Sunday models
Discussion in 'The Antiquated' started by milo1303s, Mar 16, 2014.
  1. HJmaniac
    HJmaniac
    They look great. The couple of Hubley kits I built as a kid never looked anywhere near what those look like. You are fortunate have them and the memories.
    Dan Hay and Sancho like this.
  2. musclecars
    musclecars
    yeah I know it's been a while (April to be exact)since I last posted,doesn't mean I haven't been building though.Here are some I've finished since then.[​IMG]
    And one out of character for me
    Thanks for looking and sorry I haven't been posting regularly.Happy Modeling !
  3. rudestude
    rudestude
    Damn....you hit right where it feels good with that 32 Roadster,...raised white lettered tires on a black (dark) reversed wheel just says cool.
    The whole package ,color combo, nerf bars,
    Very cool.
    Deuces and Mike-model like this.
  4. Mike-model
    Mike-model
    PACERS Fuel Altered, 1:16 br*** project.
    After more than a month of looking for 12 spoke wheels in 15", tires are also nowhere to be found.
    I made my own 12 spokes.
    Here the method and the results....
    Here the real car, photo courtesy Scott Snizek;
    Br*** 12 spokes @ 15"
    Other side;
    First off, an aluminum pipe segment with the exact inner diameter, 23 mm needed. The outer rim is annealed, bent and soldered together, visible inside the pipe;
    The inner rim using an alloy with more copper (stronger, more rigid), already prepped for thee spokes. The inner rim was annealed, bent and soldered up against the outer rim....both inside the aluminum pipe;
    Inner rim just slide fits into the outer rim;
    Getting things aligned, a good drawing is needed, also a shot of the hub/spacer with 1.4 mm tubing for the spokes;
    Spacer/hub;
    The method works;
    Meantime, wider nylon O-rings have arrived. They were filed down on the outer surface to make a flatter pavement contact. They work, cheap too.
    This project is moving along once again. Motor has arrived, now in the works.
    Mike..
  5. quick85
    quick85
    Mike, I'm amazed by what you do. Each post/photo is interesting because
    nothing is standard out-of-the-box. You have the ability to work out each
    stumbling block and come out golden.
  6. Mike-model
    Mike-model
    Thank you quick for the recognition, greatly appreciated. I ordered and received resin wheels form 2 different vendors, just the "quality", or rather lack thereof forced me to move on....thinking even before starting this project the 12 spoke wheels will be a major problem. They had to get done. The wire wheels on the FEDs worked, so basically, the same methods were applied this time....grateful it's over. Next time on a future car will be much easier.
    Mike..
  7. rudestude
    rudestude
    As always Mike....perfection.
    Them resin wheels are not for you.
    To get something that fits your quality of builds you pretty much have to build it your self....general hobby parts suppliers can't provide the quality of parts that equal your caliber of builds...they couldn't make any money.
    That's what makes your builds so cool...you build them....no kits...just you.
    Thanks for sharing them with us.
  8. musclecars
    musclecars
    guess I'll start off Sunday model show with this '49 Ford Coupe I just finished.Color is Tamiya TS-51 Racing Blue,parts box items also used.[​IMG]
    Thanks for looking and Happy Modeling !
  9. Deuces
    Deuces
    Some pics from model cars magazine.... IMG_3205.thumb.jpeg.9eb03e7bca117133cdeb1ca11d4e1c79.jpeg IMG_3235.thumb.jpeg.7629569996e71e132c143d0bbe53bbd5.jpeg IMG_3206.thumb.jpeg.85418d8e98bda2f92789da0c0470066b.jpeg IMG_3227.thumb.jpeg.1c3b6a348cdcc1dc984adbaa70907156.jpeg IMG_3230.thumb.jpeg.ad2768088d24b095f08357c11559d798.jpeg IMG_3203.thumb.jpeg.fe43a8e869ff968b060efd1b811bd1c5.jpeg IMG_3216.thumb.jpeg.94877bffaa18a0fc66805caee251b735.jpeg IMG_3204.thumb.jpeg.246239bd9592b52dae68fd2dd1d8c569.jpeg IMG_3213.thumb.jpeg.ff935fdd7d0e4a56c21cca6221cb5e9c.jpeg IMG_3210.thumb.jpeg.c65d0e3b5599b167fa10aef8b39f380a.jpeg IMG_3218.thumb.jpeg.c7c953ec693096358198571a276ef567.jpeg IMG_3212.thumb.jpeg.f5ee4214f99d35d79d3813ab2276983e.jpeg IMG_3217.thumb.jpeg.198018f9b40076bb318fa3da78bf52bf.jpeg IMG_3223.thumb.jpeg.a63ad0cd8dae6976007159a085694084.jpeg IMG_3208.thumb.jpeg.20e0dd9361c3e7689b0c0456b77274f0.jpeg IMG_3226.thumb.jpeg.17867d77abab665dc95ec265cee56d11.jpeg IMG_3209.thumb.jpeg.b42fbad142b62e89742d4fac8a244306.jpeg IMG_3200.thumb.jpeg.89f39e8dfd9d4bf67f068ac58cc9b7d8.jpeg IMG_3215.thumb.jpeg.3544be460599006ac5651227896b86a6.jpeg IMG_3201.thumb.jpeg.9ce89c4a283d1279643a5f9a47c3eeab.jpeg
  10. Deuces
    Deuces
  11. Mike-model
    Mike-model
    PACERS Fuel Altered, some motor progress. This is a 3d printed 392 kit from a FB trio, excellent, smooth parts. The motor width, valve cover to valve cover is exact scale. Cannot get any better. They are 1320 MODEL PRODUCTS in case anyone would be interested. Only available from FB.
    I decided to add some br*** features and a few changes to replicate the real car. The large tubes in the heads are to allow the exhaust pipes (scale 2.5") to have a sturdy base, not sure yet if the exhaust tubes will slide over the stubs or rods sliding inside them....figure this out later on.
    For holes in non-metal parts I prefer to sleeve them so the bolts will sit properly later on.
    -IMG_4284.jpg -IMG_4293.jpg -IMG_4294.jpg -IMG_4296.jpg -IMG_4299.jpg -IMG_4301.jpg -IMG_4304.jpg -IMG_4305.jpg -IMG_4306.jpg
    Still small things to do , more later...
    Mike..
    The 39 guy, mchook, D type and 15 others like this.
  12. John Barker
    John Barker
    from So. CA
    Hey Deuces, those are my models dude!!!! Glad you like ‘em! I have a few more ‘62 -‘66 SS’ers I could post if anyone’s interested.
    John (papajohn97)
  13. Deuces
    Deuces
    Hell yeah! Post them up and thank you!!!!!.....:)
    lothiandon1940 likes this.
  14. John Barker
    John Barker
    from So. CA
    Here’s some I don’t think I’ve posted on here before. This ‘62 Ford is kitbashed using the AMT ‘60 Starliner for ch***is/ engine/ interior and a resin body and homemade decals:
    75679EBF-2B73-43CE-9DA7-F67554626A00.jpeg BEF88BA4-53A3-4FDE-B0C8-E0CEBB993D89.jpeg 33DFE3EE-D631-4405-AF9F-A58BC96E5F82.jpeg 5E7CF82B-3C07-4C17-880B-F6EDCD432E1B.jpeg C7397BDC-0011-470C-9FB8-D4A90813DBEC.jpeg
  15. John Barker
    John Barker
    from So. CA
    This is the AMT ‘66 Nova kit with Sli** decals (AMT decals look beautiful but fall apart when wet):
    A76C841D-B439-4A55-BF96-6213F782E9C3.jpeg 6E2D1D7B-386E-44EC-9A3D-A493C9CA6E72.jpeg 2EA9E0D9-F7B4-4CD0-A6D8-FCBED6DEE7BC.jpeg 1E8F5404-976B-4797-B58F-D97BDF3C8D69.jpeg DD7F9F97-E845-4DCF-AB81-C9CC93654973.jpeg
  16. John Barker
    John Barker
    from So. CA
    This one was built from the Revell ‘65 Chevelle Z16 1/24 kit with lots of aftermarket and scratch built parts and Sli** decals:
    ACAA41C5-9098-4CFA-8B23-F9FC3AFBEC0F.jpeg 222A8795-189E-41B9-B1C6-18C8B479E55F.jpeg 001B2841-9DE0-4474-99E2-1305D9216A0C.jpeg 78943EA1-66BF-429E-A471-3CADD3B8EE9D.jpeg
  17. John Barker
    John Barker
    from So. CA
    This is the Revell ‘64 Thunderbolt kit, one of my favorites, built mostly OOB. 669678E0-29E4-4C8B-8832-B796C0C76E71.jpeg 9EA1D673-F145-47B1-9D15-410783D04467.jpeg C53F5F05-6C75-4D2C-BAAA-A8BC12B64955.jpeg 2C89276F-F25B-4DC5-8FC4-DB9EA1989BFA.jpeg
  18. John Barker
    John Barker
    from So. CA
    This is my attempt at making a silk purse out of AMT’s really bad ‘65 Mustang “Funny Car” kit. Joe Curtis of Fremont Racing Specialties made these and the Les Ritchey decals for me. If you’re into modeling cl***ic 60’s SS, A/FX, early funny cars, check his decals out on eBay, they are fabulous.
    99857B1B-4E14-4E18-9B9F-897D1E032044.jpeg 0837944C-394F-4854-BC2E-E40B1A3F96CA.jpeg 8FA944E0-8C82-4B38-A985-515F4A78365E.jpeg 78B76D59-C427-4845-8062-30508E7643FB.jpeg
  19. John Barker
    John Barker
    from So. CA
    This is the Lindberg ‘64 Dodge with aftermarket decals (stripes were painted) and lots of aftermarket snd scratch built stuff under the hood.
    EC3CE0EB-71CB-472D-BBDC-6DC11B7C4783.jpeg 86470B53-749B-4355-ADED-2A5D974DD906.jpeg 80458FB5-3F61-4870-A3DC-F73FBBDD7DF9.jpeg 94BE47F2-4A39-46DB-A80E-7650EE7788FC.jpeg FB29F942-1371-4710-B56D-82B4A79ED1B6.jpeg
    I have a few other SS models I’ve posted on here last year, just do a search using my name if you’re interested. I’m taking a break from SS’ers these days (currently building an Airfix B-17G and Revell’s new tooled XKE roadster) but will try to post more HAMB friendly model cars on here in the near future. Cheers, John
  20. Deuces
    Deuces
    Thanks John!!!... You did good sir!!....:)
    lothiandon1940, NHRANUT and HJmaniac like this.
  21. quick85
    quick85
    I don't know why exactly but the Kelly Chadwick Malibu is my fave. First,
    a great looking model. Second, you seldom see the name Kelly Chadwick.
    Third, a good friend had a '64 Malibu in high school (1968) that looked
    good in Navy Blue with chrome reversed wheels and sitting high at all
    four corners. Forth, I got to borrow it if my '66 Nova was down. Thanks,
    Dave Artis, wherever you are.
    rudestude, Deuces and Sancho like this.
  22. philo426
    philo426
  23. musclecars
    musclecars
    Lets get Sunday started off early
  24. philo426
    philo426
  25. Dennis D
    Dennis D
    IMG_0080.JPG I just started on building my first diorama. 1/24 scale Texaco station. Kinda using the photo of an old station in my boyhood hometown as a guide. I believe the station was built in the late 50's early 60's. Any suggestions to sites or books that might be helpful? Thanks. D Bismarck Texaco.jpg
    Starting with this:
    Sancho, mchook, D type and 5 others like this.
  26. Deuces
    Deuces
    Very cool! I started working at one in Dearborn when I was 15... Every day after school and on weekends... Now there isn't one Texaco station left in Michigan... :(
    At least I don't think there is....
    lothiandon1940 and Lil32 like this.
  27. Dennis D
    Dennis D
    All gone in Mo. also. I think the brand is still alive in Texas.
    Deuces and Lil32 like this.
  28. musclecars
    musclecars
    Hey Dennis,nice start to your Texaco station.Not to steal away from your post but here is the one I have.I started with a 2 bay garage from ScaleModelingbyChris who unfortunately p***ed away a few years back and is no longer in business,he made some great diorama buildings which were laser cut and very easy to build along with gas pumps from different eras.I made the overhang using a resin roof and evergreen tubing,plastic menu letters you would see on menu boards in restaurants.
    By the way my Uncle and Aunt also live in St. Peters
  29. Dennis D
    Dennis D
    Nice job! That is the same kit I am starting with. I wish I could find one of the bathroom kits he made. Where did you get the lights and would like to see some more detailed pictures so I can "maybe borrow" some of them. Thanks, Dennis
  30. musclecars
    musclecars
    Thank you,here are a couple more pics,if it helps ya.The lights are Hobbico,AAA battery run.Think they are for show lighting in a display case,they are flat and have a little wheat bulb.You should still be able to find them,the bathroom stuff is another story.Rumor has it that Paul's family threw all the molds away after his death which I find hard to believe since his brother Chris started the business in the first place until he got into doing airplanes and handed off the dio stuff to Paul.Really miss Paul and always wondered what he would have come up with next.
    This last pic was taken a while back,I no longer have Fast Eddies speed shop and car lot so the dio has taken a slight downturn.Now only have the Texaco station,Bob's Diner and Hank's Speed shop.I sold Fast Eddies to a fellow club member a couple months ago.Hope this helps ya a little more I can take some more pics of the Texaco station if you like.
