Looking to Get Started...
Discussion in 'The Hokey Ass Message Board' started by Tribalmonkey, Dec 14, 2020.
  1. Tribalmonkey
    Tribalmonkey
    Anyway. As of right now my list is getting shorter to get the roadster on the road. I’m sure a couple more things will pop up but here’s the current list.
    1. Fix or mitigate serious transmission leak (rear).
    2. Stiffen up quarter panels and adjust doors
    3. Install horn.
    4. Adjust headlights. I may have to heat and bend my headlight bar. Beams too low.
    5. Relocate headlight dimmer switch.
    6. Adjust clutch linkage.
    7. Tag, ***le, Registration.
  2. Joe Blow
    Joe Blow
  3. Tribalmonkey
    Tribalmonkey
    I’m still going to recheck my point gap and timing. Maybe I livened up the spark enough with better connections and new plugs to change the situation.
    lothiandon1940 and Joe Blow like this.
  4. Tribalmonkey
    Tribalmonkey
  5. Tribalmonkey
    Tribalmonkey
    This evening I pulled the clamshell apart (Some of the worst nuts and bolts placement on a Model A in my opinion. No socket or wrench can really get a good turn on those! Ugh!). I found that there was no felt/rope gasket on the rear bottom half. That was actually good news. I cleaned everything up and installed new gaskets. I’ll test it out tomorrow. I’m pretty confident it will be at least less leaky. F34A7361-E59E-4DDF-8811-426D7FDC4F01.jpeg
  6. Tribalmonkey
    Tribalmonkey
    Knocked a few items off the list today.
    1. Installed new gaskets in transmission clamshell.
    4. I heated and bent the headlight mounts. They look like they should be just about right now.
    5. I relocated the dimmer switch so I don’t dim the headlights each time I push in the clutch now.
    6. I adjusted the clutch linkage. I discovered that it was almost adjusted all the way already. I used a die to add a few more threads. That should buy me some time before I either install a new clutch or do the v8/****** swap.
    Next I’ll work on stiffening up the quarter panels and adding my original ahooga horn. Hopefully that gets me ready to tag and start doing some test drives.
  7. Tribalmonkey
    Tribalmonkey
    Update - I drove ‘Ratty’ around the yard this evening and so far no transmission leaks. Also no backfiring since I opened up the GAV a bit more. So far so good.
    I think I’m going to dial back my clutch linkage. I was a bit too ambitious.
    I started working on the quarter panels and door alignment. I have zero experience as a body man other than YouTube. I’ll post some before and after pics when I get to ‘after’. TM
  8. Tribalmonkey
    Tribalmonkey
    Before and after pics of the quarter panels.
    D5F7E2DD-86DE-4337-ABE9-B3424BF01EDD.jpeg 666DC63E-8F5D-4720-B3C3-18742AC46D48.jpeg 18C4C6AE-DEF3-4D8A-8174-48E30122BF82.jpeg 59AFA5A1-E23D-4E5B-BD36-66510FC9421F.jpeg BE7F647F-7C1A-474C-BA57-58DF6ADD9601.jpeg
  9. Tribalmonkey
    Tribalmonkey
    I bent and welded in a steel rod on each side. That along with welding up the cracks made a huge difference. Very solid now.
  10. Dustyp489
    Dustyp489
    Good job , Roadster is really coming along
  11. Tribalmonkey
    Tribalmonkey
    Thanks Skip! I’m excited to get it on the road.
    lothiandon1940 likes this.
  12. Tribalmonkey
    Tribalmonkey
  13. Tribalmonkey
    Tribalmonkey
    We took ‘Pappy’ (the coupe) to the Middletown, MD car show sponsored by the Middletown Fire Department last Saturday. Really fun to hangout with friends and answer questions about the car. B8124FFB-76AA-4C5B-9109-8FBB61D24958.jpeg 938D49BE-6EEF-44FD-BA3D-C1BC6FC3678E.jpeg
  14. Tribalmonkey
    Tribalmonkey
    Tried to get my original Spartan ahooga horn to work last night. Horn spins too fast at 12v and doesn’t work at all with the horn resistor. Any ideas? DE402297-EFB9-4DFF-B706-BC7E2D0E3EC7.jpeg
  15. Tribalmonkey
    Tribalmonkey
    Can you tell the differences between this pic and the one I posted this morning?
  16. lothiandon1940
    lothiandon1940
    You put the grab bars on for the rumble seat.:)
    loudbang, Tribalmonkey and Joe Blow like this.
  17. Joe Blow
    Joe Blow
    ......and cowl light/lights.;)
  18. lothiandon1940
    lothiandon1940
    ......OOPS! Missed those. Good catch @Joe Blow
    loudbang, Joe Blow and Tribalmonkey like this.
  19. Tribalmonkey
    Tribalmonkey
    Couple more minor changes. One you might notice. One is too subtle.
  20. Joe Blow
    Joe Blow
    Looks like you have the center section of your tack rail in.
  21. Tribalmonkey
    Tribalmonkey
    Yes! You guys are good. I also added the stainless cowl trim piece. I was not going to install the cowl lights and trim until I patched the rusty bottoms of the cowl sides but I don’t plan to do that patching for a while.
  22. Joe Blow
    Joe Blow
    The eyes are always the second thing to go Don.:p
  23. lothiandon1940
    lothiandon1940
    .........So true.:(
    Tribalmonkey, loudbang and Joe Blow like this.
  24. Tribalmonkey
    Tribalmonkey
    I’m now thinking I got to lose the cowl lights.
  25. Dustyp489
    Dustyp489
    I feel the only thing the cowl lights are good for is turn signals
    Skip
  26. Tribalmonkey
    Tribalmonkey
    Created a spring type clamp for an early Ford mirror to mount on the center of the roadster windshield. 6FA1FD37-3296-4F30-BF9E-2A0813B868C5.jpeg 13167006-5107-4FF0-8483-067F73496DAD.jpeg E6FE99E4-FC8B-4076-B0C1-E907EDB584A6.jpeg
  27. lothiandon1940
    lothiandon1940
    ^^^^^^^^^Innovative^^^^
  28. Tribalmonkey
    Tribalmonkey
    29772022-6764-40FF-A019-52048BDF3E34.jpeg 5E5C3853-173A-4600-B9AD-0F88DEF4ABCB.jpeg Out enjoying the great weather after Ida p***ed through.
  29. Tribalmonkey
    Tribalmonkey
  30. vtwhead
    vtwhead
    Looking good. video gives the sensation that you are going very fast. How are those mechanical brakes...:rolleyes::rolleyes::D
