Projects '33 5w Build Thread
Discussion in 'The Hokey Ass Message Board' started by CTaulbert, Oct 27, 2018.
  1. Woogeroo
    Woogeroo
    from USA
    Damn, that looks so, right.
    Stogy, CTaulbert and loudbang like this.
  2. Hitchhiker
    Hitchhiker
    Wow. Amazing build
  3. CTaulbert
    CTaulbert
    from Detroit
    Crazy how different it looks?!
    loudbang and Stogy like this.
  4. Stogy
    Stogy
    Sometimes it takes a while for things to sink in but I got it now...:D...Flamed got me snooping...
    CTaulbert, brady1929 and loudbang like this.
  5. CTaulbert
    CTaulbert
    from Detroit
    Work is continuing on the '33, now focusing on wiring the car. With the help of Ashley, we fished some wiring down the rails for the headlight taillights, and fuel system. During that time, the chrome work came back, so I've been slowly getting those pieces put back on the car.
    brEad, alfin32, RatPwrd and 9 others like this.
  6. CTaulbert
    CTaulbert
    from Detroit
    With the Auburn panel and switches, the dash has a lot of wiring in it (about 28 circuits in total). I prewired the entire dash, and used three compact deutsche connectors to make the near future install go easy.
    I checked out everything before calling it good, including lighting up the gauges!
  7. CTaulbert
    CTaulbert
    from Detroit
    The last piece of gl*** left to install was the windshield, which was awaiting the windshield frame from the chromer. With it now home, a couple friends helped me get the gl*** installed in the frame and hung on the car. Fortunately everything fit just as well finished as it did in mockup.
    brEad, alfin32, 51box and 8 others like this.
  8. CTaulbert
    CTaulbert
    from Detroit
    Ashley and I got the hood pieces built up the other day, and began the difficult process of fitting everything together. I'm pretty happy with what we achieved, so I locked down the radiator/grille/side aprons. I'll pull the hood this week so I can continue to wire the engine bay with a little more access.
    brEad, ottoman, Tim_with_a_T and 34 others like this.
  9. DDDenny
    Very nice Cory.
    CTaulbert, kidcampbell71 and Stogy like this.
  10. Marty Strode
    Marty Strode
    Cory, it's almost a shame to put fenders on, but it will even be more Dynamite with them !!
  11. loudbang
    Better and better. Close now. :)
  12. Stogy
    Stogy
    Upgrade on like...more than worthy...
    CTaulbert, loudbang and brady1929 like this.
  13. flatheadpete
    flatheadpete
    from Burton, MI
  14. krylon32
    krylon32
    from Nebraska
    looks dam good as a highboy.
  15. Just Gary
    Just Gary
    Nothing on this car sticks out or is otherwise inconsistent with the build. Even the gl*** is perfectly integrated.:cool:
  16. El Hueso
    El Hueso
  17. loudbang
    You are so great building Hot Rods if you don't mind letting us know what is your "regular job" ?
    Stogy, brady1929 and CTaulbert like this.
  18. alchemy
    alchemy
    I think he drives trains. You know, an engineer. He's sure keeping this build on track.
    Stogy, HemiDeuce, brady1929 and 4 others like this.
  19. Tim
    Tim
    from KCMO
    I thought he worked at a tuxedo rental place? His work shirts have a bow tie on them?
  20. CTaulbert
    CTaulbert
    from Detroit
    I'm going to drive it just for a bit before the fenders go on - I want to make sure nothing needs to come back apart!
    kidcampbell71, loudbang and Stogy like this.
  21. CTaulbert
    CTaulbert
    from Detroit
    My day job is an automotive engineer. Building a hot rod and build new cars are remarkably the same thing.....just different scales!
    brEad, Graham08, loudbang and 5 others like this.
  22. 57tailgater
    57tailgater
    from Georgia
    Remarkable build. On your air cleaner did you have to do much finish work on the 3D print?
    loudbang, Stogy and CTaulbert like this.
  23. CTaulbert
    CTaulbert
    from Detroit
    With most 3D print processes, you’re going to see the edges of the layers on curved surfaces. I blocked the pieces in 80 grit, then shot a couple coats of polyester primer on it. Once that was blocked to 320, it was ready to seal and paint.
    Tim, loudbang and Stogy like this.
  24. rod1
    rod1
  25. Marty Strode
    Marty Strode
    I think a little Beatnik jargon from 1960 is appropriate here, "Like Wowzville" !
  26. Ford blue blood
    Ford blue blood
    All the adjectives have been used to describe this build.......can't think of another, just perfect!
  27. hotrodA
    hotrodA
    What a car!
    What a color!
    loudbang and CTaulbert like this.
  28. rod1
    rod1
    This needs to be in Ryan's " Go Green !"thread.
  29. CTaulbert
    CTaulbert
    from Detroit
    Over the past week, I got the car wired. I did a lot of preplanning, so the actual job was pretty easy. I got the dash installed (after installing the header panel and windshield garnish plates), followed by the steering column and wheel.
    I also got the engine wired too, along with wrapping up the plug wires. The OT EFI is pretty incon****uous, and I'm very pleased with it!
    Just Gary, Jet96, Tman and 14 others like this.
