Hot Rods Dashboards Lets See Yours...........or someone's elses
Discussion in 'The Hokey Ass Message Board' started by ekimneirbo, Aug 30, 2021.
  1. ekimneirbo
    ekimneirbo
    Like to see pictures of what others have done for their dashboards.......:)
    dana barlow likes this.
  2. DDDenny
  3. rc57
    rc57
  4. nochop
    nochop
    from norcal
  5. HOTRODPRIMER
    HOTRODPRIMER
    '54 Ford dash removed and sandblasted then filled in the heat controls to even out the heat & air vents.
    I spent several hours with a pecking hammer making the couture's on each side flat for the placement of vents.
    Then went to work with a hole saw and Dremel tool.
    Next I wanted to eliminate the idiot lights and that necessitated the engine turned panel to be replaced and metal from the dash cut to insert gauges, I found a piece of engine turned aluminum at Speedway motors and I cut it to lay inside the original panel.
    What you see here is a poster board template, I transferred it to the aluminum insert.
    Next I dis***embled the speedometer housing, cleaned and repainted it.
    Then replaced the brittle & broken turn signal lens with green plastic from a lunch meat container top.
    I use a Jif peanut ****er red lid and used a leather crafting hole punch to use as a high beam indicator.
    This shows everything re***embled, I eliminated the original clock and moved the radio to clean up the insert, I also relocated the headlight switch & windshield wiper swatch to eather side if the steering column, that is where the air vents were originally located, they were relocated under the dash, never use them. HRP
  6. HOTRODPRIMER
    HOTRODPRIMER
  7. Dave Mc
    Dave Mc
  8. Dave Mc
    Dave Mc
  9. HOTRODPRIMER
    HOTRODPRIMER
    ekimneirbo and Dave Mc like this.
  10. 3quarter32
    3quarter32
  11. Sky Six
    Sky Six
    from Arizona
  12. Elcohaulic
    Elcohaulic
    Some old Pontiacs.. The Teal one was a 64 Grand Prix with a 421 Tri Power, 8 lug wheels, am/fm Reverb. What was truly rare on this car was the gl*** script in the dash board that read Grand Prix had a real long light bulb built in it. This was all factory. Till this day I have never seen another one.. Back when I owned this car I thought it was just another option on the heavily optioned Pontiac..
  13. Chicster
    Chicster
  14. catdad49
    catdad49
    My old pickup, cleaned up with dark brown camo paint and underdash a/c unit.
  15. catdad49
    catdad49
  16. willys36
    willys36
    Mysterion reproduction
    '36 Willys coupe 'g***er'
    '53 Chevy pickup
  17. Dean Lowe
    Dean Lowe
    Original works for me.
  18. JOHN H EDGE
    JOHN H EDGE
    5D3A28AF-084E-41D2-9BA0-8C60280CBC31.jpeg E33C504B-8ED0-4E07-8C20-7B0F9A2CD720.jpeg A89472FC-3A08-48D4-8172-0C68425D2E37.jpeg 8F39A2AE-51EC-4D8F-83FD-54AF65032721.jpeg 70065161-90E3-4160-8AE4-52BBE51F8131.jpeg 4D53BC21-F66B-4C4B-8549-B5E459B402D1.jpeg 231BDE8F-DFDC-41AC-BAC1-2A7785DCF0BD.jpeg FBAC7186-5B5B-4A6F-BF28-11E296930A70.jpeg Here a few out of our shop
  19. rc57
    rc57
    Just bringing these back to the top because there's some pretty cool stuff in there.
    ekimneirbo likes this.
  20. bobss396
    bobss396
    I just painted mine up, I had it out anyways. Hung some summit gauges under it, found some new paper gauge faces on eBay.
  21. topher5150
    topher5150
    This is the dash from my 47 Ford coupe. 42 Ford clock and speedo, I took a second speaker cover flipped it around and put it over the radio opening, and the steering wheel is from a 68 Thunderbird.
    mgtstumpy and ekimneirbo like this.
  22. seabeecmc
    seabeecmc
  23. 40FORDPU
    40FORDPU
    The black one is in my '39 Coupe, green one '40 p/u, and of course the last one my '40 convertible
  24. F-head
    F-head
  25. knucklenutz
    knucklenutz
  26. jimmy six
    jimmy six
    My sons 40 Chevrolet and my 56 Ford. 0B0B18F3-C09A-4D2A-A753-04E724196599.jpeg 2971E5A6-372B-4AC4-8876-048E29F4EF89.jpeg 7C3EC50A-8EBE-4085-8631-8D751DFD0C88.jpeg
  27. kabinenroller
    kabinenroller
    Modern compared to the previous posts but it is a modified dash. (Avatar)
  28. willys36
    willys36
    Oh, I forgot this one I built for my friend's '42 Willys pickup. Born of necessity, we had to install a firewall bump to fit the SBC and install Old Air A/C. And these tiny vehicles start with zero room to begin with!
  29. mikec4193
    mikec4193
    DSCN5492.JPG Just like it was in 1966...
  30. hemihotrod66
    hemihotrod66
