Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Lil32
    Lil32
    very simple
    had a new seal put in my speedo cable to gearbox
    Big mike 1968 and TA DAD like this.
  2. LAROKE
    LAROKE
    From the BillyBob Shop log.
    August 2nd 2021 Took longer than I thought it would to clean the eight nailhead piston ***emblies but I've always been over optimistic regarding deadlines. The piston ***emblies are now clean and will be set aside. Updated the procedure for the nailhead piston ***embly cleanup along the way for future reference.
    1) Remove the rings; 2) Dis***emble piston ***embly; 3) Submerge all parts in Oileater parts washer for an hour; 4) Submerge piston in Chem-Dip for thirty minutes; 5) Remove remaining carbon on piston top with br*** wire wheel in electric die grinder; 6) Go over rest of piston with the Scotchbrite buffs in the Dremel tool; 7) Clean ring grooves; 8 ) Submerge all parts in an ultrasonic cleaner session, 99 minutes 80 degrees C; 9) Submerge rod, cap, wrist pin and bolts in Evapo-Rust for up to twenty-four hours; 10) Shine up the piston again with another, shorter, wire wheel and Scotchbrite buff session; 11) Give all parts a light coating of Marvel Mystery Oil and re***emble loosely.
    Beer of the day was Madtree Brewing Company's Happy Amber amber ale. Background music was Kenny Wayne Shepherd Band's Live on.
  3. hammer-time
    hammer-time
    Where did you pick this up? Looks really nice. Would like to see it installed.
    Big mike 1968 and Lil32 like this.
  4. Jkmar73
    Jkmar73
    from Tulare, CA
    Thanks, I found it at Affordablestreetrods.com
    I wanted something nice to mount the tach to the column, rather than the normal hose clamp setup. I saw one at the last socal open house and had been looking for one when I found them at affordable street rods. It’s going to be a while before it’s mounted, so I attached the photo of the car that i got the idea from.
  5. UNCLECHET
    UNCLECHET
  6. LAROKE
    LAROKE
    August 3rd 2021 Crankshaft, main bearings and caps are next on the to-do list. Cleaning is first, then measuring what we have. I'm in deep ponder mode and taking some YouTube continuing education courses. Beer of the day is Nebraska Brewing Company's Nebraska PILS Pilsner Lager and background music was Cream of Clapton.
  7. High test 63
    High test 63
    IMG_20210803_104602416.jpg IMG_20210803_110246193.jpg Took the roadster out for a ride last evening. While giving it a flogging, it started to backfire at high rev. Was ticking on the ride back. Pulled the cover this am. Another bent pushrod.
    Poor ol engine seen duty in a 54 chevy, 66 impala, 4x4 mud truck, and now the roadster. Screwed it together about 30 years ago. Oh well. Gonna patch it back up and hopefully get the new motor together before too long.
  8. Big mike 1968
    Big mike 1968
    I cut my 47 running boards to fit my 48 fenders and re welded the flanges. I think they look nice. I'm just making everything fit so I can break it down to prime. 20210803_163920.jpg 20210803_163904.jpg 20210803_145829_(1).jpg
    Elcohaulic, HotRod33, blowby and 5 others like this.
  9. LAROKE
    LAROKE
    August 4th 2021 Started with the main bearing caps, using an abbreviated procedure that I used to clean the rods. All these caps are stamped with a number and arrow so I can batch clean them without worrying about mixing them up. Segments of the rear seal were still in the sides of the rear main cap so, I have to dig that out first.
    My friend, David Kerry, a professional performance engine builder and fabricator, had several concerns after viewing the pic of the crank and mains.
    "That crank needs micro polishing, the oil holes need chamfering please tell me you are not using those old bearings ? The wear pattern indicates the block needs line honing."
    I'm gonna try to address those concerns but probably not to everybody's satisfaction, 'cept mine. Easiest first. When I got back to the shop, I located and blew the dust off my Starrett straightedge along with my thinnest feeler gauge (0.0015"). Tried to slip the feeler gauge under the straightedge in four places (both sides, front and back) of each main bearing journal, It didn't go under anywhere. I'm happy with that result.
    Chamfering the oil holes was under my radar. I hadn't thought about chamfering the oil holes so, I'm researching that now but polishing my crank was always part to the program. The jury's still out on the bearings, both mains and rods.
    Beer of the day was Madtree Brewing Company's Lift Crisp Golden Ale. Background music was Duane Allman An Anthology.
    Elcohaulic, blowby, Lil32 and 8 others like this.
  10. tommyd
    tommyd
    from South Indy
    I gave it away. I lost interest in it a couple of years ago and it was just sitting and collecting dust. My son and I had a lot of fun racing it into the the 1990's. I then put it back on the street and raced it occasionally. He and his wife went on their first date and traveled around the midwest racing it as well. The car means a lot to them so it thats where it belongs.
    bchctybob, Elcohaulic, 49Olds and 8 others like this.
  11. LOU WELLS
    LOU WELLS
    from IDAHO
  12. HotRod33
    HotRod33
    Mounted the doors today
  13. chris bozic
    chris bozic
    from Pittsburgh
  14. 327Eric
    327Eric
  15. Tim
    Tim
    from KCMO
    Watched my 6’6” buddy stick weld on the 46’ getting ready to replace the upper shock mounts with taller ones. After years of the spring settling the shocks were bottoming out after about an inch and I managed to rip both of them off the frame the last few years flying fast and low on pot holed city streets 77A81EC1-5CD6-4C9B-9B21-201C03987242.jpeg
  16. Splitbudaba
    Splitbudaba
    A9E31A44-9E43-4C8D-BA53-2E7A7D8B2ADF.jpeg DFF06F15-5E7B-461A-835E-2B3AE7423934.jpeg ***embled the engine, clutch, bell housing, and trans. Slid it in place ! Great day!!
    bchctybob, Hamtown Al, rod1 and 11 others like this.
  17. nobby
    nobby
  18. HotRod33
    HotRod33
    IMG_20210806_122836749_HDR.jpg drove it for the first time... Put 5 miles on it... Everything checked out okay
  19. Lil32
    Lil32
    hope he had jack stands under car or whoops there goes ya legs
    recently we had over here someone at 2.30 am get a flat in a Merc SUV
    pulled into car park to fix,next morning they found the front wheel off
    and him laying under car squashed/dead
  20. Tim
    Tim
    from KCMO
    Jack, stands, more stands, tires and wheels under the car. Shook the **** out of it and waited another hour before any one got near it. I don’t even like being under a car on stands
  21. High test 63
    High test 63
    That little truck looks great!
    I love the swoop st the bottom of the cab.
    Very cool!
  22. Tim
    Tim
    from KCMO
    Congrats!
  23. lake_harley
    lake_harley
    I had a Oly beer tapper handle on my T Roadster for a shifter handle/knob, but it was too tall and the corner of it poked me in the thigh. Being a chronic tightwad I couldn't imagine just "buying" one, oh, no. Looked around the shop for anything that might be interesting or work. After about 2 or 3 hours of fiddling around I ended up with the "knob" pictured below. My guess is you'll maybe need to be 55+ years old to know what it was for, or to have ever used some of them.
    Lynn
  24. lonejacklarry
    lonejacklarry
    Yep, I have 3 or 4 in the bottom drawer of my tool box. I know I'll never use them but I can't seem to get rid of them.
  25. buschandbusch
    buschandbusch
    from Reno, NV
    I got Lance to help me put in motor and trans mounts. I tried doing it all myself out in the backyard on dirt last summer, with the cab on, but ended up getting them ****eyed by about an inch. So I pulled the cab off, swallowed my pride and asked for ***istance. That's why we're Busch AND Busch, lol. Lance got them stuck on quickfast and now things are straight and tight :) Tomorrow I'll clean off the slag and throw on some primer. Stoked to get a major step done!
    LAROKE, Tim, j hansen and 1 other person like this.
  26. blowby
    blowby
    from Nicasio Ca
    I know I know!
    Hint 1/2" square drive
    Looks good!
    lake_harley and firstinsteele like this.
  27. lake_harley
    lake_harley
    Yup. I was able to get the 1/2" square flats kinda threaded to 5/8"-11 and JB Welded in a short piece of 5/8" all-thread that was drilled and tapped to 3/8"-16 to screw onto the shift lever. Lots of messing around to keep from buying a $8 shift knob. :eek::D
    I'm thinking it's just as one-off as some of the custom, carved shift knobs though.
    Lynn
    bchctybob likes this.
  28. Rand Man
    Rand Man
    I donated one to hopefully a good home.
    rod1 and Tim like this.
  29. Tim
    Tim
    from KCMO
    Cleaned up the shop and cut down this used up cutting Matte for a new work bench cover E9666685-DA4A-4751-922E-F5A2129CB14D.jpeg buddy brought by some gas caps for me to try out on the model A project. Not sure what they are. The center cap shown is stock model A 1AE1E834-E79E-410B-9EFF-FA8AD08FCF50.jpeg used the new cutting matte to find they are roughly 3.25 inches across from the tips of the bumps 1EE03B4E-FE7A-4CD8-AEFE-2F02842EFE45.jpeg no idea what they are I’m thinking 1920’s and not Ford? Don’t seem to be vented and I think they are standard pipe thread
    LAROKE, j hansen and Lil32 like this.
  30. blowby
    blowby
    from Nicasio Ca
    To be truly representative it should probably have some blood on it. Winding those things in was always a knuckle buster.
    bchctybob and lake_harley like this.
