Technical 9 inch ford rear
Discussion in 'Traditional Hot Rods' started by coolieman, Aug 30, 2021.
  1. coolieman
    coolieman
    I have a brand new 9 inch center section 350 posi traction 28 spline . Bought from one of the big speed shop suppliers. I have put about 300 miles easy driving haven't got on it hard been taking it easy. Slight whine around town just started going out on the highway from 40 mph to 70 mph whineing louder has bad harmonic sound . I called them and they said drive it another 300 miles if it didn't go away I could send it back they would look at it. I video taped sound with my tablet . Would anyone be willing to listen to it and give me there option . I know its not right but I am scared to send it back and have them say they couldn't find anything wrong, by the way I am 74 years and don't know how many times I can pull this pumpkin out thanks,mike I can e- mail video
    Deuces and olscrounger like this.
  2. Flathead Dave
    Flathead Dave
    from So. Cal.
    Can you post the video here?
  3. squirrel
    Did you replace a different center section, that was not making noise? or is this a new build?
  4. What’s your drive line angle ?
    Drive shaft in good shape u joints etc ?
    try bolting your drive shaft up differently , flip the you joint the way it’s bolted to the flange ( hope this makes sense) I got rid of a few noises and vibrations this way.
    Truckdoctor Andy likes this.
  5. coolieman
    coolieman
    I had tractor puller guy set up rear whined way to much , I TOOK IT OUT TRYING TO SET BACKLASH,GEAR PATTERN, MADE IT WORSE GOT PISSED AND BOUGHT BRAND NEW CENTER SECTION$ 1,000,00 I UNDERSTAND
    TH GASEY WHINE BUT NOT LIKE THIS, CANT THINK OF ANYTHING ELSE WOULD MAKE NOISE I CAN'T GET VIDIO LOADED NOISE STOPS WHEN LET OFF GAS
  6. krylon32
    krylon32
    from Nebraska
    I have purchased many 9 inch posi centers from Speedway as their price was friendlier than John's. I've had 1 screamer out of the bunch and when Dave was the sales manager they sent another center N/C and paid the return freight on the original center. Things have changed.
    Deuces, rod1 and Boneyard51 like this.
  7. squirrel
    So....it's always made noise. That makes it a bit more difficult to diagnose, especially without hearing it.
    Usually when we need to get video on here, what we do is upload the video to youtube. Then copy the link to the video, and post the link here. Then everyone can see it.
    If you can't figure out how to do that, see if you can find someone young to help you? Seems to be easier for youngsters to learn how to do things on computers.
    Dave G in Gansevoort likes this.
  8. Boneyard51
    Boneyard51
    If the noise stops after you get off the gas, it is more than likely the pinion and ring gears was not set up right.
    If it was a rear end that I set up I would remove the pinion and add a couple of thousands to the shim pack and see if it helps. Listen to the sound and adjust from there. That keeps you from having to remove the axles and brakes and things. But it could be the setting of the ring gear, also, which would make it necessary to pull the third member.
    Now any of this would probably void any warranty you have on your third member.
    Bones
  9. coolieman
    coolieman
  10. coolieman
    coolieman
    While I am trying to figure out how to send video my main concern is if I send it back they can look at it and see whats wrong, the video would help but I don't know if they would listen to it wanted you guys to listen I'm still trying to get it sent, also has anyone heard of a wineing rear making harmonic at higher speeds could I have 2 problems
    Boneyard51 likes this.
  11. squirrel
    Usually driveline vibration, due to U joint angles, is what causes harmonics at highway speeds.
    That's why I asked if it's a new problem, or not.
    VANDENPLAS and Boneyard51 like this.
  12. I agree with boneyard51, and suspect since the noise has been there since day 1, that the rear was not set up correctly. 3.50 ratio is semi-hunting, and the gears indexed when they were lapped during production. Not ***embling it with the timing marks indexed would cause a whine. If you want to drive the car over my way, I can listen to it.
    Check your u-joints and u joint angles first.
  13. Boneyard51
    Boneyard51
    It usually takes a little speed to make a rear end whine and it will/can change a little at different speeds. They will usually make more noise as speed increases….but not always.
    Bones
    VANDENPLAS likes this.
  14. Kevin Ardinger
    Kevin Ardinger
    Probably not set up right. These big speed shops farm that stuff out to some incompetent *****s that no nothing about setting up a rear. They are rolling the dice that you won’t complain. Same with store bought transmissions. Then they will ask you something stupid like what kind of oil you used. Try to blame the installer. Ask me how I really feel! Lol. Need to do it yourself or find someone that knows their stuff to do it for you. Unless it was a reputable rear end manufacturer I wouldn’t buy a over the counter engine, rear or trans.
  15. Rand Man
    Rand Man
    Are you sure it’s not a wheel bearing making the noise?
  16. Stan Back
    Stan Back
    You sure you don't have a quick change?
    beater32 likes this.
  17. jaracer
    jaracer
    Ring and pinion noise is usually speed sensitive. It can be on pull or coast, but not normally on float. You can almost use your throttle to play a song. My motorhome has a noise on coast from about 50 to 35. It's not bad and it's just a noise. The rear end will probably last longer than me.
    I've said this before, but if you have a noisy ring and pinion it's not likely you can adjust it out completely. What I have found is that you just change the speed at which it makes noise. Ford had a problem with gear cases in the mid 70's. I worked at a Lincoln/Mercury dealer and we did a lot of 9 inch rear ends under warranty. For noisy gear sets Ford wanted you to remove it, run a tooth pattern and re-adjust it. After going through that you could order a new ring and pinion which was the normal fix.
  18. DDDenny
    Throw some sawdust in there!
  19. rtp
    rtp
    No stuff it full of bananas!
  20. coolieman
    coolieman
    I am zeroing in on noise , I am not paying attention to whine just trying to diagnose racket in drive line, put car up on jack stands set at ride hight put car in gear 45 mph got underneath with hose rattling up down driveshaft seems louder at both ends watched shaft dosen't seem to be out of balance no noise at tail shaft 350 trans starts behind u joint goes down driveshaft to rear I can't isolate noise in rear alot of stuff going on under there, would rear end noise travel up down driveshaft new joints brand new center section
  21. silent rick
    silent rick
    are the u joints in phase? enough movement in the slip yoke?
  22. Kevin Ardinger
    Kevin Ardinger
    Yes the rear end noise will travel up the driveshaft.
  23. Texas57
    Texas57
    When I had my '57 rear redone with trac-loc, I had a whine going around corners. never drove it much until I talked with Yukon and they told me the noise was due to the synthetic oil I used, lol, the high dollar stuff. I changed to conventional and it's been quiet ever since....53,000 miles later
  24. dirt t
    dirt t
    What's the dealer say?
  25. coolieman
    coolieman
    Yes/yes
    At first i was worried about the whine they said drive it 200/300 more miles and see what happens i could send it back and they would look at it , since i have gotten under car and listened to it in real time i am totally confused i don't see i can isolate noise with it running up and down driveshaft will pull shaft back out and check u joints
  26. dirt t
    dirt t
    Please post what you find or how it was fixed.
  27. coolieman
    coolieman
    I requested a refund and I am sending it back
