Technical 39 coupe with tudor doors
Discussion in 'Traditional Hot Rods' started by ricky111, Aug 11, 2021.
  1. ricky111
    ricky111
    Hi I have seen 40 coupe with roof chop and Tudor doors on it online I live in New Zealand and would like like to do this with a full rebuild on my 39 coupe I have a set of 39 tudor doors
    Looking for any advise please
    Any and all help appreciated
    Cheers from Nz Ricky morris
  2. Dak Rat
    Dak Rat
    from NoDak
    Can't help much with the process, but I saw a '39 coupe done that way at the "back to the 50's" in St. Paul. It looked terrific and was very nicely done. The top resembled the '39-'40 Merc with no quarter window.
  3. sloppy jalopies
    sloppy jalopies
    tudor doors are about 6" longer ?
  4. ricky111
    ricky111
    The coolest look I’ve seen I love it cheers
  5. flatford39
    flatford39
    You need fordor doors and trim the tops a little so you are not messing with the b pillar.
  6. ricky111
    ricky111
    Are the four door doors longer than the coupe
  7. Papas32
    Papas32
    from No.Ia.
    No, same size except the top corner as flatford39 said
  8. flatford39
    flatford39
    What papas32 said is correct.
  9. alchemy
    alchemy
    Only ones I've seen are the 3-window style coupe mentioned as seen at Back to the Fifties, and a local coupe with a chopped top and slanted B pillars. I know the builders of each car, and they both involved MUCH slicing and dicing. I think the slanted coupe actually used doors about halfway between coupe and tudor length.
    I feel if you use longer doors but don't slant the pillars, the shortened quarter windows will look goofy. Might need to move the back half of the roof backwards to accommodate.
    X38 likes this.
  10. clem
    clem
    what did he say ?
    maybe some pictures of cars done that way would help the OP……
  11. ricky111
    ricky111
    Yes that’s the car I don’t know if it’s appropriate to mention Gary’s car on here but his car is unbelievable and I just saw pictures of his car and after looking at thousands online knew that’s what I want to build so have got pictures big job so worth it tho
  12. 19Fordy
    19Fordy
    The doors on this 40 coupe are from a 1940 Fordor. You have to trim the top of the doors..
    I would think 39 Fordor doors would also work, if trimmed.
  13. flatford39
    flatford39
    Try reading the thread.
  14. geoford41
    geoford41
    from Delaware
    I have 1939 Fordor front doors on my 1940 deluxe coupe I like the 1 piece gl*** (smokers window) I don't smoke but I think it looks better and no noise from the vent windows and less possible leaks I am uploading some photos
  15. geoford41
    geoford41
    from Delaware
    ok finally found the 2 reworked doors trimmed to fit and reweld seem
    I choose to cut down the original folded sheet metal over (about 1/2" ) and cut out section to make the removed section fit as stock coupe top.
    I have trouble,uploading the word doc I will try another post
  16. Squablow
    Squablow
    I don't think the OP is looking for replacement doors, I think he wants longer doors with either slanted B pillars or a 3w coupe conversion. Putting 4 door front doors on works as a replacement but doesn't change the look any.
    It would be nice if someone had a picture of the car from Back to the 50's which was mentioned, to get an idea of the look he's going for.
    Hamtown Al likes this.
  17. geoford41
    geoford41
    from Delaware
    I was thinking he wanted longer doors but that is a huge undertaking and major body work that is why I added to the reworked 39 fordoor doors
  18. 19Fordy
    19Fordy
    Reworked long doors and eliminating the 1/4 windows
    will make any 39 or 40 coupe look UGLY.
    LOU WELLS and X38 like this.
  19. choptop40
    choptop40
    Minoti in Florida pulled it off on a 37 ....40 Fords are perfect , as long as they have a rake....
  20. ricky111
    ricky111
    I fully agree on that totally but have seen one where back pillar rounded with a roof chop still has back quarter windows so ver cool
    Not sure I can upload picture of another mans car to show what it is?
  21. simplestone
    simplestone
    The 38 club coupe doors are longer than on the regular coupes. I'm not sure how they compare to tudor sedan doors, tho.
    Below is a picture of the club coupe (not my car).
    And here is a regular coupe (not mine either).
    Maybe the club coupe door is what you are looking for? Or find a club coupe and use a regular coupe roof and quarter window on the rear portion?
    Hot Rods Ta Hell likes this.
  22. ricky111
    ricky111
    I’ll show you what it is I’m going to do
  23. ricky111
    ricky111
  24. ricky111
    ricky111
    [] Gary Kulgera car piece of his art work unreal[/QUOTE]
    Sorry kupfer[/ATTACH][/QUOTE]
  25. simplestone
    simplestone
    Oh, I see what you're talking about now. That's pretty slick.
  26. ricky111
    ricky111
    Very cool aye I’m 63 I’m going to do this to my coupe and daily drive until I die life is good
    So just put feelers out to se if anyone new much about this process
    I don’t like to bother the owner but I guess if you don’t ask well you won’t know
    We have some very gifted body work men here in New Zealand cheers for all comments to all
    Very cool site this very cool
    Ricky morris
  27. Rckt98
    Rckt98
    What happened to the photo, it has disappeared?
  28. ricky111
    ricky111
    Did you se the photo
  29. The 39 guy
    The 39 guy
    I am not clear on what you are wanting to do but here is a 3window with longer doors slanted B pillars.
    Another
    Even though I have shown many examples I don't want anyone to think I am in favor of making this change or any change to the body lines of the 39-40 ford deluxe coupes. Some people like it though and a few can pull it off well enough to make it worth while. I do like the last illustration however. I am going to look for a 40 coupe that I think Sam Foose built many years ago and will post it here if i find it.
    Here are the pics I could find of Sam Foose's 40 I think it has the sedan doors. Not sure though. Foose 2.jpg View attachment 5140984
    Hamtown Al, Dave Mc and kidcampbell71 like this.
  30. i7083
    i7083
    Wasn't there a thread on here not too long ago where a guy lowered the roof and used different doors? I believe he shortened the car a little to make it all work. It was somebody's father who had done it years ago...
