1926 Sleek T build thread
Discussion in 'The Hokey Ass Message Board' started by flyin flattie, Jun 24, 2021.
  1. flyin flattie
    flyin flattie
    from Redmond OR
    Here is a photo dump of the new T I’ve been working on for way to long and am finally gaining traction on. Enjoy
    Six Ball, vtx1800, 1pickup and 18 others like this.
  2. flyin flattie
    flyin flattie
    from Redmond OR
  3. flyin flattie
    flyin flattie
    from Redmond OR
  4. flyin flattie
    flyin flattie
    from Redmond OR
    IMG_7725.JPG IMG_7742.JPG IMG_7758.JPG IMG_7740.JPG IMG_7803.JPG IMG_8052.JPG
  5. flyin flattie
    flyin flattie
    from Redmond OR
  6. flyin flattie
    flyin flattie
    from Redmond OR
  7. flyin flattie
    flyin flattie
    from Redmond OR
  8. flyin flattie
    flyin flattie
    from Redmond OR
  9. Tim
    Tim
    from KCMO
    Threads been moved it’s where’s it’s supposed to be ;)
    looking good Tim!
    Six Ball, Stogy and kidcampbell71 like this.
  10. alanp561
    alanp561
    Well done! How very well done!!
    Six Ball and Stogy like this.
  11. My oh my
    Keep photo dumping !!!!!!!!!
    but some story on what your goal is would be fantastic
    Six Ball, Stogy and Shadow Creek like this.
  12. flyin flattie
    flyin flattie
    from Redmond OR
    Basic story is a good customer friend Tom dropped off this early 2000 rat Rod with body mounts for a crossly 4 banger which was gone. The ch***is was mig welded suicidal madness so I decided to start fresh with new A rails.
    I split em fit em and in the process flipped the rails backwards because the rails have a much better taper in the rear. Then I found a bad *** GM fire wall ( cowl said body by fisher). The front crossmember is as flat as a 2x4. 2” tube supports connect the trans crossmember to the kick up in the rear.
    I rearranged the front end by welding a bung to hold the spring behind the axle, in the
    To dep the rear I used 2x3 x 3/16 square tube and tapered it to now fit the new back of the rails, then jogged it in and up and put the A crossmember as Low as it will go ( I need to C notch it all now including the sub rails)
    The motor is a late 36 insert bearing polished to the hilt bottom end! So it seems to be solid so we decided to go with a T 5 for pickup and go! The only kicker is the offer adapter needed a C ground where the starte is [emoji85]but it’s good.
    The nose is a story. I wanted to make this thing but was apprehensive for good reason. I finally grew some and made dellren shrinking dies for my vibro shear and went to town ( make sure the thumb is only .1/4” tall! Max because I didn’t first go around and we’ll it wasn’t compressing the metal as you pulled it back out there in it wasn’t shrinking very well. Long story short I fixed the die and there ya go. Also made the back hem and welded it in. The hood sides I ran full beads ( model A size) and that’s where I’m at so far. Oh and the grille is a xk 120 flipped on its head!
  13. flyin flattie
    flyin flattie
    from Redmond OR
    Also the over all plan is polished hood and grille with nice paint color will be determined by how much I fumble mixing colors and black axles and such. Y’all will see soon enough when the next dump happens. I don’t do social media so your getting an exclusive look into my shop ( located in central Oregon). Hope the next round of photos come sooner than the last.
  14. A Boner
    A Boner
    Very slick build...keep the pics coming!
  15. Tim
    Tim
    from KCMO
    Awesome! I’ve missed seeing what you’re building, can’t wait for the next installment:)
  16. flyin flattie
    flyin flattie
    from Redmond OR
    Hey to another that is called Tim thank you! I’ve been busy now that I have a stable for my craft and it’s only up from here! I’ll be plaguing the H.A.M.B. with more stuff to come. Thanks for the kind words TIM.
    Six Ball, Stogy and Tim like this.
  17. Squablow
    Squablow
    Is that a 26 Chevy firewall? I had one of those once, very cool looking piece, I like that. Looks like you're undoing/redoing it right.
  18. rotten ron
    rotten ron
  19. Rynothealbino
    Rynothealbino
    Very cool. Makes me want to dig up my roadster project and get to work on it. Are you going to run the floor to the bottom of the frame rails? That's one of the main reasons I did it on my project, so I could sit in the car, not on it.
  20. flyin flattie
    flyin flattie
    from Redmond OR
    Yup I’ll be doing something similar to my past but a little better because it’s the motha funkin future!
    alanp561, Six Ball, 1pickup and 14 others like this.
  21. silent rick
    silent rick
    haha, are those front shocks i see on the sweet tea? @flyin flattie
  22. Very cool! I like the frame rails flipped. What was the OT engine pictured?
  23. flyin flattie
    flyin flattie
    from Redmond OR
    Yup yup put tube shocks on the front. It definitely helped when I hit a patch of highway 5 that was being “ worked on”
  24. silent rick
    silent rick
    just remembering the **** you took for not having any when you first built the car. love your work
  25. Tim
    Tim
    from KCMO
    Just a bump to the top, this aught to really be a killer hot rod!
  26. flyin flattie
    flyin flattie
    from Redmond OR
    Little update on the hood
    vtx1800, alanp561, GordonC and 16 others like this.
  27. Tim
    Tim
    from KCMO
    Look killer! The hood top really ties it together.
    with out the top I kept getting distracted by the shape of the hood sides. I think they must have kind of a twist to joint the cowl and track nose shape? Maybe it’s just the louvers messing with my eyes. Either way with the hood top on I love it all.
  28. flyin flattie
    flyin flattie
    from Redmond OR
    Hey thank you! Yeah the hood sides do have a twist in them. I made them flat to begin with then shrunk the back top edge and it kinda just found it’s way to twisting into shape. Matt Seret thought me about doing this type of stuff and his great words of wisdom were to do one thing at a time. Not to ***ume what worked on one side will just simply work on the other.
  29. Tim
    Tim
    from KCMO
    Well it looks fantastic man. Louvers look spot on it’s really going be be a car to sit and study when finished. Thanks again for sharing!
  30. flyin flattie
    flyin flattie
    from Redmond OR
    Did some steering figuring. Got the 2”tube cowl support body mount in and the 3/8 x8” plate welded and tacked in. I extended the steering shaft 2” in the middle and it all worked great. I’m planning on case hardening the shaft now that it’s all test fit. then I modified a 38 dodge steering arm to work and it all fell into place. Just have some welding to be done and on to the next stage..
    Six Ball, patmanta, Jet96 and 6 others like this.
