Technical 30/31 Model A Coupe Rear Window Body Question
Discussion in 'The Hokey Ass Message Board' started by -Brent-, Aug 31, 2021.
  1. -Brent-
    -Brent-
    I have been working on fitting the wood around the windows in my 30 coupe but I came across something that doesn't seem right and I never noticed it.
    At the bottom of the window opening the slotted lip doesn't jibe with the lower section of wood. I am not sure if I ever had the wood to compare it to but something isn't right.
    Even comparing it to pics online it seems different. Is this a roll-down window opening? If so, have any of you fitted a standard wood kit?
    Model A guys can you help?
  2. 31Apickup
    31Apickup
    Since the bottom flange is bent straight down it most likely had roll down back window. The 30 coupe used thinner wood, when the went to the roll down window for 31 the wood is much thicker even on non roll down windows. I can post a photo tomorrow of mine which is 1930 style.
    Stogy likes this.
  3. 31Apickup
    31Apickup
    Here’s a dark photo I have on my phone. 861C30FC-EBC4-4380-BFE7-10BD312444BB.jpeg
    Stogy likes this.
  4. alchemy
    alchemy
    A 32 coupe I've been working on had the lower flange like yours since all 32's have roll up windows. I didn't want the roll up feature, so I bent that flange to match the other sides. I made my own wood so it fit perfectly.
    Stogy and -Brent- like this.
  5. -Brent-
    -Brent-
    Sure, I'd love to see a pic. Thanks.
    I don't want roll up/down windows either. I hadn't even considered that my car was anything but standard until tonight. Since I have the standard wood kit, it looks like I'll be modifying something soon...
    Here I was thinking I was going to get off easily!:D
    Dino 64 and Stogy like this.
  6. A 2 B
    A 2 B
    from SW Ontario
    This is a '30 coupe still intact with the package tray and no roll down window. Never been apart. DSC06821.JPG
    belair, Stogy and -Brent- like this.
  7. -Brent-
    -Brent-
    @A 2 B thanks. I definitely have the roll-up/down type opening on my car then. Thanks for the clear pic.
    Thanks so much, everybody!
    Now to figure the best way to proceed...
    Stogy likes this.
  8. Stogy
    Stogy
    Maybe a Roll Down might provide some refreshing airflow, perhaps re-consider using non functional...
    Hambers, anyone here have any experience with the airflow with and without this feature?
  9. A 2 B
    A 2 B
    from SW Ontario
    From a Mike's Affordable A catalog. Kind of pricey going that route. Rear Window Kit.jpg
    Stogy likes this.
  10. Stogy
    Stogy
    Funny they exclude the gl*** in the kit and low and behold it's right below it...humm...408.30 that was easy...:D
    With no aircon in the big scheme of things it might be worth it...my rear window is fixed. I rely on the tilting Windshield and the door windows...and yes there is flow...it actually comes in curls and heads down behind the dash towards ones feet along with bees and other critters...
    As much as many frown at hanging the Ole arm out the window it certainly is very much like the dog with its tongue out at times...I live with it but wonder how much difference there is...
    AVater likes this.
  11. -Brent-
    -Brent-
    Not for me - at all. That doesn't fit this car whatsoever.
    I'd rather spend the money on my 327 or a 12 gal moon fuel tank.
    Stogy likes this.
  12. A 2 B
    A 2 B
    from SW Ontario
    That catalog is 3 or 4 years old. I have ordered from them recently, prices are all up and many things "no longer available", but they do their best to find what you need.
    Stogy likes this.
  13. Stogy
    Stogy
    I like that...Purpose built...Power and Speed...
  14. A 2 B
    A 2 B
    from SW Ontario
    [QUOTE="Stogy, post: 14183599, member: 27904 ..."With no aircon in the big scheme of things it might be worth it...my rear window is fixed. I rely on the tilting Windshield and the door windows...and yes there is flow...it actually comes in curls and heads down behind the dash towards ones feet along with bees and other critters...
    As much as many frown at hanging the Ole arm out the window it certainly is very much like the dog with its tongue out at times...I live with it but wonder how much difference there is...[/QUOTE]
    I have often wondered about the accessory add on vent wing window kits. A friend had them on his '29 coupe decades ago but I never gave them any thought at the time. Not right for Brent's car either.
    Brent, if you need any more pics or measurements, just say so.
    -Brent- and Stogy like this.
  15. Stogy
    Stogy
    I have often wondered about the accessory add on vent wing window kits. A friend had them on his '29 coupe decades ago but I never gave them any thought. Not right for Brent's car either.
    Brent, if you need any more pics or measurements, just say so.[/QUOTE]
    Yeah they're not very Hotrod either...some run them though...there was a rare side cowl vent the Town Sedans had that found they're way onto coupes as well...very rare though and would cause drag as well...
  16. -Brent-
    -Brent-
    Thanks.
    I just came out to the garage to see what I can do with the wood and how to fasten the lower section because I'd just be laying in bed thinking about it if I didn't.
    A quick look and I thought of a couple options that might work.
    At least I know what I am looking at now.
    I appreciate the help. That goes out to everyone.
    Stogy likes this.
  17. -Brent-
    -Brent-
    Sneak peak... it's a standard window opening now.
    It's also 1:15am...
  18. A 2 B
    A 2 B
    from SW Ontario
    Here is a few more pics that may help.
    First one shows the corner details. All four corners are the same, measuring 1 1/4" from the corner. Easily improvised or maybe not even needed.
    Second pic shows the lower cross wood not extending past the uprights.
    Third pic is what appears to be a bracket made of 14 DSC06823.JPG DSC06824.JPG DSC06827.JPG Rear Window Wood Bracket.jpg gauge sheet metal to tie the upper horizontal wood together.
    A page from Mike's showing that bracket. Easy to make.
    4ever18, akoutlaw and -Brent- like this.
  19. -Brent-
    -Brent-
    Those corner pieces are something I want to order or fab.
    Thanks so much for those pics!
    Here is what I did:
    A 2 B likes this.
  20. 31Apickup
    31Apickup
    -Brent- likes this.
  21. -Brent-
    -Brent-
    I love seeing all these pics. This will certainly help someone in the future.
    As for my issue, the window opening has been converted from the Deluxe to Standard and fitted to the chop.
    Mike Paul, Tim and akoutlaw like this.
  22. -Brent-
    -Brent-
    A good pic sent to me of a roll down window frame... for reference.
  23. Canuck
    Canuck
    30 coupe Standard: Rubber corner pieces replicated with sheet metal to help keep the rubber gasket in place.
    Replica rear wood framing around a NON Roll down window and rear parcel shelf. Parcel shelf has been modified to give more leg room.
    Stogy, akoutlaw and -Brent- like this.
  24. -Brent-
    -Brent-
    I've used these photos and your build blog as a reference quite a few times! It's been a great resource.
    https://chevelle406.wordpress.com/
    Stogy likes this.
  25. -Brent-
    -Brent-
    Hey @Canuck do you happen to have any pics of your garnish trim installed and the gl*** in and such?
    I've been fabbing and I made up a set of corner supports like yours but the way my repop trim is, I am not sure it will look "right".
    Here are some pics:
    akoutlaw, Tim and Stogy like this.
  26. alchemy
    alchemy
    All of the corner fillers on the body side of the window won't show at all with the gl*** and rubber gasket in place. Since the corner tins in your window molding don't cover as much as the arch in the body, maybe some of the rubber might show on the inside. And maybe you want to replace your corner tins. Or maybe we are just overthinking this.
    -Brent- likes this.
  27. Canuck
    Canuck
    These are original Ford window trim. Don't know if corner is larger than your repro. The rubber that shows along the straight sections is about the same as what shows through the corners.
    akoutlaw likes this.
  28. -Brent-
    -Brent-
    Cool! That helps. Mine looks the same.
    The stock ones I have looked that don't have such a gasket as what we're using.
