Projects 32 Closed Cab Pickup Build
Discussion in 'Traditional Hot Rods' started by NealinCA, Jul 27, 2021.
  1. Nobey
    Nobey
    Fantastic build Neal. I run the red wires in the stock Ford tubes with a Malory distributor on my 59AB in my 41
    pickup. No problems what so ever. Do you have a set of boots for the wires on the crab cap?
  2. NealinCA
    NealinCA
    Thanks for the feedback on the red wires. The boots are on order, along with the br*** contacts. I still need to trim and finish the distributor ends of the wires.
  3. Neilb
    Neilb
    from Mead Co
    Dad and son posts always get to me….beautiful engine!
    cactus1, deathrowdave and loudbang like this.
  4. Rocky
    Rocky
    Classified Editor
    33tall.jpg 33atspeed.jpg Love it! I put a 33 together some years ago. Cab channeled the height of the frame and then welded to the rails. My X member was hacked up too. I ran a stock 59AB with a T-5 trans after fixing the frame. Cut my top 4.5" with a late van 3rd seat. Fun, fun!
    cactus1, Stogy, brEad and 5 others like this.
  5. NealinCA
    NealinCA
    Rocky - When I first joined the HAMB 20+ years ago, it was your 33 pickup, SamIyam's Roach Rod, Mart's Ol Rusty, and Mild Mitch's modified that were the inspiration for my RPU. I first planned on channeling it like yours, but then realized my 6'2" self would not fit inside.
    So I ended up with this...with a 59AB and a T-5 trans...just like you did. I remember watching a video of a ride along in your truck and the T-5 sounded so fun, I wanted one too.
    Thanks for the inspiration.
    Neal
    63fdsnr, A Boner, cactus1 and 17 others like this.
  6. alchemy
    alchemy
    I wonder how many other HAMBers has Rocky corrupted over the years?
    cactus1, brEad, -Brent- and 6 others like this.
  7. rod1
    rod1
    That's funny,I was a lurker for several years. Your green flathead, the awesome Bead roller upgrade, and that roadster pickup ,along with Rocky coupe build convinced me I had found the right home.Ryan's 38 burnout video pushed me over the edge..Glad you're back.
  8. Graham08
    Graham08
    Great build! @NealinCA , how comfortable is your 32 truck at 6'-2"? I love the looks of 32-34 pickups, but I'm 6'-3"...so I had always wondered how I would fit in one.
  9. Dan Hay
    Dan Hay
    Really cool. I'm pretty anti-flathead for purely practical reasons, but dang it threads like this make me want one.
    loudbang and kidcampbell71 like this.
  10. continentaljohn
    continentaljohn
    @NealinCA your builds are so incredibly cool and inspiring and attention to details is off the charts and thanks for sharing.
    @Rocky truck also inspired me to get a truck and enjoy it,I have always love the look.
    @Graham08 i am your height and have no issues fitting but on long full day drives the foot gets sore because of the gas pedal angle and my size 13 feet.
    Graham08 and loudbang like this.
  11. krylon32
    krylon32
    from Nebraska
    For all you tall guys with a 32/34 pickup. While it's not traditional I installed a cruise control in my last 2 deuce pickups which allowed some stress relief on the right leg.
  12. Nobey
    Nobey
    My cruise control is a little knob on the dash that says throttle, it works well. I must admit your foot can get stove
    up in a pickup and whatever kind of relief you find is a good thing......
    Jeff34 and kidcampbell71 like this.
  13. Outstanding thread and work as usual Neal, looks fantastic!
  14. Mart
    Mart
    Hey, thanks for the name check, Neal. Glad to have helped in some small way. The tables are turned now. I look to your workmanship for inspiration.
    Blues4U, A Boner and loudbang like this.
  15. My Friend has that 39 Coupe here in New Zealand, just been through a rebuild after having it on the road as found for sometime, Running a Y Block. I thought I recognised your pick up from his photos but wasnt sure. He calls it the San Lorenzo Coupe
    Nominal, kidcampbell71 and loudbang like this.
  16. NealinCA
    NealinCA
    In my 32 RPU, I used a modified 28-29 Model A seat riser in place of the stock gas tank, to get the seat bottom lower.
    I made a simple square tube riser with similar dimensions for the closed cab pickup...
    I am using 33-34 pickup cushions, so it has a 1 piece lower. I fit OK in the cab, but the original seat springs are not great for long trips. I think I want to have some high density foam cushions made for a little more support.
    Tman, nunattax, Hamtown Al and 3 others like this.
  17. NealinCA
    NealinCA
    Some asked why I wasn't going to paint the truck, so here...I painted the rear fenders :)
    The truck had 1930 Chevy rear fenders on it, which didn't look right. I traded for some original Ford pickup rear fenders, but wanted them to blend in with the rest of the truck. I know the whole fake patina thing doesn't sit well with some, but here goes anyway.
    They were pretty nice old fenders...
    After some careful prep, I sprayed on a custom blend of blue/grey to match what was on the truck...
    I did the dropped headlight bar ends while I was at it.
    Then I "accidentally" spilled some metal shavings from my bandsaw on the fresh paint...
    Then rinsed it off with vinegar, hydrogen peroxide and finally wiped with an oily scotch brite pad, I think they match the rest of the truck pretty well...
    Your opinion may differ...haha.
  18. NealinCA
    NealinCA
    We did get the front and rear axles in place, as well as the transmission and steering box installed. I then started in running front brake lines.
    rod1, cactus1, Runnin shine and 9 others like this.
  19. NealinCA
    NealinCA
    I also worked on the engine a little. I got the plug wires finished up on the distributor end, with boots and heat shrink numbers...
    Then mocked up the original unfilled grilled shell, Pete Eastwood dropped headlight bar and headlights for a little inspiration.
    I'm hoping to get the engine dropped in next weekend, and hopefully fired off soon. I'm not entered to race at RPM this year, but I am still shooting to have the truck there. Another 3 week thrash just like last year for the September 24th/25th deadline...
    cactus1, Runnin shine, brEad and 15 others like this.
  20. Graham08
    Graham08
    Thank you for the reply! The lowered seat riser is a great idea.
  21. rusty1
    rusty1
    ...those fenders look so right!
    A Boner, Tman and loudbang like this.
  22. Speedy Canuck
    Speedy Canuck
    Loving this build. Great stuff Neal!
    Nobey and loudbang like this.
  23. Rocky
    Rocky
    Classified Editor
    Nice, Neal and thanks for the nice words.
  24. roddering
    roddering
    from Arizona
    Great job! Amazing work. You are a true artist.
  25. Your truck is fantastic, as are all your projects and your shop looks incredible. Thanks for all the great posts over the years. I wish I had the patience for detail like you do.
  26. DDDenny
    You nailed the "well aged" matchup perfectly Neil.
    A Boner likes this.
  27. NealinCA
    NealinCA
    Not much progress on the pickup this weekend, but I did get an idler/fan bracket made for a friend's 32 project. He is using an Sharp intake without a generator mount, so this is what I came up with...
    20210912_102633.jpg 20210912_110115.jpg 20210912_114016.jpg 20210912_115446.jpg 20210912_122029.jpg 20210912_125538.jpg 20210912_125617.jpg 20210912_171015.jpg 20210912_171318.jpg 20210912_171134.jpg 20210912_171101 (1).jpg 20210912_171101 (1).jpg
    Jeff34, Toms Dogs, Jack Rice and 21 others like this.
  28. The37Kid
    The37Kid
    NICE! Will they be available in heavy patina and buffed for chrome?
  29. NealinCA
    NealinCA
    Haha. Way too much work...this was a one of one...
    cactus1 and kidcampbell71 like this.
  30. akoutlaw
    akoutlaw
    Weiand generator mount 2.jpg Weiand generator mount.jpg That is similar to the one that was offered by Weiand. Here is the unfinished one that I have.
