Technical Barn find 57 vette.
Discussion in 'The Hokey Ass Message Board' started by racer-x, Jul 24, 2021.
  1. DDDenny
    I don't think "project creep" is even in Brians' vocabulary!
    By the way, how is the Chevelle coming along?
    Stogy likes this.
  2. I was already planning new shackles and bushings. If it sits too low i will put some springs on it. I dont do things part way. If it needs fixing i will fix it.
    vtx1800, catdad49, Algoma56 and 10 others like this.
  3. The chevelle is going great. Alot of progress has been made. The 427 block might be ready to pick up at the end of the week. I might put the short block together next weekend. I have the new trunk and full floor pieces. Instead of doing drag week i will spend the time off putting the floor in. I hope to have the engine in the car running by thanksgiving. The body work will be done this winter. Hopefully the body will go back onto the frame in the spring.
    catdad49, Stogy, loudbang and 4 others like this.
  4. Jones St.
    Jones St.
    loudbang and racer-x like this.
  5. Utahvette
    Utahvette
    Your transmission tunnel piece is backwards in this picture. The flaps go below and alongside the center glove box.
  6. Thanks for the tip.
  7. wheeldog57
    wheeldog57
    This is a bit of a hack but I have stuck a golf tee into a hole, broken it off, then thread the screw into it.
    I have only done this for elongated or beat up holes in metal, not fibergl***. Good luck
    racer-x, Stogy, Thor1 and 1 other person like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    These work great
    3C3B8F56-91DE-4CF3-B70D-2417DEAF277D.jpeg 8D26A0DE-D449-4C90-AD8A-A0C24DC4E035.jpeg
    WC145, catdad49, e1956v and 4 others like this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
  10. rumblegutz
    rumblegutz
    The most appropriate repair is to re-fibergl*** the enlarged hole. Then drill a new properly sized hole. I have used as a temporary repair what I have possibly mistakenly called barrel nuts possibly also called tubular retainer nuts. See photo.
  11. MCjim
    MCjim
    from soCal
    ...and that crossmember the shackles mount to are notorious for rotting from the inside out...ask me how I know.
    Stogy, Thor1, loudbang and 1 other person like this.
  12. Dave Gray
    Dave Gray
    loudbang, Stogy, 427 sleeper and 2 others like this.
  13. There are several good suggestions to fix the stripped out holes. I have a few sill plate holes and all four holes that hold the plate around the shift handle. Nothing will show.
    As far as the frame goes it looks nasty but its actually verr solid.
  14. Todays fun involved flipping the shackles. Silly me thought i could just unbolt the shackles and somehow get the spring over the frame. That idea didnt work. In the high heat and humidity i kept going. The springs needed to be completely unbolted. With the car on the lift and a pair of screw jacks for support the job is mostly done. New shackles and bushings are on the way. I will switch them out when they arrive. The car looks much better. The rear of the car dropped several inches. It sits level. It was cool to see all the bolts were original. I cleaned them up and re installed them all but one that broke.
    I found out the car was bought originally in northern Illinois. It raced at dragstrips in the area. That would explain the stance and old eelco fuel block. 20210825_183131.jpg 20210825_183150.jpg 20210825_183215.jpg 20210825_183230.jpg
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    Much better.... I bet the limit straps fit now too
    WC145, catdad49, Thor1 and 5 others like this.
  16. Stogy
    Stogy
    That looks fantastic @racer-x...that will be a fun little ride...
  17. Fordors
    Fordors
    @racer-x , is there any chance the car was sold by Doane Chevrolet in Dundee, IL? Doane had some connections in Detroit, maybe even with Duntov and they tuned and race prepped Corvettes.
  18. I need to see if the straps fit while its on the ground. On the lift with the rear end supported they didnt.
    I couldnt get the exact dealership. I can ask more question when i see him next.
  19. Is this the original stance? The car looks higher in the front now. Should it be level? Or is it just how the body is shaped that it looks like that?
    Thor1 and loudbang like this.
  20. 20210825_192901.jpg The straps fit with the full weight on the tires.
    WC145, 61Cruiser, catdad49 and 11 others like this.
  21. DFH-GMC
    DFH-GMC
    from Texas
    0591B712-4638-472F-8D22-7C28035FF446.jpeg This is how mine sits without engine or trans.
    Yours looks good
    WC145, bowie, catdad49 and 4 others like this.
  22. Stogy
    Stogy
  23. noboD
    noboD
    The ***embly manual should give you measurements to certain things from the floor.
  24. I have the manual. I will take a look. It doesnt look too far off as is.
    Thor1, loudbang and Stogy like this.
  25. Dick Stevens
    Dick Stevens
    Looks level to me, you have to look at the bottom of the body, not the curved tops of the fenders and quarter panels.
    Thor1, Stogy, loudbang and 1 other person like this.
  26. ClayMart
    ClayMart
  27. loudbang
    Man you work FAST and GOOD. Looks 100% better already :)
    racer-x, Thor1, guthriesmith and 2 others like this.
  28. jimdillon
    jimdillon
    Brian your efforts have paid off so far-looks so much better. I am sure you will make it even nicer. Once you start driving it I believe you will like the way it drives, keeping in mind when it was built.
    catdad49, Torkwrench, Stogy and 3 others like this.
  29. A Boner
    A Boner
    Take a tooth pic and smear some JBWeld/epoxy/ect. around the sides of the enlarged holes. Let it dry real good...then install screws!
    Stogy, Thor1, racer-x and 2 others like this.
  30. Dennis D
    Dennis D
    Looking better every time you touch it!
