Projects 34 3W my way
Discussion in 'The Hokey Ass Message Board' started by Xman, Sep 24, 2013.
  1. Xman
    Xman
    I know where your coming from. I didn't post very many of my build pictures because I didn't think they were interesting to anyone but me. Thing is, I love looking at what everyone else is doing.
  2. hotrodderhaag
    hotrodderhaag
    man that thing looks killer! glad to see it 1 color. The stance is perfect... now pile on the miles!
  3. LongT
    LongT
    Good at***ude for anytime you seem overwhelmed too. Just do something!!
    Car looks great!!
    Bill
  4. PKap
    PKap
    from Alberta
    Too bad about the bearing, but you've got to be stoked about the profile
  5. bonesy
    bonesy
  6. flatnasty
    flatnasty
    from Vancouver
    Dan that coupe of yours is looking Outstanding man! You are out of control. Keep up the good work.
    Brad
  7. rod1
    rod1
    How's that beauty doing?
  8. Xman
    Xman
    The engine never ran as good as I thought it should. I suspected the carbs (I rebuilt them)and planned to send them out to an expert. One day while cruising around locally, the engine backfired and quite. Had to tow it back home. Come to find out the Mag took a ****. I sent it to Joe Hunt and they put a coil in it and now the engine runs great.
    I have a couple hundred miles on it now and lovin it. Looking forward to making rod runs this year.
    First chance I get I'm going to shoot a video and post it here. I always like it when others do that.
    Dan
  9. mercmaniac
    mercmaniac
    Love your 3w. Here’s some photos of my recent build. Looks like I’m in good company! I build about two cars a year , and this one went to OK. about a year ago.
  10. Xman
    Xman
    My car bad 34.jpg as it is today. Yours is incredible!
  11. Xman
    Xman
    OK so I screwed up and sold both of my 3W coupes. To rectify the situation I started another 34.I swear I'm keeping this one
    I have the ch***is started and will post pics soon. No body yet but looking. It will follow as closely as I can with the car pictured above, so stay toned.
  12. rod1
    rod1
    Cool.Can't wait to follow along again.Love your stuff Xman.
    jammer likes this.
  13. rod1
    rod1
  14. Xman
    Xman
    I have the new frame put together and a quickchange mounted. The front will be a spring behind with a V8 60 axle. I cut the center out of an aftermarket crossmember and used it to make a flat one that is mounted at the top of the frame rails. This is very close to what I have done in the past.
    I am also finishing up on the build of a Mustang Bullitt so the 34 project has to share my tome. 100_1295.JPG 100_1300.JPG 100_1307.JPG
  15. Xman
    Xman
    Picked this up 100_1320.JPG today along with a pile of parts including the most perfect frame I've seen. To bad I don't need it now.
  16. Tim
    Tim
    from KCMO
  17. rod1
    rod1
    Wow .Couldn't happened to a nicer guy. Sweet!
  18. 2deuces64
    2deuces64
    Excellent!!!!!!!!!!!!!
  19. JimSibley
    JimSibley
    Man, i love this car. This thing is as bad*** as they get!
  20. Xman
    Xman
    Thanks for the encouragement guys, it helps a lot when your working by yourself.
    I removed all the wood from the body and will be taking it to the strippers to totally clean all paint and rust out. I'll have nice fresh metal to work with.
    Will be chopping it 6 inches.
    Tim, XXL__, 2deuces64 and 2 others like this.
  21. 51box
    51box
    from MA
    @Xman Your old 3W was a great looking car. Look forward to this new build, keep the pics and details coming!
  22. Xman
    Xman
    100_1344.JPG 100_1345.JPG 100_1347.JPG So, I loaded the body and small parts up and drove down to Portland Oregon to get it dipped. Had a quote before I left and thought it was high but probably worth it. After unloading at the stripper, the price more than doubled. Said FU and brought the car back home. Having it blasted locally.
    I have the new floor mostly done. Used Tom Bays subrails and sheet metal from a local supplier. Since I will be chopping it I decided to go ahead and cut the cowl section off and get it mounted to the new floor. It will be easier to work on it while its on the frame rack as well.
  23. Xman
    Xman
    I decided to go ahead and replace the rt side quarter panel and panel below the trunk lid. Still splitting my time between the 34 and my 68 Mustang FB so things go slow on both cars.
    Getting ready to channel the body 2 inches. Never done this before so I'll be going slow and take my time. My other chopped 34 was channeled 2 inches but that had a Don Smart full floor. I'm no Don Smart but I'm going to give it a try. IMG_0770.jpg IMG_0771.jpg IMG_0291.JPG
  24. Xman
    Xman
    Almost done with the 2" channel. I started by modifying the feet of the cowl. Then cut and tack weld in the 2" strips in the sub rails. Then bolt the cowl back on the floor that is solidly bolted down on the frame. I could then put the rear body in place and start tacking everything in so nothing would shift. I'm currently working on the rear floor area so it will flow together and not look cobbled together. I'm very happy with the progress so far. By the way, I did put both doors in place with gaps set dead nuts before tacking the cowl and body section in place,(very important step).
  25. The37Kid
    The37Kid
    Looks nice, just scrolled up to see the old coupe, will the rear tires fit the wheel wells the same?
    Bob
  26. Xman
    Xman
    Yes , the tires will fit the same and the profile of the car will be exactly the same.
    Next projects are steel B pillars and then chop the top. That's when it starts looking like my other 34.
    The new magneto came back from Joe Hunt for the flathead and I ordered the Schroeder steering box.
    Tman, 3blapcam, Jim Bouchard and 4 others like this.
  27. panhead_pete
    panhead_pete
    Oh man I love this thread!
    Jim Bouchard likes this.
  28. Xman
    Xman
    I decided to ***emble the car as a roller so I could see how the stance was going to look. I think it's going to be just right after the engine, trans and other weighty stuff is installed, so I; ok with it at this point. Checked my windshield frame and it is too nasty to use so I'm 100_1362.JPG 100_1360.JPG on the hunt for a good one! Anyone have a good one?
    Not sure about the wide 5's look but I'll use them to roll the car around in the shop.
  29. Xman
    Xman
    After I posted the pictures, I see I forgot to point out that all 4 tires are 600X16s. The stanse will be very different with 550X16 front and 750X16 rear.
  30. Squablow
    Squablow
    Do you still have the old panel from below the trunklid, and would you sell it? Because I'd buy it, even if it's ****ed up. I'm trying to piece together a roadster out of original steel and I have nothing for below the trunklid, I'd be thrilled with even a ****ty one. Same with the RH quarter, even if that had to get cut into chunks to ship it easily. I've got some quarter panel sheetmetal but any extra bits would help.
    Coupe looks good though, loving the build.
    yard man and loudbang like this.
