Hot Rods Look what showed up today.
Discussion in 'The Hokey Ass Message Board' started by keith27T, Aug 6, 2021.
  1. Stogy
    Stogy
    That was a hit that sure must have been memorable...:eek:
  2. keith27T
    keith27T
    I no taking the bumper of was.
    loudbang and Stogy like this.
  3. Stogy
    Stogy
    I bet...big Honking rusty tights...:eek:
    Nothing better than skinned knuckles and rust in the eyes...:oops:
    loudbang and keith27T like this.
  4. keith27T
    keith27T
    Little more progress. Dis***embled. Now to clean up and put back together. 38A33CC5-7B6A-4595-B67F-65C4A0A083EF.jpeg
    Stogy, loudbang, Thor1 and 1 other person like this.
  5. keith27T
    keith27T
    Hey v8flatt44,
    Yes did some checking getting a couple bottles. AC Delco EOS (Engine Oil Supplement)
    Canada Part#992869 Has anyone here had any experiences with this product? How much do you use?
    Searching, but seems people have different opinions.
    When I changed the oil I used Lucas 10/30.
  6. vtwhead
    vtwhead
    Keith, last I knew GM did not recommend using it as an oil additive. Isn't that just a zinc supplement for new ***embly run in?
    MBog and loudbang like this.
  7. keith27T
    keith27T
    Not sure, some guys add it. That's why I am asking first.
  8. jaracer
    jaracer
    If I remember right it was about the equivalent to STP.
  9. keith27T
    keith27T
    Okay just go the stuff.
    It says: Sticky Lifter And Noisy Valve Train: Add the contents to SF/CC, SG/CC, additive.jpg SH/CD engine oils at or between oil changes. If condition persists, consult your ACDelco Dealer.
    Also for new cam/lifters. rebuild engines.
    My question is , what are these oils I can add it to?
    loudbang, Deuces and Stogy like this.
  10. flatheadgary
    flatheadgary
    from boron,ca
    i am a little late to the party but, you can't use adjustable push rods in olds motors. there isn't enough room between the rocker and the head. i had a 394 and put in a hot hydraulic cam and tried the push rods and had to put them into the block to get it to run. very hard to adjust without it running. they used to make adjustable rockers back in the day but they were more than the push rods so i tried them. bad move.
  11. Budget36
    Budget36
    I believe the SF/-etc are the type of oil spec. Should see that on your oil can/bottle as well. I ***ume it’s compatible with those types only?
  12. Gary Addcox
    Gary Addcox
    Well, you just picked up several miles per gallon with that anchor laying on the garage floor. LOL
  13. keith27T
    keith27T
    Bumper on today. Not perfect but it’s better then it was.
    Now to clean it up and reinstall the signal lights.
    Need a new signal lense and headlight ring which I found on ebay. Should be here next week.
    Squablow, loudbang and Thor1 like this.
  14. keith27T
    keith27T
    Moving along. Painted the rims and found some white wall tires for them. Looks like original. Re did front brakes, and hoses. Back brakes where okay. Just had to be clean them up. Finally replaced the valve covers gaskets and carb vacuum line. Think I am going to replace the master cylinder and the brake line to the back brakes it is a little rusty. 2F61C296-5D8A-489D-BDFB-C1F17BD78E1F.jpeg 1DF91500-B9D9-4EE4-9A5F-66A6BA20C00C.jpeg Also am going to replace the rusty fuel line. And then thinking about putting a trans cooler in and changing the trans filter.
    It’s coming along.
    guthriesmith, Squablow, Al T and 2 others like this.
  15. keith27T
    keith27T
    Update:
    Installed new master cylinder, brake line, and new brake hose. Now need to bleed the lines.
    Picked up a new fuel pump, as looks like mine is leaking around the gaskets. Will replace with new filter as well. Then onto the fuel line and trans filter and gasket...........
    MBog, Texas57, Thor1 and 1 other person like this.
  16. keith27T
    keith27T
    She’s on the ground! A1AF7D0A-E267-445D-BBD3-8B89DE0D2D66.jpeg FC3F666D-6FAF-4E2D-9075-AB65AAB83A78.jpeg
  17. keith27T
    keith27T
    Finally got her on the road this car is a really nice riding car, I never drove an Oldsmobile.
    With the price off 94 these days, she is a little expensive to go on long trips. But what a joy to drive. Oh and the valves sound much better after a tuneup and a trip down the hwy.
    MCjim, treb11, Budget36 and 5 others like this.
  18. SS327
    SS327
    EOS is good to use in a flat tappet engine. Has the highest crush strength of any lubricant I have ever used. Do not use it in a roller cammed engine! It has such a high film strength that there is not enough friction for the rollers on the tappets to roll and will flatspot the roller eventually once EOS is no longer used. It also should not be used with every oil change. I’m an ex Buick mechanic.
    Thor1 and Budget36 like this.
  19. keith27T
    keith27T
    Thanks for this info. Will be adding at every oil change????
  20. gatz
    gatz
    Nice vehicle !
    I remember those as new.
  21. SS327
    SS327
    Every other oil change or every 2 changes is all you need.
  22. keith27T
    keith27T
    Thanks for that SS327
  23. keith27T
    keith27T
    Added original rings to the wheels.
    Thor1, Algoma56 and anothercarguy like this.
