Hot Rods Build a hot rod y block
Discussion in 'The Hokey Ass Message Board' started by famdoc3, Aug 28, 2021.
  1. famdoc3
    famdoc3
    So it’s time to build the motor for my Model A Coupe project. I have been into 50 years starting with my 57Tbird in 1972. So I’ve been collecting parts. Found a forged truck crank about 10 years ago sent it to be cut for Chevy rods then to be nitride. High nickel 1959 292 ultra sounded for core shift and then .060 over block bored to .090 for custom pistons on narrowed Manley ls Hbeam rods completing the lower end. Heads with stainless valves and hardened seats.
    Okie Pete, Sharpone, Tim and 10 others like this.
  2. famdoc3
    famdoc3
  3. famdoc3
    famdoc3
    Was lucky enough to get a blower manifold from Australia YBloke. Polished 471 B8FBCE5F-E08B-4C64-AD06-B63ACC385FEA.jpeg
  4. famdoc3
    famdoc3
    Next the Grant Flame Thrower
  5. Very impressive,,,,,,keep those pics coming .
    It’s exciting to see a Y block build,,,,and this looks like a pretty bad dude !
    I like that gold color as well ,,,,and the 4/71 !
    This would have been a good candidate for a complete build thread .
    Tommy
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
  7. Corn Fed
    Corn Fed
    Fantastic! Its great to see more Y-blocks being used. I dig them.
    I too got lucky and have a forged crank and high nickel 292 in my '57 wagon, but it doesnt look near as cool as yours.
    And I have a 312 in my Model A PU, so I will be closely watching your build.
  8. loudbang
    Are you underdriving that supercharger? That pulley looks rather large. :)
    Sharpone and Deuces like this.
  9. famdoc3
    famdoc3
    Not under driven. I’m running 2 v-belts off of the crank pulley which is essentially the same size (a little over 6 “). Working out the details as I go. It’s an adventure. Thanks for looking! MIKE
  10. Baumi
    Baumi
    Great Y you are building there! I have a 312 in my 34 sedan, those Ys are beautiful , and yours seems as if it´ll be performing great aswell!
    Sharpone, loudbang and Deuces like this.
  11. famdoc3
    famdoc3
    Here’s a picture of the mock up before it went to the machine shop. Bit by bit it’s getting there. 64BC91F9-884F-4940-B8AA-931830A4774F.jpeg
  12. famdoc3
    famdoc3
    Wheel are for the mock up only. Plan is for 35 16”wires.
  13. AHotRod
    AHotRod
    It's a beauty ! I also painted my block Gold.
  14. famdoc3
    famdoc3
    Progress is being made. It gets better and better. Front drive system coming together. Power steering worked out. Still no fluids yet. Distributor to get new points and then set up on the machine before final installation and wires to make and install plugs. MIKE
  15. y'sguy
    y'sguy
    from Tulsa, OK
    Love it, which heads and did you do anything to them?
  16. AHotRod
    AHotRod
    That's a sharp engine
  17. famdoc3
    famdoc3
    Heads are 113s with hardened seats and 16 stainless valves cut for real seals. Thanks for looking . MIKE
    Sharpone, williebill, Deuces and 3 others like this.
  18. famdoc3
    famdoc3
    Pure Y block ****!
  19. famdoc3
    famdoc3
    Latest distributor in and plug wires made
  20. vtwhead
    vtwhead
    Mike, what steering box are you using with that cowl steering? Fantastic job on that 292!
    Sharpone, Deuces and loudbang like this.
  21. v8flat44
    v8flat44
    But, why aren't you using a 350/350 with..........? Good on you....Ford in a Ford & a Y-BLOCK to boot ! That's gonna be one sweet rod ! Way to go !!!
  22. y'sguy
    y'sguy
    from Tulsa, OK
    Any problems trying to set up the timing on it?
  23. famdoc3
    famdoc3
    Steering is a custom stock car power box made in Pa. don’t think timing should be a problem the distributor cam moves to adjust the timing not only by moving the distributor, we’ll see how it works out soon when it gets to the dyno.
  24. Wanderlust
    Wanderlust
    Major wood
    Sharpone likes this.
  25. jaracer
    jaracer
    Nothing like a Y block. The T-Bird valve covers have to be about the best looking valve covers ever made. New Eng in Car3.jpg
  26. famdoc3
    famdoc3
    Put the motor in the frame have to run it to break in the cam and check it for leaks. 6DE3C25A-DAD3-4057-B6D6-DFDC42C97D11.jpeg
  27. Deuces
    Deuces
    Needs some open headers...;)
    Sharpone and loudbang like this.
  28. famdoc3
    famdoc3
    Open headers coming soon. Maybe tomorrow. Stay tuned. MIKE
  29. SPEC
    SPEC
    Love those Y blocks!
  30. jimmy six
    jimmy six
    If you can’t get a blower …. the next best has always been dual quads..even if you hide them under a 1956 Purolator NASCAR air cleaner 48580F31-E062-457B-9242-CA618B9F2654.jpeg 5BAB18DD-0CFA-4947-B2E5-FF9BF99AD124.jpeg
    osage orange, fauj, Sharpone and 8 others like this.
