin' one as we speak! Oh yeah! ...and does it look low & cool!
  27. Dan........ you gotta post some pictures..!!! Don't make me beg.
    Jay.........does a rod get any better than that?
    Thanks for posting that picture and the link...............................
  28. 50Fraud
    50Fraud
    That was a neat looking little truck. Very muscular looking!
  29. Bruce Lancaster
    Bruce Lancaster
    At the end, I think Senter was more or less running it alone on a budget of 47 cents and the masthead was entirely imaginary--Names like "Hiram Squee" and "***o Garfoon", ***les like "Degaussing engineer." Somebody here must have one of the late issues...
  30. nailheadroadster
    nailheadroadster
    I do have a few that I just scanned but they're not very good pics. Lost a bunch while moving a few years ago. Sorry about the quality, I didn't have a digital camera then.
