Projects 1936 Chevy truck build thread
Discussion in 'The Hokey Ass Message Board' started by skippycraig, Dec 26, 2011.
  1. skippycraig
    skippycraig
    from Washington
    Bought some steel floor pans from eray fit OK but will make for a starting point. Need to push pedal area out a little and make a tunnel still.
  2. Diggin' the white wheel and shift knob
  3. pila38
    pila38
    I'm in love with this truck, it just looks right. Congrats on the first drive!
    nunattax likes this.
  4. Spoonman34
    Spoonman34
    Nice ride Reading this thread helps motivate me to get back working on my 35 tall cab.
  5. dd2492
    dd2492
    from michigan
    Your truck looks great been workin on my 36 for 3 years was wondering what size tires and rims you used they look perfect.:D
  6. akinser
    akinser
    from lndiana
    Nice truck.I joined this forum when I saw what you were doing.
    I'm just starting a build on my 36" and need the front fender supports. I'm trying to gather all my parts. It would be great if I could get the 37' door pillar and cowl metal also. Anybody got a few parts laying around?
  7. Scotts Enterprises
    Scotts Enterprises
    How's the project going Skippy!
  8. TMoney
    TMoney
    Hey man, interested in your engine for sale. It won't let me message you because you have too many saved messages. PM me your info and I will give you a call.
  9. roncravens
    roncravens
    Did you own a 1954 station wagon that was sold in 2009 I think I may have purchased that car looking for some info would like to contact you email cravensd@twc.com
  10. mjhartz87
    mjhartz87
    from Conroe TX
    hey skippy love the truck. im currently working on a 36 low cab and i was wondering if you still have dimensions for setting the radior perch of your cross member. im using a 37 ch***is so i have had to alter some things and i am close but not spot on.. i have some pictures for you to somewhat look at on a thread i started. any help would be greatly apreciated!!
    http://www.jalopyjournal.com/forum/showthread.php?p=9655556#post9655556
  11. nitrohonkey
    nitrohonkey
    Love your truck! Any chance you have pictures of how you mounted the caravan seat to your riser. I am building a 38 Chevy pickup presently...where are you located in WA?
  12. Król
    Król
    Great build! Just read your whole tread. I just started a 36 Chevy low cab build myself love these trucks. I'm using a slightly warmed over 250 I6, T5, S10 Blazer rear end. I plan to use a dropped straight axle. Just the inspiration I needed. What brake, clutch pedal ***y. are you using?
  13. I know this is a extremely old post. I'm looking for info on what's involved with modifying the floor board and firewall in a 36 chevy truck low cab. Any info would be appreciated.
  14. KJSR
    KJSR
    from Utah
    Good morning. It has been a while since I did the modification but it was really just removing the old firewall, making and installing a new flat firewall, making a new floor that was flat all the way to the new firewall, making and installing closeouts for the trans. All of this was done with the cab off. I will send you a conversation to see if you have any additional questions.......
  15. Skippycraig1
    Skippycraig1
    Hey I’m back. This is Skippycraig that built this truck. I have long since sold the truck but going thru my shed I realized I have a really nice top for the earlier 34-35 boxy trucks I would give anyone that can use it. Unfortunately I can’t get into the Skippycraig account so I’m Skippycraig1 now.
    swade41 likes this.
  16. ronzmtrwrx
    ronzmtrwrx
    I see you have been away from here since 2015. Just FYI, There is a forum now called Pay it Forward or something like that where you could post about giving that roof away. Also, there is now an Off topic forum that will let later model stuff as well as independent front suspensions slide. I was surprised that no one called you out about that on your original build thread. :cool: That was a good looking truck btw.
  17. Skippycraig1
    Skippycraig1
    I’m a lot older and wiser now, I think that since Chevrolets have factory parallel leaf springs the crowd gave me a p*** on the Fatman crossmember. I’m building a model a coupe someone cut the roof off so I’m expecting some non fan mail but it’s a traditional build with wishbones and dropped axle so hope I’m ok. .
    ronzmtrwrx likes this.
  18. Skippycraig1
    Skippycraig1
    Hey buddy I’m back.
