Projects 27T Modified (All Ford By Ford)
Discussion in 'The Hokey Ass Message Board' started by 55willys, Jul 14, 2021.
  1. Dave G in Gansevoort
    from Upstate NY
    Nice setup! Now I'm going to have to get a brake lathe. It never ends...
  2. 55willys
    55willys
    Got mine at the local tire shop. He had two, one set up for disc and the other for drum. Bought both with all the adapters for $150. They just started taking their stuff across the street to the auto parts store because it was cheaper and easier than doing it themselves.
    Big mike 1968 and loudbang like this.
  3. 55willys
    55willys
    Cut a junk brake rotor off and bolted the first wheel to it. Almost got it cut apart when something happened to the wiring or the motor on my brake lathe. I will look into it later and figure it out but for now this is what I have. 16287831469832421784944202795306.jpg 16287836355252324472979608679250.jpg 16287836578866347776086583427378.jpg 16287838051172559180244858580672.jpg
  4. 55willys
    55willys
    I am looking at hood options. I have a stock 27 T hood for measurements. The hood needs to be lengthen 5-1/4" and I want it to come down to the top of the frame rail. I have been looking at using a model A hood but even the 30-31 is about an inch too short. Thinking about just forming a hood from aluminum sheet. Not sure on weather to make a 3 or 4 piece hood. I was thinking about using woven wire mesh in the sides rather than louvers. The other area to look at is how to latch the hood. Looking for ideas and options. 16293307720104424592268932214267.jpg 162933081130879148381095390475.jpg
    oliver westlund and loudbang like this.
  5. 55willys
    55willys
    Here it is with the grill shell in the proper location. 16293318857449049885595719260488.jpg 16293319077104831097441071453648.jpg
    Randall, Lil'Alb, brEad and 3 others like this.
  6. A Boner
    A Boner
    Cool project...keep the pics coming!
  7. Big mike 1968
    Big mike 1968
    Great start following.
  8. Dave G in Gansevoort
    from Upstate NY
    In my opinion for what it's worth, I like it and can imagine the hood that much longer. 3 pieces and how about leather straps and buckles
    brEad, loudbang and 55willys like this.
  9. 55willys
    55willys
    I think that I have decided to make the hood out of aluminum. I am pretty sure I will use stainless woven wire mesh in the sides instead of louvers. Contemplating running the exhaust out through the side panel and splitting the side panel above and below similar to a Duesenberg SJ supercharged car has.
    I am going to run naturally aspirated for now but have a turbocharged manifold and a pair of 97 carbs to go on it. This would require a hood top change because they will stick out the top. The turbocharged manifold also dumps out on the driver's side instead of the p***enger side so pretty much would have to remake all of the hood and sides at that point.
    I am thinking that a 3 piece hood would be better if the carbs come through so I might as well start with that design. I was thinking about placing a square tube bar down each side to attach the tops of the side panels to and use 28-29 hood latches bolted to the frame at the bottom.
    I could use a Dan Fink hood latch kit for the top although that wouldn't be as traditional as I would like. I was also thinking a spring loaded rod with a knob out through the top of the side panel might work as well. The hood top could pivot open either way or be lifted straight off. The side panels can be removed separately. I am also thinking about using 26-27 T hood latches at the bottom.
    Any thoughts on these ideas are welcome.
    The first pic is of model A hood latches and I prefer the 3 bolt design.
    The second picture is model T hood latches and I prefer the middle one in br*** and the br*** hood clips. 16294072352902486644628161950253.jpg 16294072902795867921292885299083.jpg
  10. 55willys
    55willys
    The hood strap kit is also an option but I don't prefer it. 16294075527532636009690770329682.jpg
    loudbang and AndersF like this.
  11. Dangerousdan
    Dangerousdan
    from Arizona
    Great start . Looking forward to the progress. thanks
  12. 55willys
    55willys
    Got one wheel cut apart and second one cut but not separated. After cutting the welds in the brake lathe I had to heat the rim with a torch to expand it and beat the center out with a big hammer. Looks like I will have to remove the band off the center. 16294278126716961023496362117597.jpg 16294278744324418573881226027894.jpg
  13. Marty Strode
    Marty Strode
  14. 55willys
    55willys
    Thanks Marty, looks great.
  15. The aluminium hood is 15" over stock length and is fastened by leather straps on spring hooks
    Yes... I did build it in there
    Lil'Alb, brEad, Stogy and 3 others like this.
  16. 55willys
    55willys
  17. 55willys
    55willys
    Does anyone have the dimensions of a 32 Ford roadster windshield? I'm pretty set on a fold down windshield. I think that I could use 2" chop 32 posts and mounts with a lower 27 T windshield frame. Not sure if the 32 lower stanchions will fit the 27 T cowl. The other option is to modify the 27 T posts to accept the 32 foldable posts and use the 27 T windshield. 16294462198953506635307481916755.jpg 16294463204227491534357990015026.jpg
  18. Marty Strode
    Marty Strode
    Here is another one, using stainless, twist and fold down latches. IMG_0347.JPG
  19. Dave G in Gansevoort
    from Upstate NY
    I personally really like the looks of the loooong hoods. Kind of reminds me of Lady Gaga... I personally like her nose!
  20. 55willys
    55willys
    Looking at another hood option is using the 28-29 hood sides and grill shell. This still lines up with the outside frame rails but gets a bit tight to the water pump and doesn't fit well with the front spring. The grill shell will of course have to be shortened, this is just to get a visual. 16294904913026623456990553006671.jpg 16294905319812351898379402151509.jpg 16294905622722011602804872188592.jpg
  21. 55willys
    55willys
    16295683131468791999985314536526.jpg 16295685084477366555057152153107.jpg Chucked up the wide five hub in the brake lathe and turned down the center. I cut the back side even with the edge of the center so when I weld it it will not rely on the rivets.
    oliver westlund, loudbang and AndersF like this.
  22. 55willys
    55willys
    Flipped it around in the brake lathe and cut the front side. Had to use a brake drum damper on it to keep down the chatter. It ended up being about 7/8" wide and I will be able to weld the front side of the spokes to the rim. The rivets are still in place holding the center on. 16295706970693664202845218902953.jpg 16295707214288291998063869515285.jpg
  23. 55willys
    55willys
    16295734773715932496632834909706.jpg 16295735328155293476460277689711.jpg 16295736757856579414732624674585.jpg Used my rubber headed mallet to tap the rim on the center. Hand turned the rim and adjusted it until the cutter was hitting in multiple places. If anyone has had experience with rims they are close but not perfect from the factory.
  24. 55willys
    55willys
    I'm liking the look of the wider wheels but am not sure about the ring of the old rim between the spokes. I could cut it out between the spokes or find a way to hide the edge. I need that little bit of rim to make the center tight to the hoop it's about 1/16" thick. I will post some pics Monday.
    Lil'Alb and loudbang like this.
  25. dirt t
    dirt t
    I'll be following.
    Dirt t
  26. 55willys
    55willys
    Getting the modified off the cart and on the ground. 16297437723128029095909431981239.jpg 16297438081255178407464799801725.jpg 16297438278736957335570813272485.jpg 1629743860106932773395750439840.jpg
  27. 55willys
    55willys
    The edge that I am not liking. Thinking about cutting it out between the spokes and tig welding it front and rear at the spoke. Any thoughts on that? 16297504896723709106300783655638.jpg 16297505280314465480325951966224.jpg
  28. Dave G in Gansevoort
    from Upstate NY
    Imho it looks like you could weld all the way around the band and grind it smooth on the outside so that it looks like it is actually part of the wheel hoop. Sort of trick the eye into seeing it as smooth. Then a second bead at each spoketo further trick the eye and effect a strong connection between the center and the hoop.
    Great job. As I said before now to get me a brake lathe...
  29. ratfink56
    ratfink56
    Hit it with some rattle can black and see how it looks?
  30. brading
    brading
    I am with Dave on this one, what he suggests the wheels would be strong and look good.
    WalkerMD and loudbang like this.
