Hot Rods HIGHBOY REAR TIRE SIZES
Discussion in 'The Hokey Ass Message Board' started by Art Center Dropout, Jul 30, 2021.
  1. I have a 32 Ford roadster that I will run as a highboy. I have 16" x 7" rear steel wheels. I plan on running a radial tire and would like it to be at least 9" wide and 30 to 31" tall. I have searched for which tires people are running but all threads are from 2017 back . Can anyone help with what they are presently using?
  2. krylon32
    krylon32
    from Nebraska
    I'm running 750-16 Excelsior radials on the rear of 2 of my highboys tall but not real wide.
  3. TomT
    TomT
    43548856-3652-47BD-9095-5179E0E98433.jpeg 681B821D-23A7-4884-89B6-10B730D5899C.jpeg My avatar runs 235/85-R16s and are just a little bit under 31.5” tall inflated won 4.5” 40 Ford rims tubeless with a 46 banjo rear. My 32 5-window rinds the same tire on 16” Int Harvester rims which I believe are 5” wide again tubeless on a Canadian Maverick 9” rear (narrower than the 8” American counterpart). Found the avatar set used at Carlisle and the 5-window set from tire rack.com a Durvais tire I think it’s spelled …..
    akoutlaw, Lil32, Packrat and 2 others like this.
  4. Fogger
    Fogger
    Traditional high boy tire sizes haven't changed for many years. For 16" wheels rear size 7:60x16 and front 5:25x16 bias Firestones. You can find radial tires, like Excelsors, in the similar sizes. My '32 Roadster runs bias ply tires in the stated sizes. LARS 2015.jpg
  5. 1-SHOT
    1-SHOT
    from Denton
    What size fronts are you running. Frank
  6. RockyMtnWay
    RockyMtnWay
    I’ve tried radials on my roadster over the past few years and only way to go.
    NJ Don, rod1, Lil32 and 4 others like this.
  7. Mr48chev
    Great examples of what looks right there.
    I have to say that the blue Cabriolet that Tom T showed in his first photo says tons though. Perfectly centered in the opening with an even gap all the way around. No matter what size tire that is an absolute if you want it to look right. Tom T blue Cab.jpeg
  8. da34guy
    da34guy
    I run 235 85 16's on all mine
    Lil32 likes this.
  9. Dino 64
    Dino 64
    from Virginia
  10. Haven't bought the tires yet. I have 40 Ford 16" rims with 6:00 X16 RO
    I have 40 Ford rims and 6:00 x 16 rollers presently, but am thinking 5:50 x 16's.
  11. This is the look I like. At the present time the rear (59 Ford with 68 3rd member) is not in, but that is next. I want to get it rolling around with the tires I will use. Got worried that some sizes are going away.
  12. RMR&C
    RMR&C
    from NW Montana
    Be aware that most if not all "big" radials from your local tire store will be LT(light truck) tires which are 10 ply. Very stiff and heavy...the 235/85 size I run on my dually.
    clem, Lil32 and sidevalve8ba like this.
  13. da34guy
    da34guy
    You are correct, but if ya only run 18/20 lbs in em they ride great.
    Lil32 likes this.
  14. cfmvw
    cfmvw
    I like the rake and proportions on that. What size are you running on the front?
  15. da34guy
    da34guy
  16. Hey @RockyMtnWay,
    Where did you buy your Diamondbacks? I'm also in Calgary and am looking for some for the Model A roadster.
  17. RockyMtnWay
    RockyMtnWay
    Direct from dbtires @ 1-888-922-1642.
    pprather and Tim like this.
  18. Almostdone
    Almostdone
    Same here.
    John
  19. B.A.KING
    B.A.KING
    Most are running 16s on rear. why? Add to rake? taller tire ? tradition? i have been told that 15s are getting hard to find.
  20. primed34
    primed34
    I had trouble finding 235/70/15s with blackwalls that weren't well over a year old. My local tire store just got me a pair made this year yesterday. My tire guy said 15s are on the way out.
  21. Thanks to everyone who responded. Very usefull.
  22. Tim
    Tim
    from KCMO
    because pre 1949 Ford wheels that 99% of us run are 16”
    X38 likes this.
  23. Rockchip
    Rockchip
    I'll check in to represent the 1% not running 16". The 8.20-15 still does it for me. Fits the natural body line of the '32 rear wheel well radius pretty close and maintains a nice sidewall to wheel diameter look.
  24. dana barlow
    dana barlow
    from Miami Fla.
    Some great looking rods posted.
    Tire size,rear match up*= Hotrod builders ,at least in the 1950s an early 60s, were not as goofed up as todays ideas, with mismatched an misread old photos of what was ,and was not !
    Hot rod builders like myself{I build rods late 50s an in too the early 60s an on.=So I know what was real,an many others,all were trying for speed* an cool looks. So lets talk speed*,big V8.
    If the rod has a flathead V8>What every one tried to do was get best bit/grip they could at the time> the tires that were around to get ,after WW2 got wider=more bit/grip for strong take off. < What that should tell you is the rear tire on your hot rod should fit/match the year your rod is styled for! If you have flathead v8 power( 1945 to about 50 style) rear tire should match that,for about the widest tire being sold at the time your rods engine n style looks like!! Flathead V8's look best with no wider then about 5 to max of 6in. tread on road. If rod style is before WW2,pre that should be around 4 in. with Flathead V8.
    Overhead V8 power,tire should be those tires that were being sold when OHV -V8 your using should kind of match ,tires became wider from 1950 up. Tread width of rear tires should match your power plant an time style.
    Nothing looks more off**,style wise, then a rod with the wrong width rear tread tires,too the power plant it has!
    Like seeing rear tires under about 5 in. wide tread with Overhead V8{ with rod built like 1950s or 60s hotrod ! an up !
    The fat treads ( width of 8in an up around 60s an on kept growing.
    Tires got wider an wider every year,that started being made were great grip,but belong on rods of those years ,style wise,not on older style builds.
    I had some on my own 28A hot rod{ Ford Thunderbird Y-block OHV V8 power},I thought were trick stuff in 1961,monster width of 6-1/2 in tread< biggest I could find at the time. By 63 ,I had some 7in. wide tread on rear.
  25. B.A.KING
    B.A.KING
    That does fit well!!!!
    dana barlow likes this.
  26. X38
    X38
    It does look good. And, you have properly mounted tail pipes.:)
  27. SEAAIRE354
    SEAAIRE354
    If you don’t mind me asking. Is the wheel well opening on a 32 the same size as a 30/31 A ? I’m going through the same thing now and really like what everyone has posted. I have also noticed that some of the suppliers of steel wheels don’t offer 16” although I haven’t done a ton of research yet.
  28. I know this picture and this post is just about 3 years old now but man does that car have "the look".
    It's cars like this that got me into traditional hot rods when I was a teenager 30 years ago.
    clem likes this.
  29. Mr48chev
    That is what the whole thread was about rear tires that fit the rear wheel opening correctly.
    That 8:20 in post 23 should be the text book fit. the gap between the tire and the lip is as close to perfect as you can get
    Speccie likes this.
  30. deucemac
    deucemac
    I am running Firestone 14x31 double diamond Coker repops on my avatar 32 roadster. Quite happy with them. Also, quite handy for keeping people from following too close through puddles! Throws up a very nice rooster tail!
