Technical 3-D Printing Taillights
Discussion in 'The Hokey Ass Message Board' started by scotts52, May 19, 2017.
  1. gimpyshotrods
    gimpyshotrods
    I have an entire AR-15 lower that I 3D printed from carbon fiber reinforced co-polymer polyester. I probably spent 10-minutes cleaning it up after printing.
    It has had over 1000 rounds through it, and has been exposed to harsh cleaning chemicals. Zero issues.
    We use FDM and SLS 3D printed parts on ***embly line production machines and testing machines, to make individual pieces of equipment that retail for upwards of $250,000, on long runs, with perfect repeat-ability.
    Little to no cleanup, constant exposure to harsh chemicals, and cyclic exposure to high intensity UV light. Zero issues.
    If your 3D printed parts are not long lasting outside, you are using the wrong material.
    Jeff34 likes this.
  2. abe lugo
    abe lugo
    All I'm saying your not going to print clear or tinted gl***, Yet. At least on the budget 95% of folks here are on. Glad to know those lasting polymers do exist though.
    Just like removing rust with a 250k laser rust blasting machine.
  3. wsdad
    wsdad
    Wouldn't it just be easier to cut them out of a chunk of plastic? A CNC machine makes more sense to me than a 3D printer. It's like trying to make a head by welding layer upon layer of steel, verses cutting a head out of a block of steel.
  4. there are printers that do that, CNC controlled welders that can print objects in metals
    gimpyshotrods likes this.
  5. Bcuda69
    Bcuda69
    Scott, you could work with Shapeways.com See their materials. They have UV cured frosted acrylic they claim is watertight and suitable to 176°F. They can also produce items in metals by lost wax process.
  6. RTi04
    RTi04
    I've done a fair amount of 3D printing, and I don't think the technology is there yet. SLA (UV-cured resin) will give you the best result, but it's not UV stable and will get yellow and very brittle soon after being exposed to sun. Any FDM process (where filament is melted and built up layer by layer, like Makerbot, etc) can be UV stable, but the resolution will look like garbage. It would require a TON of sanding and polishing to get it to where you'd want to use it, and even then...probably not. As people have mentioned, your best use of a 3D printed lens would be to use it to make a mold for casting. If I remember correctly, the UV cured frosted acrylic that Bcuda69 mentioned falls under the SLA problem - it uses UV to cure the resin during the printing process, but doesn't stand up well to constant UV exposure (though I might be wrong).
  7. gimpyshotrods
    gimpyshotrods
    I am working with full size commercial FDM 3D printers, not hobby stuff. If 0.0015mm is not accurate enough, I cannot help you.
    zman and Bcuda69 like this.
  8. gimpyshotrods
    gimpyshotrods
    Here are two images, direct from the page of our Stratasys Fortus 900mc:
    Bcuda69 likes this.
  9. rladams65
    rladams65
    I am about to venture down this path for a '62 Mercury Monterey. My plan is to design & print in PLA until I get a pretty good fake. Then use the PLA as a form for a silicon mold and cast the replacement in resin. Not sure what I will do about the chrome accent on the crown of the lens - either some metal paint to be done with it or cast a metal accent, chrome dip that, and then JB ClearWeld it onto the lens.
    Considering the cost of a [not very good] replacement and the crazy price for a nice example, I have plenty of space to experiment.
  10. David Gersic
    David Gersic
    from DeKalb, IL
    Find the thread on the Ford dash “waterfall” being done as a 3D print. I don’t know if the chrome there would hold up to outdoor use, but it might give you some ideas.
  11. cretin
    cretin
    A friend of mine makes 3D printed tail light lenses. I’m not sure what filament he uses, but he prints them in clear and then he sprays them in red candy. Here is some of his work.
    D810FFE5-0541-4EAE-B026-72C93D472BDD.jpeg DE87D32B-3DED-4E64-8787-A1FAB2147C4E.jpeg 43908239-ACFA-4AE1-B829-1661A5E570A9.jpeg 25162F6A-8B17-484B-9917-5FD5948670E3.jpeg D8F2B378-917B-4DE3-82F7-A02C11F87752.jpeg 4ADE0B28-D877-42F3-8395-D55985931114.jpeg
  12. Rand Man
    Rand Man
    My son works for a rapid prototyping firm. Like others have said, most everything that comes out of a 3D printer requires hand finish work.
    Unkl Ian, guthriesmith and Deuces like this.
  13. hotrodjack33
    hotrodjack33
    Well, 3D printing isn't very traditional...but I guess having to pay $250 for a NOS tail light ain't all that traditional either...:(
    SS327, Deuces, blowby and 3 others like this.
  14. lostone
    lostone
    from kansas
    To me 3d printers ain't nothing more than another tool for us to use.
    Mig welders, plasma cutters etc ain't traditional either but we still use them everyday to build our dream cars ;)
  15. Beanscoot
    Beanscoot
    Wow, those look great!
    Deuces likes this.
  16. Fortunateson
    Fortunateson
    Your buddy has talent. He could do a few at a time of those that are difficult to find.
  17. abe lugo
    abe lugo
    I like the ones above but those still needed some clean up. Or light sanding to make the clear and tint stick. A this point they are printing some cool stuff. But once again. Save up and buy the real deal. You will eventually find it at and ok price if you wait it out.
    Otherwise have a friend that can print some out and you can just spray them red tint. Nevermind having the know how to make 3D files and set them up and all that tech mumbo jumbo.
  18. DesmoDog
    DesmoDog
    Those look good. I'm guessing he's not using a machine that melts layers of filament together though.
    Inexpensive FDM printers that use spools of material are not creating parts that look like that.
  19. zman
    zman
    from Garner, NC
    LMAO, all the naysayers. I just bought a roll of translucent red filament to prototype some lenses. I'll prototype in PLA and then move on to probably PETG if that doesn't last I'll do ASA. Just like the 50's bro.
    Bob Lowry and AndersF like this.
  20. zman
    zman
    from Garner, NC
    And if you know how to tune your printer for the filament there is very little cleanup needed these days.
    Bob Lowry likes this.
  21. guthriesmith
    guthriesmith
    Looking forward to how those come out @zman. That technology keeps getting better and this idea brought up back in 2017 is more feasible now than it was then. Every new 3D printer we get at work has much better capability than the one it replaced. Cool technology for making stuff like this.
  22. chickenridgerods
    chickenridgerods
    from DSM, IA
    ASA is a better choice for longer term UV stability. Granted, if it fades or becomes brittle you can just print and finish another replacement part.
    Be prepared to need to sand and polish the surfaces, though.
    Bob Lowry and Jeff34 like this.
  23. dirt car
    dirt car
    from nebraska
    Back in the day recall seeing those Olds hydramatic deck emblems turning to white granular beads of plastic & crumbling away on examples of vehicles that had very little if any garage time, in today's world most reproduction plastic would do just fine on a restored or custom that is properly protected.
  24. rusty1
    rusty1
    check with skipstich on here, he knows his stuff
