Hot Rods Front Cycle Fender Brackets?
Discussion in 'The Hokey Ass Message Board' started by louder50, Aug 19, 2021.
  1. louder50
    louder50
    from Michigan
    I have read through days of posts about cycle fenders and it appears the use of round bracket material seems to be the least prone to cracking and breaking. My question is what is stronger.....solid round steel or DOM steel tubing? And should the tubing be cut and welded at the bends to strengthen them? Im copying the style shown here....or trying to. 06122013e.jpg
    ratrodrodder, The37Kid and Stogy like this.
  2. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Solid would be stronger. If tubing, yes for sure weld the ends shut.
    Stogy likes this.
  3. AVater
    AVater
    Having broken mine a few times, I encourage you to build them stronger than you think. Why? These fenders feel every bump along the way. Unlike "regular" fenders mounted to a ch***is, these move with every move of the front wheels and feel every jolt along the way. The picture below was the first edition:
    Needless to say, they broke on me a few times.
    The photo below shows the third or present version. Note the gussets and addition of the circular brace (like your example).
    Something you can't see is the steel under the fender that the supports are welded to. Yes, this connection broke once too on me. My suggestion in your build would be to mount the braces on the fender end to something more substantial than the fender itself.
    Once more--it's tough out there for these fenders. IMHO the right side has it worse.
  4. louder50
    louder50
    from Michigan
    AVater your post was one I studied a lot. Did you use solid or DOM tubing? I was thinking 5/8" diameter and fabbing some internal brackets inside the fenders to attach them to.
    Stogy likes this.
  5. gnichols
    gnichols
    from Tampa, FL
    I hope this thread goes for 10 pages. So much to learn, not much ever published on the topic.
    A Boner, dana barlow, Stogy and 3 others like this.
  6. pitman
    pitman
    5/8ths DOM works and offers 3/16" plate mount flanges (3), a place to weld both sides. Never had a failure. Make one continous tube bracket that begins at outer edge (inside) of lower rear of fender (4 or 8 o'clock) then stand off the tire sidewall as you bend it. Weld to rear lower plate. Pickup the rear hole, then forward and Up, around lower front hole, capture top hole plate, then standoff tire sidewall, p*** over top of tread (clear it), fasten fender to the tread tube-extended portions.
    Stogy likes this.
  7. AngleDrive
    AngleDrive
    from Florida
    4130 aircraft tubing, if you have to weld do it with a tig. Flatten area that mounts to fender and backing plate. Make a template first out of mild steel. I would bolt it to fender and baking plate. 5/8ths outside diameter. Then have it chromed. :)
    Stogy and 55willys like this.
  8. xlr8
    xlr8
    from Idaho
    It seems like solid rod would be stronger but actually tubing seems to be able to withstand the vibration better. As others have already mentioned, flatten the end of the tubing in a vise or press instead of trying to weld an end on, a welded end will never stay.
    Stogy and pitman like this.
  9. louder50
    louder50
    from Michigan
    Any chance you have a picture of this?
    Stogy likes this.
  10. The37Kid
    The37Kid
    I read about using old rifle barrels, finding a matching pair may be a problem. Bob
    Stogy likes this.
  11. pitman
    pitman
    If you look to drivers side, along the front axle, from the ctr spring perch. The Ford spindle bolt holes you want to use, are at 8, 4 and 2 o'clock. Rear of fender mounts off the horizontal tube from 8 o'clock.
    The top of fender mounts from the ~ vertical end of tube, which p***es by the 2 o'clock bolt/flange. Wish I had a detail pic, car was sold 6 years ago.
    Stogy likes this.
  12. buford36
    buford36
    from Maine
  13. ratrodrodder
    ratrodrodder
    from Boston
    Following along as I've had this same question myself. I've looked at nearly ever car with cycle fenders at hot rod shows that I could find and none of them seemed to do it exactly the same. These photos and explanations are great!
    Keep 'em coming!
    Stogy and The37Kid like this.
  14. Rickybop
    Rickybop
    I like bobbed rear fenders and cycle type front fenders.
    But I know the cycle type fenders can be a problem. And the main problem seems to be that the brackets are only on one side. It would change the clean look, but I wonder if anybody has maybe attached outboard brackets to the spindle. Is that feasible?
    Stogy likes this.
  15. COCONUTS
    COCONUTS
    I never had any luck with these brackets or with welding side pipes.
    Stogy likes this.
  16. AVater
    AVater
    I used solid rod. Looks to be 7/16” but with paint etc could be 3/8”. Frankly the rod was something I had in the garage. If I did it again, would use thicker or perhaps DOM as suggested. Here’s another thought: old Ford bumper jack handles are 1/2” may be hardened?
    Stogy likes this.
  17. jaracer
    jaracer
    Ever seen a race car ch***is built out of solid rod? Tubing is always stronger if you are comparing apples to apples.
    Stogy likes this.
  18. I used bicycle forks on the basis that they can support a 200lb man over rough ground they can support my mudguards.
    Bolted at four points and gusseted. Rubber between the support and the guard to reduce vibration.
    Tim, Stogy, kidcampbell71 and 7 others like this.
  19. ClarkH
    ClarkH
    Somebody apparently did it with my old speedster, back in the day. Here are the cycle fenders that came with it, front (left) and rear. Outer supports connect to a spindle nut.
    Thing is, the castle nut spins freely inside the support, but there's no provision for a bearing. So apparently it just rode metal-on-metal? Seems crazy. Perhaps they were bolted on for show and removed for extended driving?
    Anyway, not sure this helps the converstation. I'm just saying, it's been done.
    Stogy, kidcampbell71 and ratrodrodder like this.
  20. japchris
    japchris
    from England
  21. Dave G in Gansevoort
    from Upstate NY
    Now this is interesting. And maybe to take it further down the bicycle parts path, maybe a proper silver bronze braze joint for any fabricated joints. After all steel tube bicycles are brazed and they take tremendous loads and beatings when ridden.
    Stogy and ratrodrodder like this.
  22. Blake 27
    Blake 27
    Tim, Stogy, 300racr and 9 others like this.
  23. The37Kid
    The37Kid
    Like that idea a lot, I can see in & out brake cooling louvers punched in that. Bob
    Stogy, Donut Dave and gnichols like this.
  24. Dave G in Gansevoort
    from Upstate NY
    What gage is the support steel? This looks really strong.
    Stogy likes this.
  25. bowie
    bowie
    Back about 1990 , after running fenderless for about 10 years ; I was thinking of building a pair from a ‘36 tire cover. In talking about them with big Pete at Carlisle , he said he had just the thing for me. He said this pair ran on a Lehigh valley’32 thru the ‘50’s and ‘60’s and had never cracked. I have run them for about 30 years, still no problems…never did get around to painting them . Edit:they are made from tubing : AF53A386-339E-4655-8C3D-9109C14B250B.jpeg EF4688AA-2B4F-4AE6-9746-6ECFF6AD2C1E.jpeg 8F0D2FEE-60B4-45C0-8F32-BF4B1A2525E8.jpeg
    coupe33, Stogy, cactus1 and 5 others like this.
  26. fiftyv8
    fiftyv8
    from CO & WA
    I must be a whimp as I used much heavier material and had most of it laser cut out as to minimise bends.
    Sorry that pic's are not really taken to focus acurately on the brackets but I figure you will get the idea after you stop laughing.
    I just did not want to be dropping a fender on the highway or worse...
    Hutkikz, RICH B and Stogy like this.
  27. gnichols
    gnichols
    from Tampa, FL
    Old school sporty car. The mounts are not so pretty, but the fenders don't add any weight to the suspension. Sorry I don't know the make or year of this cool little racer. Could be a special, just don't know. The fender style reminds me of an Allard or Kurtis from the 1950s.
    Stogy, cactus1 and kidcampbell71 like this.
  28. gnichols
    gnichols
    from Tampa, FL
    A car from down under, or England possibly? Pix from FB. I had an idea to mount rears for my truck like these on the axle ends, but never got around to them.
    241427138_6792778880748075_715184158100833630_n.jpg 241434849_6792779187414711_1131580944527820357_n.jpg
  29. GordonC
    GordonC
    I built a pair out of a spare tire ring I bought for $20! Welded nuts to the backing plate and made steel rod mounts to bolt them on. I also welded flat steel strap inside the fenders for the rod to weld to instead of just the thin sheet metal of the ring. Haven't run it a whole lot but did notice they do flop around some so am going to add some extra supports to them shortly.
    Stogy likes this.
  30. PhredH
    PhredH
    In no particular order of fabrication. Used Ford steering shaft for tubing and 16 ga steel sides
    One more way to skin that cat. 14EEB268-0D00-4815-86E8-511C381E6405.jpeg AC2D21FA-21CD-40EB-A1A4-3E8E57E94328.jpeg 5C582BEF-6D5D-44FC-9E02-D32C667A48A8.jpeg 84D092BE-0823-4EA1-9912-29CF069312F7.jpeg D146E624-6618-4FC7-9FE9-FB29762B16DA.jpeg CA15AF0D-85D2-48F9-B4DD-7D03BC852292.jpeg D2FD0E03-0307-453F-A5BD-71D5AACDE106.jpeg 4A17C9E1-C42F-47D5-A134-2C04BD056981.jpeg 992839BE-72DD-46C6-8C0D-9C9B1F18135B.jpeg 6EA6F1D6-9112-4D77-96EA-9BC6CFDB6F69.jpeg B42DE1EF-86F7-4767-AEFF-69633B2CF10E.jpeg E349CFBD-7C8D-4434-938D-4BD358948C5B.jpeg 14EEB268-0D00-4815-86E8-511C381E6405.jpeg AC2D21FA-21CD-40EB-A1A4-3E8E57E94328.jpeg 5C582BEF-6D5D-44FC-9E02-D32C667A48A8.jpeg 84D092BE-0823-4EA1-9912-29CF069312F7.jpeg D146E624-6618-4FC7-9FE9-FB29762B16DA.jpeg CA15AF0D-85D2-48F9-B4DD-7D03BC852292.jpeg D2FD0E03-0307-453F-A5BD-71D5AACDE106.jpeg 4A17C9E1-C42F-47D5-A134-2C04BD056981.jpeg 992839BE-72DD-46C6-8C0D-9C9B1F18135B.jpeg 6EA6F1D6-9112-4D77-96EA-9BC6CFDB6F69.jpeg B42DE1EF-86F7-4767-AEFF-69633B2CF10E.jpeg E349CFBD-7C8D-4434-938D-4BD358948C5B.jpeg 14EEB268-0D00-4815-86E8-511C381E6405.jpeg AC2D21FA-21CD-40EB-A1A4-3E8E57E94328.jpeg AC2D21FA-21CD-40EB-A1A4-3E8E57E94328.jpeg 5C582BEF-6D5D-44FC-9E02-D32C667A48A8.jpeg 84D092BE-0823-4EA1-9912-29CF069312F7.jpeg D146E624-6618-4FC7-9FE9-FB29762B16DA.jpeg CA15AF0D-85D2-48F9-B4DD-7D03BC852292.jpeg D2FD0E03-0307-453F-A5BD-71D5AACDE106.jpeg 4A17C9E1-C42F-47D5-A134-2C04BD056981.jpeg 992839BE-72DD-46C6-8C0D-9C9B1F18135B.jpeg 6EA6F1D6-9112-4D77-96EA-9BC6CFDB6F69.jpeg B42DE1EF-86F7-4767-AEFF-69633B2CF10E.jpeg E349CFBD-7C8D-4434-938D-4BD358948C5B.jpeg 14EEB268-0D00-4815-86E8-511C381E6405.jpeg
