Projects '33 5w Build Thread
Discussion in 'The Hokey Ass Message Board' started by CTaulbert, Oct 27, 2018.
  1. flamedabone
    flamedabone
    That color changes ALOT.
    Love it, -Abone.
  2. CTaulbert
    CTaulbert
    from Detroit
    It does! For being a solid color, you’d never expect this much change with the lighting conditions. I’m looking forward to seeing the fenders along side the body.
    Stogy, Peanut 1959, Tim and 2 others like this.
  3. Fogger
    Fogger
    Absolutely beautiful!!! The attention to detail is evident from the photos, great prep on the body and the color enhances the body lines. You have another winner in the works. Looking forward to your completion.
    Stogy, CTaulbert and loudbang like this.
  4. CTaulbert
    CTaulbert
    from Detroit
    I've been chipping away at some small projects on the '33. With the top insert panel wrapped, I got the tack strip moldings installed, and ****oned up with the nice rubber filler strip.
    Then I moved on to reinstalling all of the body wood that I had previously painted black. Next, the cleaned and regreased window regulators went in after some new gl*** I had cut for the car. After working on a project last year that had Solex gl***, I grew to really like it....so that's what I had cut for this car. I think it complements the body color well too?
    Stogy, brEad, cactus1 and 14 others like this.
  5. CTaulbert
    CTaulbert
    from Detroit
    I got a last batch of powder coating back recently too, which included the rear spreader bar. I chose to mount the fuel filter/regulator for the OT EFI on it, which turned out to keep it easily serviceable while maintaining it out of sight behind the gas tank cover. With that the last couple hoses made up, I could finally call the fuel system done.
    Stogy, brEad, kidcampbell71 and 8 others like this.
  6. CTaulbert
    CTaulbert
    from Detroit
    My rear end came back from Hot Rod Works the other day too. I sent the parts out earlier for HRW to do their final machine work and ***embly. As always, it came back looking great, and I know the work inside is even better.
    I mounted it on a couple engine stands, and got it painted this weekend too. The slide-in axles will arrive this week, so the ch***is is going to officially become a roller real fast!
    Stogy, brEad, kidcampbell71 and 13 others like this.
  7. Fogger
    Fogger
    Can't say anything but WOW what a beautiful build.
    kidcampbell71, CTaulbert and loudbang like this.
  8. loudbang
    Outstanding as usual. :)
  9. Turns
    Turns
    What an awesome build with tremendous build quality - like wow :cool:
    Cheers Turns
  10. Peanut 1959
    Peanut 1959
    Awesome paint color choice!
    Stogy, loudbang and CTaulbert like this.
  11. Rand Man
    Rand Man
    Lots to like on this one. Well done.
  12. CTaulbert
    CTaulbert
    from Detroit
    Thanks guys!
    Stogy, loudbang and Just Gary like this.
  13. Woogeroo
    Woogeroo
    from USA
    That looks so ***y. I'm in love.
  14. teach'm
    teach'm
    from Tucson, AZ
    Great idea to use engine stands to paint the rear end @CTaulbert. See you and Ash in Oklahoma soon!!
  15. CTaulbert
    CTaulbert
    from Detroit
    Also good to have friends with extra engine stands!
    63 days…..
    Stogy, brady1929, loudbang and 2 others like this.
  16. CTaulbert
    CTaulbert
    from Detroit
    Knocked out a bunch of small projects on the frame this week. I got the freshly painted rear end in the car, and the rear suspension ***embled. With the rear end in place, I could measure for a driveshaft, and I promptly got one on order.
    I wanted to keep the look of the original Ford rear hubs, so I took a pair of rear hubs and machined the snouts off. I found a socket nut in the McMaster catalog, along with some stainless all thread and castle nuts, and came up with a plan to make the rear end appear to still have stock axles.
    I chucked the new slide-in axles in my lathe, and used a live center to locate the socket nut on the face. I then rotated everything by hand as I welded on the socket nut. The stainless all thread got shortened to fit, then drilled for a cotter pin. Looks stock on the outside, and easy to remove and reinstall as needed!
  17. CTaulbert
    CTaulbert
    from Detroit
    Another small project was doing some light turning on the MT brake drums to fit the original Lincoln backing plate slash shields. It didn't take much, but it was necessary to get enough clearance. With that done, I painted the rear drums and once dry, got them installed.
    I moved onto bleeding the brakes, using a Motive power bleeder. When I built the plumbing last year, I stepped up and bought a nice turret style flare tool. I can say that it was worth the money, as I didn't have one leak! Once everything was bled, I adjusted each corner, and the resulting pedal felt great.
    About that time, the driveshaft hit the door, so I got it installed along with the rear wheels, and rolled it outside!
  18. CTaulbert
    CTaulbert
    from Detroit
    A few more shots before I rolled everything back inside......
    Jet96, bymanr, Shadow Creek and 18 others like this.
  19. RatPwrd
    RatPwrd
    LOVE LOVE LOVE the details and quality of your workmanship!!!
    Woogeroo, CTaulbert and loudbang like this.
  20. hotrod1948
    hotrod1948
    from Milton, WI
    WOW! This is just amazing.
  21. Tim
    Tim
    from KCMO
    Fantastic
  22. Stogy
    Stogy
    Jawdropping is all I can say...we are blessed to be witness to this...Hambtastic...
  23. loudbang
    Perfect blend of new and old technology and keeping the new stuff under wraps. :)
  24. rod1
    rod1
    Thanks for the updates. Truly amazing.
  25. Marty Strode
    Marty Strode
    Cory, great tutorial on how to build and thoroughly finish a traditional Hot Rod. What did you use for brake line material, and would you post a picture of the flare tool you used ? Thanks !
  26. CTaulbert
    CTaulbert
    from Detroit
    Thanks Marty!
    I used 3/16" stainless, with 37deg single flares and AN tube nuts/sleeves. I bought the turret style tool, that's sold under Eastwood and Summit (just different stickers):
    https://www.summitracing.com/parts/sum-900319
    loudbang and Stogy like this.
  27. CTaulbert
    CTaulbert
    from Detroit
    It was only a matter of time, but I rounded up some friends this morning and we sat the body down onto the frame. It went on easy, and we hit the holes spot on without even trying!
    Next up is a bit of dynaliner/dynamat, followed by a lot of wiring.
    Just Gary, wheeldog57, brEad and 12 others like this.
  28. CTaulbert
    CTaulbert
    from Detroit
  29. flamedabone
    flamedabone
    I still can't get over how cool that color is. Nice rear axle trick too.
    -Abone.
    Tman, CTaulbert, loudbang and 2 others like this.
  30. Northerner
    Northerner
    Got to be one of the best engineered traditional builds ever. I am truly amazed. Thanks for the posts.
    CTaulbert, loudbang and Stogy like this.
