Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Marty Strode
    Marty Strode
    Paul, are you bringing it to Toutle ? Hope to see you there !
    kidcampbell71 likes this.
  2. Paul
    Paul
    Editor
    It's the only thing on my calendar for that weekend. ;)
    kidcampbell71, bct and loudbang like this.
  3. Tim
    Tim
    from KCMO
    Getting real close now!
  4. Paul
    Paul
    Editor
    'getting to be too long between updates.
    I've been pecking away at the little stuff, mostly clean and paint.
    I did a quick repair on the steering wheel, looks fine from ten feet away..
    I can pop it off and do it right later I guess.
    plugged the end holes in the master cylinder and drilled and tapped the stock holes to accept banjos,
    plumbed both brakes and clutch, bled and initial adjustment.
    not a lot of picture taking though, so here's a short walk around video.
  5. Tim
    Tim
    from KCMO
    Nice!
    Stogy, loudbang and Paul like this.
  6. Paul
    Paul
    Editor
    Thanks
    Stogy and loudbang like this.
  7. Tim
    Tim
    from KCMO
    Walk around videos always show a lot of details that are missed in photo updates because you wouldn’t think to take a photo of a random bracket etc. ch***is is looking great man
  8. bct
    bct
    You have to be thinking 5 steps ahead to build this clean . Thanks for the video.
    brEad, loudbang, OFT and 3 others like this.
  9. Paul
    Paul
    Editor
    When this engine was to go in an A I put together the fuel lines from the carburetors to run to the firewall,
    this go 'round it'll run through a gl*** bowl filter and forward more in the flavor of the stock J2 fuel lines, similar components just rearranged and with fewer bends.
    'ran the steel lines by the buffing wheel and screwed 'em in place.
    It'll run an electric fuel pump out back.
  10. OFT
    OFT
    Those fuel lines are supper clean!!
  11. Paul
    Paul
    Editor
    Thanks, yes and try to keep your options open.
    Earlier I drilled and tapped the master cylinders to run the lines out the ends.
    As said above I changed direction and plugged those holes and modified the stock holes to work with '57 Chevy banjo fittings.
    Here I pulled the plug at the brake cylinder and screwed in a '40 Olds hydraulic stop light switch.
    I have had good results with these switches in the past, the trick is to use the ones with screw type connections, avoid the bullet connectors.
    brEad, dana barlow, bchctybob and 9 others like this.
  12. warbird1
    warbird1
  13. Paul
    Paul
    Editor
    Gas tank mounted, fuel pump mounted.
    Almost time to start working on the body.
    Some more..
    brEad, AHotRod, dana barlow and 18 others like this.
  14. Paul
    Paul
    Editor
    Short video of first fire.
    Minor water leak at right rear head gasket..
    Plain water in it right now, should go away with proper mix and stop leak..
    Gear oil leak at gasket between Buick case and Olds tailshaft housing,
    should be an easy fix.
    But ran it for about five minutes and it didn't blow up, so that's good.
    Kreepea_1, brEad, AHotRod and 16 others like this.
  15. Marty Strode
    Marty Strode
    Paul, did you make it to Toutle ? I went Sat. didn't see you.
    Paul and kidcampbell71 like this.
  16. Paul
    Paul
    Editor
    No, unfortunately.
    Too many obligations needed attention.
    Looked like a good turnout.
    Sorry I had to miss it.
    loudbang and kidcampbell71 like this.
  17. rob-redm
    rob-redm
    nice Paul ! thanks for sharing the updates...
    Stogy, OFT, loudbang and 1 other person like this.
  18. 64 DODGE 440
    64 DODGE 440
    from so cal
    Sounds good!
  19. Paul
    Paul
    Editor
    Parking brake cables and linkage.
    '62 Corvette cables, OEM at half the price of those ugly aftermarket cables,
    misc hardware from the junk drawer and some left over s****s of steel.
    It'll get cleaned up and dressed before paint.
    PXL_20210824_222634478.jpg PXL_20210826_202104064.jpg PXL_20210826_205124099.jpg PXL_20210827_211931797.jpg PXL_20210827_211936607.jpg PXL_20210827_212130207.jpg PXL_20210828_011119711~2.jpg PXL_20210828_011155285.jpg
  20. OFT
    OFT
    Nice, did you catch the squirrel in act of stashing "nuts" lol
    loudbang and tomkelly88 like this.
  21. Paul
    Paul
    Editor
    Catch doesn't quite fit here,
    being just a baby it had no fear,
    it practically climbed into my hand.
    I put it in a box and fed it until my grand daughter got home.
    Atwater Mike, Tman, warbird1 and 5 others like this.
  22. alchemy
    alchemy
    And then you made fric***ee?
  23. Paul
    Paul
    Editor
    Granny woulda made a pie, but Elly Mae put a stop to that.
    Tman, Stogy, kidcampbell71 and 2 others like this.
  24. dumprat
    dumprat
    from b.c.
    Raise it up right and have a new shop security attack squirrel!
    Tman, Stogy and loudbang like this.
  25. 64 DODGE 440
    64 DODGE 440
    from so cal
    Leash train it and tell people it's a micro miniature hunting dog.
    Tman, Stogy, loudbang and 1 other person like this.
  26. Paul
    Paul
    Editor
    Parking brake done.
    Now what else was on that list?
    brEad, AHotRod, The 39 guy and 11 others like this.
  27. Dave G in Gansevoort
    from Upstate NY
    More ideas to plaigerize. Thanks Paul, between your build and Marty Strode's I'm getting lots of help with mine. Others as well...
    The 39 guy, Stogy, OFT and 3 others like this.
  28. Paul
    Paul
    Editor
    pulled the points distributor, couldn't get it to run right on just the battery.
    'might run better with generator and full charge.
    stuck a magneto in it's place,
    one I had on the shelf for a while,
    looks a bit crusty under the cap,
    surface rust from trapped moisture no doubt,
    but it snapped when turned so in it went.
    runs much better,
    enough to run in the cam,
    varied rpm about 1500 to 2500 for twenty minutes or so.
    guesstimated, no tach hooked up and didn't even look at the clock.
    short clip at idle:
    brEad, Tim_with_a_T, Dago 88 and 6 others like this.
  29. Stogy
    Stogy
    A Gearhead Symphony...Golden Rocket indeed...Very Golden...you have a magic touch kind of like Midas...King Midas that is...;)
    Dago 88, loudbang and Paul like this.
  30. Paul
    Paul
    Editor
    oh yeah,
    fixed the minor leaks
    it never got above 185
    and it made no funny noises
    other than a bit of popping at higher rpm,
    ignition again I'm fairly certain.
    all that can be sorted out..
    who services Vertex magnetos in the Seattle-Tacoma area?
    Tman, Dago 88, loudbang and 3 others like this.
