Technical Removing WD40 from bare metal before priming?
Discussion in 'The Hokey Ass Message Board' started by bantam, May 16, 2021.
  1. rg171352
    rg171352
    from New York
    Any updates? I used WD40 after reading many threads here that made it seem as though it and Gibbs were fairly equivalent. On the bright side, my body has not started to rust yet.
  2. No comparison between WD and Gibbs in my worthless opinion.
    I’m from a body shop background. WD40 wasn’t allowed in the shop nor any other silicone product in a spray can.
    Ive had to remove WD40 from bare steel bodies. Inside and out. ****s
  3. noboD
    noboD
    And Gibbs is easy, just wipe it with thinner and paint away. I've done it, no fisheyes.
    Dino 64 likes this.
  4. Wanderlust
    Wanderlust
    Just to be contrary, WD 40 is an excellent contact cleaner and protectant.
    5window and Truck64 like this.
  5. BamaMav
    BamaMav
    from Berry, AL
    Don't know if they still make it or not, but I used to use Wisk laundry detergent. It would remove oil from a pickup bed like nobody's business. Wife doesn't buy it anymore, so I'm not sure if it's even in stores anymore.
  6. indyjps
    indyjps
    Clean Dirt.....That made me smile.
    I understand where you're going.
  7. Pete1
    Pete1
    from Wa.
    It tastes pretty good with a beer chaser.
  8. Deuces
    Deuces
    But I like garlic.....:rolleyes:;)
    lothiandon1940 likes this.
  9. LOST ANGEL
    LOST ANGEL
    And onions!:p:D
    lothiandon1940 and Deuces like this.
  10. Deuces
    Deuces
    Only french fried....;)
    LOST ANGEL and lothiandon1940 like this.
  11. 5window
    5window
    With gloves, lots of ventilation and no sparking metal in sight. That stuff is volatile as hell, highly flammable and will make your liver look like an dead armadillo that's been out in your Texas sun for a week in about the same time. Way better and safer methods for cleaning..
  12. Jones St.
    Jones St.
    Happening again. He needs to remove the W-D, not what to use to protect bare metal...........next time. Mineral Spirits. Then metal prep.
  13. KenC
    KenC
    Common misconception. There is no silicone in WD40. Check the MSDS. But it is still not the right choice for this job.
    5window likes this.
  14. Cool.
    Never read the TDS for that one. Mainly cause we were prohibited to use it in the shop.
    gimpyshotrods likes this.
  15. 1971BB427
    1971BB427
    from Oregon
    I use a good degreaser first, then a final wipe with acetone on a rag. Never had any issues with paint coming off.
  16. Los_Control
    Los_Control
    from TX
    I actually use wd40 a lot as a cleaner, I will spray on hinges and clean them and get them working well, then spray a lubricant on them afterwards.
    WD40 is great for air tools. A tool such as a die grinder oiled properly will eventually gum up with oil and lose power.
    Run WD40 through them, until clean ... you will see all the old oil come out the exhaust. You will feel the power or torque come back, then add proper oil.
    My Uncle had a coats 40/40 tire machine that he stopped using because it no longer could remove a tire without hammers and bars. Was that way for over 10 years. I started running WD40 through it and within the hour I had it working as good as new again. Of course now it needed lubricant.
    If you have air tools you could use some WD40.
  17. squirrel
    I have air tool oil, which I use in air tools.
    LOST ANGEL, Deuces, Dino 64 and 3 others like this.
  18. Dino 64
    Dino 64
    from Virginia
  19. saltflats
    saltflats
    from Missouri
    Can it be sanded off?
  20. MCjim
    MCjim
    from soCal
    WD40 has its uses...one for example; it is great for removing burnout rubber, tar from road work, Etc. stuck on your car.
    Deuces and VANDENPLAS like this.
  21. Moselli
    Moselli
    Concerns about the health hazards and disposal of chemicals have taken me down a different path when it comes to prep. I’ve had good results cleaning metal using food grade citric acid. Mix 1/4 - 1/2 cup with a gallon of hot water.
    Use a sprayer to wet the area, let it sit for five minutes, spray again and scrub brush, rinse with clean water, blow dry.
    Moselli
    LOST ANGEL likes this.
  22. 5window
    5window
    Also pretty good for softening and removing silicone caulk-like when you make a mess regrouting your bathtub
