Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. vtwhead
    vtwhead
    Wow, music to my ears Paul. I love it, sounds wicked. What cam are you using?
    loudbang and Stogy like this.
  2. Paul
    Paul
    Editor
    Reground stock by Delta Camshaft.. I think..
    I built this engine years ago
    and honestly don't remember..
    I'll have to see if I can find my notes.
    loudbang, bchctybob and Stogy like this.
  3. Jkustom
    Jkustom
    Wow Paul, very cool. Impressive and inspiring as always!
    Stogy, loudbang and Paul like this.
  4. 30tudor
    30tudor
    www.fuelinjectionent.com
    Is Spud Miller’s place. Great magneto man to say the least as nice a guy as you’ll find. He is in Oregon.
  5. bchctybob
    bchctybob
    Hey Paul, do you remember what paint you used to paint your engine? I like the rich gold color. The gold on mine looks kinda faded and it hasn’t made it out of the shop yet.
    Stogy, Paul and loudbang like this.
  6. bchctybob
    bchctybob
    Sounds good! Does your mag have the advance mechanism?
  7. Paul
    Paul
    Editor
    Engine paint is One Shot 109-L Metallic Gold.
    It does change color from heat, the more cooked it gets the more bronze it gets.
    Yes this magneto has advance, not fixed.
    Stogy, Dago 88, kidcampbell71 and 2 others like this.
  8. Paul
    Paul
    Editor
    Spray bomb undercoat and set body back on frame to locate a few penetrations, throttle linkage, wiring, etc.
    chriseakin, brEad, bchctybob and 13 others like this.
  9. dumprat
    dumprat
    from b.c.
    Nice!
    I stared butchering my pile of **** together yesterday using the plans you sent me. Thanks!
  10. Paul
    Paul
    Editor
    another (hopefully) minor glitch yesterday,
    tried to put it in gear with engine running.. no go..
    plenty of throw for disengagement
    goes in and out of gear as it should with engine off
    rolls easy in neutral and when in gear with clutch depressed.
    whatever it is it means a bit of tear down to fix.
    and Mary says "and you think this is fun?"
    bchctybob, Stogy, rod1 and 4 others like this.
  11. vtwhead
    vtwhead
    LOL we all have a "Mary" hanging around now don't we. Just hooked up my MC/CS yesterday and bled it off. Next on the list is to see if it will go into gear as well. The very same set up also! Now I am a bit nervous:rolleyes::rolleyes:
    Stogy, loudbang and AHotRod like this.
  12. Paul
    Paul
    Editor
    Well, I must have been too ready for something serious..
    turned out to be about as minor as it could be.
    Simply just a bit of adjustment.
    Pedal was pushing throw out bearing too far.
    Backed it out a bit and all is good.
    It moves under its own power.
    bchctybob, Stogy, bct and 5 others like this.
  13. AHotRod
    AHotRod
    Brushes and spray bombs rule .... pure Hot Rod.
  14. 64 DODGE 440
    64 DODGE 440
    from so cal
    If it was easy, everybody would be building them.
  15. Dick Stevens
    Dick Stevens
    Paul just makes it look easy!
  16. Paul
    Paul
    Editor
    Minor distraction,
    I'm using a C10 column with a '62 Olds wheel
    Truck signal arm was short and crusty,
    Scored a '64 Olds signal arm,
    cut the threaded end off the Olds,
    cut the tab off the Chevy,
    weld the tab to the Olds arm.
    Sand and polish.
    'probably just hit it with clear to keep it from rusting..
    Just Gary, chriseakin, brEad and 13 others like this.
  17. rob-redm
    rob-redm
    looking great Paul !
  18. vtwhead
    vtwhead
    Nice touch on the directional signal arm! Meant to ask a while back about your choice of 1/4 brake lines instead of 3/16. Do you find an advantage to having more volume with the larger lines?
  19. Paul
    Paul
    Editor
    I used 1/4" because that's what the master, clutch slave and front cylinders used from the factory, and 3/16" only on the rear axle because that's what the rear cylinders took.
    I was more concerned with matching master and slave bores than line volume.
  20. alchemy
    alchemy
    Larger lines doesn't push more volume to the wheel cylinders, it just holds more volume in the line. Doesn't really matter what size as long as the fitting at the ends fit right.
    bchctybob, Stogy, AHotRod and 4 others like this.
  21. Looks great, the bottom is so clean it is a shame it is hidden!
  22. Paul
    Paul
    Editor
    Worked on the throttle pedal and linkage yesterday.
    I wanted to keep the stock '58 stick belcrank because of its relative rarity
    but it needs a push action from the pedal
    and wasn't going to work with the pedal I had in mind.
    So I added a ball pivot to the throttle shaft bracket for a pull action,
    drilled the bracket for a return spring,
    and modified the dashpot bracket to take the other end of the spring.
    Eliminating the belcrank and dashpot.
    And fabbed up a simple pedal.
    I will modify or replace the pedal pad with something that will slide easier on the foot,
    Something s****ish.. maybe..
    PXL_20210907_171546787.jpg PXL_20210909_010738088.jpg PXL_20210909_011109739~2.jpg
  23. Paul
    Paul
    Editor
  24. AHotRod
    AHotRod
    Nice creativity Paul
  25. loudbang
    Stogy and Paul like this.
  26. Paul
    Paul
    Editor
    testing clutch, brake, throttle etc. action
    getting closer all the time.
    just about time to pull the body again
    -to get it at least in primer before final ***embly
  27. Paul
    Paul
    Editor
    Pedal version #3:
    Looks like a highschool metal shop Moon style bigfoot , but it fits, barely, and feels better under foot.
    silent rick, Tman, brEad and 14 others like this.
  28. Paul
    Paul
    Editor
    Redoing the headers.
    Kewpie Doll style collectors and
    side one starting to take shape.
    Tman, bchctybob, The 39 guy and 9 others like this.
  29. jebbesen
    jebbesen
    from Winona, MN
    Those look really nice! To me they look much more finished than the original pipes. Plus this way you can decide if you want to baffle them or not.
  30. Paul
    Paul
    Editor
    Side two coming together
