Projects 27 coupe build
Discussion in 'The Hokey Ass Message Board' started by AndersF, Oct 17, 2015.
  1. MMM1693
    MMM1693
    Working out nicely!
  2. chessterd5
    chessterd5
    from u.s.a.
    Hi Anders, looks good. I have not commented in awhile but have been watching. I like your chop top. I noticed the bullet holes. Did it try to run or was it for measuring?Lol
    If you don't mind sir, I would like to know how tall it is from the roof to the floor?
    Thanks and have a good day!
  3. gonzo
    gonzo
    Awesome progress!
  4. goldmountain
    goldmountain
    Isn't it amazing that a 5"chop on a T is a conservative chop? Also, the original header above the windshield has a slight curve at the top, like it does above the rear window. Are you going to compensate for that?
  5. AndersF
    AndersF
    No i dont going to put in a visor.
    The pices that goes over the doors stick out 1 inch in front of the front window posts.
    I keep those to give the front a bit of shape.
    Thanks
    Thanks
    The bulletholes is from when the last owner before me tryed to deliver his last load
    of moonshine he ever did. :D
    But they helped me to determine where to do the cut.
    From the sill to the plane where the roof is attached it is 39 1/4.
    My measureing stick bow a little and show a tad moore on the pic.
    Thanks
    Yes it is. On allmost any other car a 5 inch chop would be a radical chop.
    No the header will remain straight.
  6. AndersF
    AndersF
    Since it was good wheather today i rolled out the car to stand back and look at it.
    Tok some pics to compare whith those before the chop.
  7. That looks great and not over done, it has good visual balance.:cool::cool: JW
    chessterd5, AndersF and j hansen like this.
  8. AndersF
    AndersF
    Thanks. First i was a bit disapointed that i didnt could take more then 5 inch.
    But when it was done it turned out alot better then i thought it would.
    My only regret is my rear window.
    I should not messed with it. It turned out great in many ways but do look stock.
  9. goldmountain
    goldmountain
    That rear window is a pane - pun intended. I had planned on taking less out on mine too, but in the end decided that it looked better small. However; when I back up, not so much. Back up camera time.
    AHotRod and AndersF like this.
  10. Peanut 1959
    Peanut 1959
    If you want to return some height to the rear window opening, now is the time to do it! But it's looking great!
    AndersF likes this.
  11. chessterd5
    chessterd5
    from u.s.a.
    I like it!
    That Hemi is going to be stout!
    Thanks for the measurement, it helps me with mine.
    I like the rear lower suspension arms too. It is a good look. Do you have to have fenders on, or no?
    AndersF and 26 T Ford RPU like this.
  12. AndersF
    AndersF
    I problaby keep my rear window as it is. To lazy to redo.
    The lower arms are stock Land Rover trailingarms. I like the look of them to.
    Since may last year we are allowed to get them legal without fenders.
  13. MMM1693
    MMM1693
    Nice job on the chop, but it needs a visor IMO
    26 T Ford RPU and AndersF like this.
  14. I was thinking a Model A style of visor would look cool, It will need something. JW
  15. MMM1693
    MMM1693
    X2 on the A style visor
    26 T Ford RPU likes this.
  16. AndersF
    AndersF
    Sorry guys that i must disapoint you.
    And my wote gonna win.:cool:
    But i had seen it without a visor all the time in my head.
  17. MMM1693
    MMM1693
    Hey... its your head!
    Stogy, AndersF and 26 T Ford RPU like this.
  18. chessterd5
    chessterd5
    from u.s.a.
  19. Well they all work without, but i do like the ones with the slight overhang.:cool: JW
    Stogy, chessterd5 and AndersF like this.
  20. AndersF
    AndersF
    As usual this time at year the progress is slow.
    I have done some jobs on my coupe but the progress have ben really slow.
    And the job that i completed i didnt take a photo of when it was done.
    But i have mounted the taillights.
    Its a Chevy 58 lower series ones and one of the best looking taillights of the 50:s.
    But on a small hotrod they tend to stick out a bit to much in my opinion.
    They allso need a flat surface to mount to.
    So i made some pots to sink them in a bit in the tailpanel.
    After the last pic i cut of the edges that stick out and welded them in.
    I allso replaced the white lenses with red ones.
  21. Nice job on those and i agree that they are good looking taillights. Too many belly ****on 50 Pontiac or 38-9 tear drops. JW
    OFT, Stogy and AndersF like this.
  22. I first saw them used on a friends Dodge Bucket, Cool. JW
    AHotRod, brEad, Stogy and 1 other person like this.
  23. goldmountain
    goldmountain
    It looks good with those tailights sunken in but I think retaining the backup lights would be better. I hate it when people behind me don't know that I'm backing up.
  24. AndersF
    AndersF
    I have a plan for that.
    Stogy, AHotRod, OFT and 1 other person like this.
  25. AndersF
    AndersF
    Here is the picture i forgot to take on my last update.
    When i was at the tech inspection 2 years ago he didnt like that my firewall flexed when he pushed the brake.
    Problaby not a problem anymore since i made the transmission tunnel since then.
    But better safe than sorry so i reinforced the firewall.
    To p*** the inspection i need a defroster for the windshield.
    I found a neat little unit for racingapplication i could use.
    First i started to measureing where to get the hot water through the firewall.
    I found a good spot where it works on the inside and i could route the heatlines relative discret over the engine.
    Then i needed to mount the heater and direct the heat to the windshield.
    I tested with some cardboard if i could use the space behind the dash.
    It seemed to work so i started to fabricate a bracket for the heater.
    I allso made a pipe facing down if i ever need some heat to the floor.
    Then i made the channel to direct the heat behind the dash.
    Did not do the openings yet becouse i want the windshieldframe in place first.
    The dash still fit so i guess it is a success.
  26. MMM1693
    MMM1693
    You come up with some neat stuff
    Stogy, fiftyv8 and AndersF like this.
  27. AndersF
    AndersF
    Its a long time since the last update on my build.
    The sad truth is that i have done allmost nothing since then.
    But sometimes things dont go as planned but this is not the right forum for that.
    Where i left the build it was time to start modify the windshield frame to make it fit.
    So i chopped the windshield frame and straighten the hinge and mounted it.
    It all seemed to work well but something looked odd with the hinge against the header.
    When i take a closer look on the stock header i see it have a groove the hinge fit in.
    Thats offcourse is missing on my homemade one.
    The stock one is to rusty and bent to cut out and use.
    I think i know how to solve it but i will think it over a bit more before i do anything.
    The 1927 factory ac still works like a champ.
  28. goldmountain
    goldmountain
    It is always good to see other solutions to similar problem areas. Keep plugging away at it.
    AndersF, loudbang, OFT and 1 other person like this.
  29. Good to see you moving forward on your build, you will get it sorted and Happy New Year. JW
    AndersF, loudbang and Stogy like this.
  30. Max Gearhead
    Max Gearhead
    from Wisconsin
