  1. Unclebrad
    Unclebrad
    Doing a search for the top you are wanting, I got confused pretty fast. Is this the top you have in mind?
  2. Sancho
    Sancho
    Or are you talking about this top?
  3. Stan Back
    Stan Back
    Is this the top you have in mind? Well, no. It looks like that Hardtop roof is as long as the 2-Door. I'm talking about a roof like the difference of a 50 Ford Coupe and a 50 Ford 2-Door Sedan. It looks like they both used the same decklid, but the length of panel between the front of the decklid and the rear window was far greater on the Coupes. I always thought the Coupe was far better looking, and would the same treatment go good on a 53 or 54 Plymouth or Dodge.
    I ain't thinking of cutting this one up just to find out.
  4. 7berkmerc
    7berkmerc
    Maybe this helps to identify the right version.......[​IMG]
    OahuEli, rod1 and loudbang like this.
  5. 7berkmerc
    7berkmerc
  6. themoose
    themoose
    @Stan Back
    Here's how it might look still using the rear window...
  7. Squablow
    Squablow
    I figure if Plymouth did make a business coupe, it'd be one of these two ways. Either with a shorter quarter window and longer tulip panel like below
    Or with a 4 door front door but the same size quarter window, which would have been less tooling for them and created a shorter roof, like this.
    Here's the original to compare
    N.Ozols, themoose, 7berkmerc and 2 others like this.
  8. 7berkmerc
    7berkmerc
    So is the car you are thinking of modifying is a '54 Plaza Business Coupe as shown in the photo? It seems that that the car picture was the shortest roof/longest decklid made. I get what you are saying about the Plaza Club Sedan and the rear quarter window difference. It looks like the Savoy Club Coupe shared the same rear quarter window as the Plaza Business Coupe. Here is an image of the an even shorter roof version. I removed the Savoy chrome side moulding to make it more Plaza-esque... :)
    loudbang and Peanut 1959 like this.
  9. Stan Back
    Stan Back
    I think you guys all figured out what I was looking for. Plymouth took the cheap way out. No back seat, no roll-down rear windows, no rear arm rests (no seat), etc. When I took this one apart there was a receipt for about $31.00 for the stainless that the dealer added around the lower part of the roof. Plus they also painted the cardboard side panels a dark green to match the factory front ones -- and added some sort of seat. It had the new (to Plymouth) TorqueFlight which I understand got a different compression-ratio engine. Sorta a Pro Stocker (sure!).
    It doesn't look much better with the shorter roof, but I took care of the motor with a 354" Hemi. Thanx to you all for the exercise. (Still like the look of the 49-50 Ford coupes better than the 2-doors.)
    loudbang and Unclebrad like this.
  10. 7berkmerc
    7berkmerc
    Plaza_1.0.jpg I think a shortened fastback roofline is in order...... :)
  11. rusty1
    rusty1
    ...I think the orig .Plymouth was a perfect design,...just my 2 cents, which ain't much, love to have one or a wagon.
    jimmy six and '28phonebooth like this.
  12. Rot 'n Kustom
    Rot 'n Kustom
    Here's one I did back in 2017. Took a Ford roof and transplanted it to a Plymouth.
    Easy enough in pixels, much harder in real life!
  13. tasvalowna
    tasvalowna
    from tasmania
    Hi , I’m thinking a colour change on my 48 . Maybe cream for the body and the roof either still in green or the roof black with the body cream , can anyone help please
  14. tasvalowna
    tasvalowna
    from tasmania
    Looks like an Instagram link doesn’t work , do I need a photo hosting web address ?
  15. themoose
    themoose
    Just copy the photo to your device and then use the upload file ****on when you post a reply which will allow you to locate the file on your device and post it directly here.
  16. jnaki
    jnaki
    Hello,
    No need for any outside photo hosting web or company. Just save it to your own device folders or laptop/desktop computer files.
    1. Send your photo to your tablet photo folder as a jpeg. or to a laptop/desktop computer.
    2. Once the photo is located on a file folder, then open it up to check the focus and
    composition. A blurry photo ruins everything, so use your laptop/desktop photo
    program to get the right size for a good in focus photo.
    3. The composition is important as it is the car being shown, not people, houses or
    trees/gr***.
    4. Once the photo is finished, then copy it to a Word Do***ent to place is correctly. Once
    pasted, copy it for insertion on this reply page. there is no need to hit the upload tab,
    although that works, too.
    5. Once pasted, before you post it, make your adjustments. If it has some errors, you can
    always delete it and try again. no need to post the largest photo you can. some phones
    create large photos, so you can edit them before posting.
    Jnaki
    Good Luck...
    Peanut 1959 likes this.
  17. Scooterville
    Scooterville
    Hello, someone please do a rendering of this 56 in all black. One with black steelies with the chrome baby moons and with skirts, and another like it but with black wall tires no skirts. Thanks!
    83E31533-032A-44D9-B974-ED856502D0BC.jpeg E7CB6B42-911C-49CD-BBAF-36A7D0474342.jpeg
  18. 7berkmerc
    7berkmerc
  19. Scooterville
    Scooterville
  20. themoose
    themoose
    @Scooterville
    Just in case you want to see it in gloss black...
  21. Scooterville
    Scooterville
    lothiandon1940, themoose and loudbang like this.
  22. Scooterville
    Scooterville
    Ok, so I had to sell my 39 Deluxe Coupe to settle some things BUT I was able to bounce back by getting another 39 Deluxe Sedan this time. This one has a 48 Flathead v8 with some goodies and a C4 auto trans/Granada rear, 56 F100 brakes.
    The color is a Ford Medium Wedgewood Blue. I plan to change the wheel color for now but not sure what do go with. I’m also not sure if I wanna stick with Black walls. Down the road I’m thinking halibrand style wheels big n littles with black wall tires. Please show me your ideas. These are the only pics I have so far since it’s not in my possession yet. Thanks so much!
    D5C246BF-9935-4C41-A2BA-CA48E37305A2.jpeg DE946A78-6E85-4CC1-BEB8-0455289050EC.jpeg B43C787A-69EA-4119-A2A4-D1CA44D331E6.jpeg 7E382CBE-387E-4321-B727-91E64205D1B9.jpeg
  23. verde742
    verde742
    THE BEST LOOK EVER !!!!! IMO[​IMG]
  24. Flamed48
    Flamed48
    Could the wheels on the camaro be swapped over to the 55 please and thank you
  25. Can someone photo shop a set of craters on my car and a set of Ford steel wheels with caps
    I want to do steelies and caps but found a set of cragars with rubber for next to nothing 977DBF84-2549-4439-9451-15E1692FE360.jpeg 4A40B68C-5FD3-4AE1-95A1-09E00E49A8B9.jpeg C3AEB101-B495-43A0-ADD5-7D0DEECE1041.jpeg
  26. themoose
    themoose
    kidcampbell71 and loudbang like this.
  27. Thanks moose
  28. verde742
    verde742
    They have a four door '39 Merc at Squeeg's Kustoms, they are making it into a tudor, it IS FANTASTIC...
    VANDENPLAS and loudbang like this.
  29. bobj49f2
    bobj49f2
    I did this some years back. If you search "Chero" you'll find discussions about what a great truck this is and the person who built it has some skill. Sad to say I built it but only in my mind. image001.jpg
  30. Slopok
    Slopok
    Come on man, everyone knows craters only look good on Dodges! ;)
    loudbang and VANDENPLAS like this.
