Technical LOVE WHEN A DREADED TASK IS EASY
Discussion in 'The Hokey Ass Message Board' started by Darin Younce, Sep 2, 2021.
  1. Darin Younce
    Darin Younce
    My horn ****on was the only devise on my 39 pickup not working which bugged me so I was convinced the wire running up thru the steering tube needed replacing. I had check it with my tester and had nothing. I took the switch off the gearbox, removed the c clip and pulled the rod/horn ****on up about 6 or 8 inches (being full removal is a pain).
    I then bent the 4 tabs that hold the horn ****on to the steering cap and removed it , cleaned every surface , did a quick test before re***embly and the dang thing was fixed, then re***embled and rechecked and still working. Been a good day.
    loudbang, Dave Mc, Lil32 and 4 others like this.
  2. oldiron 440
    oldiron 440
    I understand what your saying, my horn ****on on my Fairlane hasn't worked for twenty years...lol
  3. williebill
    williebill
    Down the road, when you least expect it, you will pay dearly for todays good fortune.
    When a job goes unexpectedly easy for me, I patiently wait for the payback.
    It will arrive when it's good and ready.
    But it will arrive.
    SS327, loudbang, partsdawg and 3 others like this.
  4. X-cpe
    X-cpe
    Said that when I sub-framed my 57 PU with a 77 Impala SW front section. The steering column lined up perfectly with the steering box. Haven't worked on it for quite a while but I know it's waiting.
    No good deed goes unpunished.
    williebill and SS327 like this.
  5. I hear you. There's been several times I've put off a job, anticipating a big h***le, nothing fits, etc etc. Then, go to do the job, and it just falls in to place! Should've done this a long time ago.
    But, there are a lot more jobs, where I say, "Should have that back in an hour" and 2 days later, it is.
    X-cpe likes this.
  6. Jack Rice
    Jack Rice
    I've been putting off changing the noisy leaking header to head gasket on the p***enger side of the 330" Desoto hemi in my 36 Ford p/u. The fenders are so in the way and the lower bolts go into the water jacket so leaking coolant just adds another dimension. I going on a 150 mile cruise this Saturday and decided now is the time. It went fairly well and solved the problem! I've been dreading this task most of this summer.
    Algoma56 likes this.
