Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. 33Doll
    33Doll
    Blasted the old headers. Still look solid.
    Cool! Don’t have to fab new ones!
    Especially since it doesn’t have your off the shelf parts. Everything is custom fabricated.
    Gonna running Short pipes, with short Cherry Bomb M-80’s coming out the side, in front of the rear wheels. Aught to wake up that Flatty!
    upload_2021-8-9_20-41-55.jpeg upload_2021-8-9_20-41-55.jpeg upload_2021-8-9_20-41-55.jpeg upload_2021-8-9_20-41-55.jpeg upload_2021-8-9_20-41-55.jpeg
  2. 33Doll
    33Doll
    Kinda like this First incarnation of the Doll in the early 70’s
    Except I will do Slash-cut tips!
  3. brEad
    brEad
    Go Doll! Go!
    That old pic is cool.
  4. 33Doll
    33Doll
    Having a wonderful time trying to get my shocks to clear they just rubbed a little bit before on the hairpin, So I chopped mounts down about an inch and a quarter. But now it’s real close to the perch and shackle.
    So with the right spacer on the bolt, it will be just…. Centered…. Enough…
    Darn custom build stuff!
    But thats what makes it neat from off the Shelf Parts, and Kits. Enough to drive you crazy sometimes! But worth it!
    upload_2021-8-11_20-49-36.jpeg upload_2021-8-11_20-49-36.jpeg upload_2021-8-11_20-49-36.jpeg upload_2021-8-11_20-49-36.jpeg
    kidcampbell71, Stogy, brEad and 2 others like this.
  5. 33Doll
    33Doll
    Shocks done, just need to pull them back apart and paint everything, re***emble then start on the body.
    upload_2021-8-16_22-56-43.jpeg upload_2021-8-16_22-56-43.jpeg upload_2021-8-16_22-56-43.jpeg upload_2021-8-16_22-56-43.jpeg upload_2021-8-16_22-56-43.jpeg upload_2021-8-16_22-56-43.jpeg upload_2021-8-16_22-56-43.jpeg upload_2021-8-16_22-56-43.jpeg upload_2021-8-16_22-56-43.jpeg upload_2021-8-16_22-56-43.jpeg upload_2021-8-16_22-56-43.jpeg
  6. 33Doll
    33Doll
    Just got back from a little Vacation at the coast.
    (Boy we needed It!)
    Got a little Garage time today!
    I had a plan to stick to painting the shock mounts and fender braces and then work on the exhaust. But I got a little sidetracked when I decided to see how easy my Brillo wheels I was using on the fender Braces, would strip the Body paint and I decided to start where I saw some Bondo showing, and of course that led to grinding it all off!
    Found a little fun underneath!
    Not too bad though. Apparently they just Bondo-ed over the dents, and used way to much. so I’m gonna work the dents a little bit and then just skim coat it.
    I have to figure out how to strip the doors without digging into whatever might be underneath. I don’t wanna strip whatever filler might be on them.
    upload_2021-8-23_16-20-8.jpeg upload_2021-8-23_16-20-8.jpeg upload_2021-8-23_16-20-8.jpeg upload_2021-8-23_16-20-8.jpeg upload_2021-8-23_16-20-8.jpeg upload_2021-8-23_16-20-8.jpeg upload_2021-8-23_16-20-8.jpeg upload_2021-8-23_16-20-8.jpeg upload_2021-8-23_16-20-8.jpeg upload_2021-8-23_16-20-8.jpeg upload_2021-8-23_16-20-8.jpeg
    oliver westlund, rpm56, Stogy and 4 others like this.
  7. 33Doll
    33Doll
    The shocks were topped out with the Spacer I added to spring.
    It was really close before anyway. It would go down a little with the weight on the car, but you really want it in the middle of the stroke at Ride height! So now the front an d rear should be right in the sweet spot!
    Along with the Traction bars being more Close to Henrys angles, This thing should Ride and
    Handle so much Better!
    Cant wait to see!!!!
    upload_2021-8-23_17-38-16.jpeg upload_2021-8-23_17-38-16.jpeg upload_2021-8-23_17-38-16.jpeg upload_2021-8-23_17-38-16.jpeg upload_2021-8-23_17-38-16.jpeg
    rpm56, Stogy, loudbang and 3 others like this.
  8. 33Doll
    33Doll
    Front is Done Too now!
    Fab up some exhaust, Mount the running
    boards temporarily, because they are coming out the side. and then start back on the Body!
    Yaay!!
    upload_2021-8-23_19-41-47.jpeg upload_2021-8-23_19-41-47.jpeg upload_2021-8-23_19-41-47.jpeg
  9. 33Doll
    33Doll
    Got one side of the exhaust mocked up, and tack welded!
    I wonder how loud a Flatty will be with 3/4 length 1-3/4 pipe with 2-1/4 tips?
    Should be Quieter then a Harley.
    Oh well we will see, if I don’t like it, I can Always add mufflers later. I just want to build the car and get it drivable.
    It ought to sound *****in though!
    upload_2021-8-26_19-57-33.jpeg upload_2021-8-26_19-57-33.jpeg upload_2021-8-26_19-57-33.jpeg upload_2021-8-26_19-57-33.jpeg upload_2021-8-26_19-57-33.jpeg upload_2021-8-26_19-57-33.jpeg upload_2021-8-26_19-57-33.jpeg upload_2021-8-26_19-57-33.jpeg upload_2021-8-26_19-57-33.jpeg upload_2021-8-26_19-57-33.jpeg
    40ragtopdown, loudbang, Stogy and 2 others like this.
  10. Jim Bouchard
    Jim Bouchard
    It will sound TOTALLY *****EN!!!!
    loudbang, Stogy, 33Doll and 1 other person like this.
  11. dumprat
    dumprat
    from b.c.
    I haven't seen cu and splice exhaust in a while! Looks good though. Should sound pretty good. Flatheads aren't very loud.
    Stogy, loudbang and 33Doll like this.
  12. 33Doll
    33Doll
    Thanks!
    Yeah, I don’t have a tubing bender. Plus I’m “repurposing” the old Exhaust, and “Reapplying”(routing) it Differently!
    The chrome tips are some tubing my neighbor gave me that was part of some type of fancy garage shelving! All Home Built stuff! Supposed to look like some kid did it in the 60’s Right?
  13. Stogy
    Stogy
    You're smokin' @33Doll...now tell us how Pumped you're getting...Looks real good Hamber...;)
  14. 33Doll
    33Doll
  15. 33Doll
    33Doll
    Both sides done!
    Just have to pull them off and finish weld and paint! Probably hang them on the wall until Im ready for them! (Running out of wall Space!)
    Also
    Did some fun Hot-Rod scoops on the tips!
    Groovy-Man!!!
    upload_2021-8-27_17-18-22.jpeg upload_2021-8-27_17-18-22.jpeg upload_2021-8-27_17-18-22.jpeg upload_2021-8-27_17-18-22.jpeg upload_2021-8-27_17-18-22.jpeg upload_2021-8-27_17-18-22.jpeg upload_2021-8-27_17-18-22.jpeg upload_2021-8-27_17-18-22.jpeg upload_2021-8-27_17-18-22.jpeg upload_2021-8-27_17-18-22.jpeg upload_2021-8-27_17-18-22.jpeg
  16. 33Doll
    33Doll
    Last bit of inside stripping before wire wheeling cleaning, filling coating. I am so grateful the wood and metal inside is all intact and still good! Just tighten the screws, and new nails!
    upload_2021-9-5_12-53-51.jpeg upload_2021-9-5_12-53-51.jpeg upload_2021-9-5_12-53-51.jpeg upload_2021-9-5_12-53-51.jpeg upload_2021-9-5_12-53-51.jpeg upload_2021-9-5_12-53-51.jpeg upload_2021-9-5_12-53-51.jpeg upload_2021-9-5_12-53-51.jpeg upload_2021-9-5_12-53-51.jpeg
    Stogy, brEad, 40ragtopdown and 4 others like this.
  17. 33Doll
    33Doll
    Well
    The Fun stuff has begun! Stripping all that Lacquer!!!! Man I hate body work!!
    Fixed the dents! They are alot better then when they were covered up before! Wont have as much filler this time!
    8B02B158-42AB-40A0-98F7-9D61A8549C00.jpeg 04315870-408A-4894-AABB-DB29683B8A7F.jpeg 72C09164-612F-44A8-B624-0C892AF3B865.jpeg C1EC35A1-22F9-4E66-8A1D-33D2470F3DF3.jpeg 73666F08-1DEF-4990-B81A-2E8EF829A1C5.jpeg F43AAA9D-A16F-48E8-8EB5-18028FB8E489.jpeg BF0532CE-B337-4E23-8A63-E06B593EF495.jpeg BE8B0756-2FFB-4848-ADCA-F07BA7A0DAD3.jpeg 252D0A9A-A0BA-42B2-BD71-0B747EAB1CB7.jpeg 5DDEE16A-F0E5-439A-931F-7BA9DAD5169E.jpeg 18B7AF52-8C2A-457A-BABF-63311BBBD942.jpeg F69058B8-4DED-4C58-AE78-1790C62C0FDC.jpeg
  18. 33Doll
    33Doll
  19. dumprat
    dumprat
    from b.c.
    Going to chop it 3" while you have it all stripped down? Lol
    Joel W and kidcampbell71 like this.
  20. loudbang
    Stogy, rusty valley and 33Doll like this.
  21. 33Doll
    33Doll
    54263B2A-8863-460E-BE36-943B18CD6680.jpeg No. Not this one. Too
    Many Curves! Plus its the Doll!
    You guys did talk me into filling the cowl light holes!
    But…..I have a plan!
    I’m gonna put them down on the frame horns underneath the Fenders.
    Depends on where the curve is which side the frame. I’ll put it
    Plus I’m making Nerf bars out of 37 Ford Bumper-ettes.
    Stogy, brEad, 40ragtopdown and 2 others like this.
  22. 33Doll
    33Doll
    Thanks!
    I actually like fixing the dents and stuff.
    It’s all the stripping and sanding and body filler….. and sanding….and body filler and primer and sanding…and….
    Lol!
    Stogy, brEad and loudbang like this.
  23. 33Doll
    33Doll
    This is so…. Much Funnnn!!!!!
    NOT!
    Stogy and loudbang like this.
  24. 33Doll
    33Doll
    C618F474-21C4-4910-A921-D2E91CE20722.jpeg Well it looks like the Jasco routes going to work!!!
    Less than 10 minutes to do this to the original Lacquer!!!
  25. 33Doll
    33Doll
    NASTY!!!!
    It Burns!!!!
    Sacrifices a Hotrodder does!
    only another Hotrodder knows!!!!
    45B69C5E-75DD-4912-AE93-46250208DB8D.jpeg C5999F8B-A396-450F-9547-4C1EFA761198.jpeg
    Stogy, brEad, loudbang and 2 others like this.
  26. 33Doll
    33Doll
    Not bad for a few hours!
    Now the brillo wheels will work quick
    6CE090CC-6D13-4E20-B099-1596B6C8A4F6.jpeg 2F1C2CA1-175D-470B-BB53-B2A922A5E64E.jpeg 05131FCF-F886-4DD9-AD70-A3D14A73ADBD.jpeg
    Looked like this a few hours ago:
  27. 33Doll
    33Doll
    Well… after several burns… and weird taste in my mouth! I got all the Black paint off the Front!
    Just the rear Drv Quarter and the body will be easy to finish to shiny new metal!
    (Fenders doors and hood, I can do one at a time on saw horses!)
    The Hard part is done. Just need to Fill a bunch of bolt holes, few stress cracks, Por 15, seam seal, and undercoat. Sounds like a lot, but not really.
    How is it my whole garage ends up on the floor every time in less than an hour!!!
    Cant wait to get at least the shell
    Back on the ch***is!!! YAAY!!!
    upload_2021-9-6_16-36-21.jpeg upload_2021-9-6_16-36-21.jpeg upload_2021-9-6_16-36-21.jpeg upload_2021-9-6_16-36-21.jpeg upload_2021-9-6_16-36-21.jpeg upload_2021-9-6_16-36-21.jpeg
  28. 33Doll
    33Doll
    Love My Work sometimes!
    We have a punch press, so I made a “hole” bunch of plugs for various holes on the fire wall and floor boards and such!
    oliver westlund, Stogy, brEad and 5 others like this.
  29. rockable
    rockable
    I wish I had access to that punch press. I always end up cutting them out with snips.
  30. 33Doll
    33Doll
    Man time flies!
    It’s been almost a month since I’ve worked on the 33!
    The wife’s getting sick of me out in the garage all the time so I had to stop and do some honeydews!!!
    Looks like there’s a lot more too!
    I’m retiring in 5 1/2 years and I’m gonna leave this godforsaken state of California and go to some other state and not tell them where I’m from!!!
    Don’t worry if I come to your state , I’m not one of those lefties. I’m an old-school Northern Californian like the Hank Junior song says!!!
    Anyway we got 25 years of **** we need to get rid of so we don’t drag it with us across country!!!!
    Back to the doll!!!
    Got the body all stripped of paint finally! Just got a hand- sand it, to smooth it out!
    Got most of the underneath of the floorboard cleaned up just got a finish that tomorrow, DC05431A-2F28-4F4C-9B5D-50228CF76CCD.jpeg FDBC6327-91E9-4BFF-963F-DB060F1F7A29.jpeg 642AA32D-7FC0-408B-88C3-9A887993034F.jpeg 8EDF59D6-FA20-48AA-9AA5-9F67A8BE2F6A.jpeg DC81F71B-2C99-43DF-A4AD-F6FD578E8B6F.jpeg 2B1912BD-EAFA-4FD7-93F3-60E78B515014.jpeg and then the inside and I'll start to weld the holes up then I can fix the dings in the body.
    Then start coating the inside and the underneath!
    Won't be long before I get the body back on!!!
