Projects 37 Chevy Hot Rod tribute project
Discussion in 'The Hokey Ass Message Board' started by RatPwrd, Aug 29, 2021.
  1. RatPwrd
    RatPwrd
    LOL, teal and tweed yuck! Yeah I feel very lucky to find such a straight, rust free, and complete car!! Then on top of that having some racing history to it also!!!! Yeah I would like to meet, and to check out each others 37s!!
    loudbang, Thor1 and SilverJimmy like this.
  2. Signed up yesterday for November GoodGuys, bringing my 64 Nova G***er. You going?
    loudbang and RatPwrd like this.
  3. RatPwrd
    RatPwrd
    Yeah, for sure, will be in one of these 2? We PB182398.JPG will have to meet up out there, and maybe you could come out to Queen Creek to see the 37?!
  4. 1971BB427
    1971BB427
    from Oregon
    My '39 coupe had a 9" Ford in the rear when I bought it, but no sign of what engine it once had. And not even close to as well kept as your '37! Mine was owned by two brothers who both worked for Old Chicago fibergl*** parts, which specialized in pre War Chevy fibergl*** parts. They'd made some gl*** parts for it like trunk lid, fenders, and one piece frontend, but then sold it to another guy. He planned to bring it back to a g***er, but said he kept getting older and it sat there in his field until he finally sold it to me.
  5. 38Chevy454
    38Chevy454
    I happen to have some first hand experience to know that a big block fits in the 37-38 Chevy quite nicely. It's tight and you have to watch all your clearances. But it's hard to beat the visual impact of a BBC. Nice car you found, I really like the Olds rear in there. Those traction bars certainly look homemade.
  6. I was thinking about the show also.. Need to get the headlights wired and such on the 34 truck to make the drive..
    I am still a bit PO'd at them from the 2020 show and how they treated people up in the sale area.
    Thor1 and loudbang like this.
  7. RatPwrd
    RatPwrd
    Yeah, I'm a big block Chevelle guy, love the big block, easy to make big power. When I get to the eng/trans mock up stage, I plan on mocking up both big, and small blocks, so whatever way I go it will all fit nice. Haven't decided if I'm going to give myself more room by setting the firewall back? Like the look of the stock ribbed unbutchered firewall, but be much more room for the big block if I did. Have to leave plenty of room for a big radiator, especially in AZ!! I don't think the traction bars are homemade? All the mods on the car look fairly professionally done. Ill post detail pics of some of that tomorrow, have a bunch more pics to post.
    Thor1, loudbang and SilverJimmy like this.
  8. Just Gary
    Just Gary
    This is gonna be an awesome build.
    Here's another '37 to add to your file. Taken a few years ago at the Jalopyrama in Annapolis, MD:
    akoutlaw, SilverJimmy, Thor1 and 3 others like this.
  9. RatPwrd
    RatPwrd
    Thanks! yeah I really like this one!, think I have a pic of this one already, but at a different show? has a great stance, not too tall, rear fenders aren't butchered to hell. Like the graphics/decals on this, haven't decided if I'm going to do anything like that? really easy to over do it.
  10. 1971BB427
    1971BB427
    from Oregon
    This is a local car that's been around awhile. Owner p***ed away, and the family just got it back on the strip again this summer.
  11. RatPwrd
    RatPwrd
    So here is why I believe this car and or parts were at least partially professionally shop built. The sticker in the rear window "McBride engineered compe***ion racing machines Tulsa Okla" and a smaller version under the hood top. All of the ch***is parts look very well thought out and made. These parts weren't made with a cutting torch, hammer, and a rat tail file!! LOL There are 1/8" plates reinforcing the bottom of the front frame rails from under the front floor boards, to the front cross member. There are 1/4" plates reinforcing the bottom of the frame rails about 18" long under the front spring eye on the rear leafs. All of the parts; rear upper shock mounts, frame reinforcements F/R, tow bar/upper front shock mounts, trans cross member mounts, and traction bar mounts F/R, all have stampings on them. They all say T&L CO, Special Part, built by, etc, etc, and a series of numbers like a part number or more likely a date?!?! But, if the numbers are a date, that put all these nice new Ricky Racer parts built/installed right before the car was parked in 1972, and didn't leave the storage building until 2015?!?! Would love to find out any information or history about the McBride company!! Any hot IMG_20210501_095939866.jpg IMG_20210502_102511513.jpg rod racing historians from the Tulsa area?!?!
    swade41, Thor1, SilverJimmy and 2 others like this.
  12. RatPwrd
    RatPwrd
    Front upper shock mount/tow bar brackets. T & L 7 8 71....July 8th 1971?? and if you look all of the hardware holding the ch***is parts are all nice high quality, high strength bolts, not hardware store grade 5 stuff!! IMG_20210901_213058387.jpg IMG_20210901_213105985.jpg IMG_20210901_213144526.jpg IMG_20210901_213202452.jpg
  13. RatPwrd
    RatPwrd
    Trans crossmember and mounts. Factory muscle car era GM trans crossmember, probably a brand new part off of a then late model car?? Must be Camaro, or Nova? 31" wide, measured my Chevelle, its 54" wide IMG_20210901_211724195.jpg IMG_20210901_211736053.jpg IMG_20210901_211805548.jpg
    SilverJimmy, Thor1 and loudbang like this.
  14. RatPwrd
    RatPwrd
    Front frame rail lower reinforcement plates. go from under the front toe boards forward, all the way to the front crossmember under the radiator. Bolted and s***ch welded to the frame. IMG_20210901_211833816.jpg IMG_20210901_211900703.jpg IMG_20210901_213123826.jpg 1/8" plate cut to follow the gentle "S" bend of the frame
  15. RatPwrd
    RatPwrd
    Rear spring, front spring eye reinforcement plates. 1/4" thick, about 18" long, factory mount welded to the bottom IMG_20210901_211322676.jpg IMG_20210901_211424819.jpg IMG_20210901_211440364.jpg IMG_20210901_211359234.jpg
  16. RatPwrd
    RatPwrd
    Rear traction bars, and mounts, 1 1/2" diameter tube! all 1/4" thick plates IMG_20210901_211633253.jpg IMG_20210901_211615848.jpg IMG_20210901_211029104.jpg IMG_20210827_144147082.jpg
    swade41, Shadow Creek, Thor1 and 2 others like this.
  17. RatPwrd
    RatPwrd
    More close ups IMG_20210901_211209544.jpg IMG_20210901_211239076.jpg IMG_20210901_211407609.jpg IMG_20210901_211510296.jpg of the stampings on the parts
    swade41, Shadow Creek, Thor1 and 3 others like this.
  18. 1971BB427
    1971BB427
    from Oregon
    Trans crossmember looks like factory Chevy for the late 60's or 70's Camaro, Nova, or Chevelle.
    Thor1, RatPwrd and loudbang like this.
  19. RatPwrd
    RatPwrd
    Measured my Chevelle its 54", this one measures 31", must be Camaro or Nova?!
    Bowmalloy Bolts! I worked at the Navajo Generating Station from 1980-1990 and when I first started working there they had a campaign to get rid of all those bolts. Those bolts were actually TOO good, Grade 12 in most sizes and when something would go wrong instead of the bolts failing the equipment would get destroyed. We had to go thru all the bolt bins and toss them right into the s**** pile and restock the bins with actual Grade 5 and Grade 8 fasteners. Now the whole Station is in the s**** bin…..
  21. Guy Patterson
    Guy Patterson
    Those damn bolts are not cheap man just wow don't lose those
  22. Just Gary
    Just Gary
    Post pictures of the date codes on the sides of the gauges. That'll sorta establish a "no earlier than" race car build date. :)
    loudbang, Thor1 and RatPwrd like this.
  23. RatPwrd
    RatPwrd
    volt gauge, and fuel gauge, how do you read these date codes
  24. RatPwrd
    RatPwrd
    oil psi, speedo, and tach, mech water temp had no markings
  25. RatPwrd
    RatPwrd
    I never knew they had a name? I knew my dad had some from working in the record pressing industry, and I knew they were really strong! That's one of the reasons I think this car was put together by someone with a little more knowledge? Put more thought and effort into some things than most would?! Back before you could order a bunch of ARPs from Summit
  26. I remember when the hot setup for rod bolts were SPS!
  27. RatPwrd
    RatPwrd
    OK......so this throws a whole new wrinkle in the time line of this car?!?! So "Just Gary" said to check date codes on the gauges, didn't know you could do that?! Speedo is N9 Sept 69, ok that lines up with the time line of the car. Tach has no numbers whatsoever? Water temp no markings? Oil PSI W 12 Dec 77, Volt Y 11 Nov 77, Fuel Y 9 Sept 79. Looking at gauges to see date code markings, I find along the bottom edge of the 2 panels..."built by Lynne 3 23 80 2E, and "built by Lynne 3 11 80 2E. So this car that I was led to believe was parked , and never moved from 1972-2015?! Had new gauge panels fabricated in March of 1980?, and newer 1977-1979 gauges installed?!?!
  28. 50John
    50John
    Unbelievable that the shop stamped everything. I could see if they were making a line of parts that they were marketing but these appear to be one offs for your car. Great project and an excellent starting point. Hope you can somehow track
  29. Is there any HAMB’rs from Tulsa Oklahoma that remember this T&L Co.? Maybe somebody has an old 1970 phone book from Tulsa in a pile somewhere? I know I’d sure like to get a 37-39 Chevy G***er kit from them! Those look so well made I wonder if they were advertised in one of the magazines or National Dragster for sale? Somebody has to know!
  30. I wonder if Lynne was 1/2 of T & L?
