Technical Need help identifying Ford brake calipers
Discussion in 'The Hokey Ass Message Board' started by McTavish77, Aug 7, 2021.
  1. McTavish77
    McTavish77
    Hey Hamb’ers…I picked up a ‘50 Ford Shoebox a while back and I’m going through the brake system and need to replace/rebuild the front disc calipers. Problem is, I have no idea what they’re off of. If anyone can help identifying based off of the pics I’d greatly appreciate it. Let m know if there are any other pics that you may need to help or further info!! Thanks everyone!
    -Andy
  2. Hitchhiker
    Hitchhiker
    I'm probably completely wrong...but the calipers look GM to me.
  3. Mid-70s-up Ford Sliding calipers. If you have 10 or 11" rotors, probably Granada/Maverick. Bigger rotors, full-size Ford or Torino. You can also check caliper piston size to nail it down further. I suspect the latter, as while it's been a while, IIRC only the bigger cars used a separate, bolt-on caliper bracket. On most of the smaller cars the bracket was integral with the spindle.
    deathrowdave and gimpyshotrods like this.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
  5. McTavish77
    McTavish77
    thanks for the info Steve! I measured the OD on the piston it’s approximately 2.70”. Does that help in any way?
    This car is kind of a Frankenstein (9” rear out of a Bronco, column out of a LTD, console from an Olds, etc…) and I have paperwork on everything done to the car but no info on the front end!!!
  6. According to what I can find most used a 2.6" diameter piston. Are you sure yours is bigger? If 2.6" is the size, that caliper was used on just about everything in '77; Granada, LTD, T-Bird, Torino.
  7. McTavish77
    McTavish77
    Thanks Steve…I finally had some time to get the caliper out to get a better measurement on the piston and the OD is 2 5/16” so 2.3 and some change. Wondering if it belongs to a Mustang II is something similar.
  8. Where the boot goes can be smaller, the piston needs to be out of the bore for an accurate measurement. The M2 uses the same 2.6" piston.
  9. McTavish77
    McTavish77
    Thanks for all the info Steve; very much appreciated! You got me on the right track in what I need to hunt for!
  10. FritzJr
    FritzJr
    AMC also used those calipers in the '70's. They could be out of an AMC Concorde or Spirit.
  11. gary macdonald
    gary macdonald
    Looks like the Granada
  12. bobss396
    bobss396
    Agree, mid 1970 Ford, likely a Torino or LTD, definitely mid-size. These were some of the better calipers Ford used in the era.
