Technical battery in trunk..
Discussion in 'The Hokey Ass Message Board' started by banditomerc, Aug 5, 2021.
  1. banditomerc
    banditomerc
    What gauge cable do I need from trunk mounted battery up to the starter?..1 gauge?
    Elcohaulic likes this.
  2. 51 mercules
    51 mercules
    If I remember right! In my merc I used 2 gauge. No problems.
  3. I use #1 for a run from the trunk to the solenoid on my cars. Little extra cost = little voltage drop = never a worry.
  4. squirrel
    might depend on few variables, like what engine it is, 6v or 12v, how long the run is, etc.
    4 gauge might work on a short run with a small engine, 00 might be needed for a wild high compression big block with a long run.
  5. Jokester
    Jokester
    I use 2 gauge, but my battery is only 5 feet from the starter. You didn't say what kind of car. The longer the cable the bigger gauge required.
    .bjb
  6. banditomerc
    banditomerc
    It's a 1940 merc..small block ,12 volt. Guessing a 12 ft distance from trunk location to starter terminal.
    Rusty Knutts and 41 GMC K-18 like this.
  7. olscrounger
    olscrounger
    I use 1/0 for all battery cables--overkill maybe but no issues
  8. At least 1/0, 2/0 would be better. Bigger yet if it's a hard-to-start application like a big high-compression or blower motor.
  9. hepme
    hepme
    welding cable, stranded. Like C.I., bigger is better.
  10. Tickety Boo
    Tickety Boo
    from Wisconsin
    What side is best when putting a battery in the trunk?
    Most of that I see are mounted on the p***enger side and did this to my last car , but these pictures makes me re-think doing that on the next build.
    It won't be an x frame but that p***enger side slick looks planted pretty good. ;)
  11. I used double ought on my last setup. 12V and right behind the cab of a C10. May have been overkill. LOL
    olscrounger likes this.
  12. Almostdone
    Almostdone
    Model A.
    I don’t think the Impala’s problem was the battery location.
    John
    lothiandon1940 likes this.
  13. mgtstumpy
    mgtstumpy
    I recently upgraded my battery cable from trunk to solenoid due to voltage drop. It starts each and every time now when hot.
    VANDENPLAS and lothiandon1940 like this.
  14. evintho
    evintho
    I ran 1/0 batt cable from my trunk to the side of firewall (20') on my '54 Ford. Ran the positive cable below the decklid, over the wheelhouse and through the rocker panel to a power post.
    Check these guys out. batterycablesusa.com Great prices, quality products and a $4 flat rate shipping charge!
  15. loudbang
    It was done on the p***enger side in the "Hot" factory cars back in the day for traction purposes. And I did the same because the starter is on that side using welding cable because it was very flexible and easier to run along the frame. But with todays tires and track prep it doesn't much matter anymore. :)
  16. chevyfordman
    chevyfordman
    My 40 Ford sedan had a plate above the rear axle on the p***. side; I removed it and it was a good hole to run the OO cables through to the battery.
  17. 1971BB427
    1971BB427
    from Oregon
    I always use at least 1/0 and often 2/0. But you need to be sure you're also using the extremely fine strand battery cable, and not the co**** strand wire. The co**** strand wire does not have the same high ampacity of the very fine strand wire, so wont have the same high current rating.
    loudbang and olscrounger like this.
  18. Good advice. This is why I like welding lead.
    One thing that is going to piss the uneducated off but I am going to throw it out there anyway. The current does not run though the wire it runs along the surface of the wire. The more stands you got the more surface area you got.
    Now take that or leave it it is free information.
  19. gimpyshotrods
    gimpyshotrods
    I can fix that.
  20. Richard L
    Richard L
    from Quincy, IL
    Don't forget to vent the battery to atmosphere
    loudbang and 51 mercules like this.
  21. willys36
    willys36
    My battery is in the 'trunk' of my '36 Willys, right in front of the spare tire bump. I run 2/0 welding cables, one positive to the starter, and one negative that bolts to the starter mount. I run the negative cable 'cause 99.99999% of car electrical problems are ground problems.
    loudbang and TagMan like this.
