Customs 1936 Chrysler Airstream Engine Conversion
Discussion in 'The Hokey Ass Message Board' started by MFG, Aug 24, 2021.
  1. MFG
    MFG
    I have a 1936 Chrysler Airstream 4 door. Before I go any further with my car, can I put in a newer 318 motor and automatic transmission in using the original frame?
  2. harpo1313
    harpo1313
    from wareham,ma
  3. gene-koning
    gene-koning
    Yes, with modifications.
    The Airstream is a unibody car I believe. Probably going to need firewall and trans tunnel work, that 318 auto trans is a lot bigger then the original trans was. Gene
  4. MFG
    MFG
    This 1936 Chrysler Airstream has a full frame under it that’s in pretty good shape. It has a floor board with trans tunnel and fire wall. I have all of the body mount bolts removed . Just wanted to see if I could put a newer motor such as a 318 small block or maybe a newer straight 6 that would fit inside the engine compartment and I can close the side panels. If not I’ll get rid of the car
  5. MFG
    MFG
    Here is the current motor
  6. Rusty O'Toole
    Rusty O'Toole
    I know a guy who put a 340 in a 36 Plymouth so it should be possible. A Chev 350 fits easier. The problem is steering interference, the engine compartment is made for a narrow six cylinder. The Chev engine starter and exhaust manifold are located slightly different, giving more room.
    mitch 36 likes this.
  7. AirSTREAM has a frame, AirFLOW is unibody
    Hnstray, lemondana, Stan Back and 3 others like this.
  8. With the starter being on the driver side of a 318/360 might pose a steering problem along with the exhaust.. Now Dodge did also have factory center dump manifolds also that may help?
    Now the 318/360 is about 2 inches wider than a SBC..
  9. I do commend you for trying to keep it all DODGE though :):);)
    VANDENPLAS likes this.
  10. squirrel
    The A body (Dart, Valiant, etc) driver side manifold can help with steering/exhaust clearance. Still have to move the engine over a bit to the p*** side, which doesn't hurt anything as long as you keep it straight in the frame. The engine was offset pretty far on the A bodies, after all.
    Hamtown Al and gimpyshotrods like this.
  11. Torana68
    Torana68
    from Australia
    It wont be a bolt up "plug and play" deal, Hot rodding isnt that sort of thing, there wont be a Kit for it. Things will need to be modified and fabricate stuff. If you don't want to get this far into it, its not for you.
    X38 likes this.
  12. jimmy six
    jimmy six
    If your thinking inline. A 300 Ford is a great engine.. a friend has one in a 52 Hudson Hornet.
    Hnstray likes this.
  13. If you're thinking an inline 6 take a look at an AMC/Jeep engine/trans combo. Fairly compact, decent power, and a lot of aftermarket support.
  14. 302GMC
    302GMC
    from Idaho
    This is a Plymouth, the Chrysler should have at least as much room underhood. HPIM4059.JPG HPIM4060.JPG
  15. Rusty O'Toole
    Rusty O'Toole
    The newer type mini starter helps (318 - 360)
    firstinsteele and VANDENPLAS like this.
  16. earlymopar
    earlymopar
    There is even a smaller starter that works... Get one from a 2005-2008 Dodge Ram with a 5.7 and a MANUAL transmission (the upper one in the picture below). This is a coaxial (planetary) gear reduction design, not offset like the Chrysler and Nippondenso gear reduction ("Mini") starter designs. That's why the motor housing is directly in line with the starter drive axis, making the whole starter more compact.
    dwollam, Stan Back, 302GMC and 4 others like this.
  17. 55cad
    55cad
    MFG, did you end up keeping the car? I have a 36 Airstream and we put a slant six with an automatic in it. The rest is pretty much stock, unrestored. IMG_20220320_161005393_HDR.jpg IMG_20220320_161107257_HDR.jpg
    Hnstray and 302GMC like this.
