Technical Is this normal ?
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Sep 7, 2021.
  1. Dino 64
    Dino 64
    from Virginia
    So I have a 350 crate which I bought about 4 years before it was started. It was properly primed with the correct tool and oil was visible on both heads before it was started. After 500 miles I changed the oil for the first time today. Attached is a pic of the bottom of the drain pan. I edited the pic to increase contrast to bring out the specs of metal visible. They are very small. Full disclosure, I did not rotate the engine during storage.
    Jalopy Joker and Just Gary like this.
  2. squirrel
    could be.
    Is the cam still working?
  3. Atwater Mike
    Atwater Mike
    Hate these SBC visual signs... flattened a few bump sticks in those monsters...
    Deuces and Dino 64 like this.
  4. Paulz
    Paulz
    Seems a little excessive. Cut the filter open and see what's in there.
    egads, Deuces, LWEL9226 and 2 others like this.
  5. indyjps
    indyjps
    Pull the rockers and do some investigating on valve tip height as its rotated. See if any cam lobes have gone flat. Whatever ***embly lube that was used dried up or dissolved before it was fired.
    If you find a dead cam, good time to swap in something better.
    Or just keep driving it and see what happens:D hencho in Mexico small blocks may have some "self clearancing" clearances. They may have all been that way when new.....I never bought a new car that had a SBC.
    Dino 64 likes this.
  6. jaracer
    jaracer
    That would scare me.
    Dino 64 likes this.
  7. Jalopy Joker
    Jalopy Joker
    next time do not wait for 500 miles to change oil
    LWEL9226 and Dino 64 like this.
  8. Lloyd's paint & glass
    I'm kinda in the camp that says if it was still running fine, no oil pressure issues, i would put new oil and a filter in it and fire it up, run it around the block a few times, and change it again. Like he said up there ^^^ tear that filter open and see what's in it.
    SS327, tommyd, Deuces and 5 others like this.
  9. Dino 64
    Dino 64
    from Virginia
    Thanks guys, just got the alert from HAMB. It’s running really well. It doesn’t heat up at all. I just put in a new filter and fresh oil. Break in lube added before start up. I’ll drive it a bit and change the oil again as suggested. Don’t have a warm and fuzzy feeling about this. :rolleyes:
  10. oldiron 440
    oldiron 440
    It could be better and it could be worse, I'd run it until it was a problem.
  11. lothiandon1940
    lothiandon1940
    Good luck, Dean. Hope it works out.
  12. gary macdonald
    gary macdonald
    Change oil , cut old filter , inspect . Add magnets to both rear of valve cover oil drains ( dont block them ) for a quick visual check . Make sure you use oil with plenty of zinc .
    Dino 64 and Just Gary like this.
  13. Dino 64
    Dino 64
    from Virginia
    Thanks Don, we’ll see……
    lothiandon1940 likes this.
  14. BamaMav
    BamaMav
    from Berry, AL
    Probably a combination of machining debris that didn't get washed out and normal break in wear. You said you had to magnify the pic for clarity, so if it's that tiny, I wouldn't worry about it unless you see a bunch more when you change oil again. But it's not my engine, so worry if you want...
  15. Dino 64
    Dino 64
    from Virginia
    Who wants to worry ?? Gonna cut open the filter I just removed, run it, change it again and see. Hope you’re right
  16. Budget36
    Budget36
    You could send an oil sample in And have it ****yzed, then find someone smarter than me who could tell you where the metal came from.
    loudbang, Dino 64 and VANDENPLAS like this.
  17. Dino 64
    Dino 64
    from Virginia
    It came from Mexico :eek::rolleyes::)
    Budget36 likes this.
  18. Was the drain pan absolutely clean? If it's not giving you trouble, run it for awhile, and drain it into a clean gl*** baking pan. Why jump off the cliff, when all you want is a better look.
    Dino 64, Deuces and Just Gary like this.
  19. 56don
    56don
  20. Deuces
    Deuces
    Dino 64 likes this.
  21. Dino 64
    Dino 64
    from Virginia
    Don’t think I mentioned jumping off a cliff …….:cool:
  22. catdad49
    catdad49
    Dino, what was the prognosis?!
  23. Dino 64
    Dino 64
    from Virginia
    It’s all good ! Changed the oil and filter, ran it for a while, changed the oil again and it was clean. Probably as previously stated, just some ‘dust’ from the machining and casting. Thanks for asking
  24. catdad49
    catdad49
    That's Good News!
    lothiandon1940, Dino 64 and Budget36 like this.
  25. lothiandon1940
    lothiandon1940
    Fabulous news there.
    brady1929, catdad49 and Dino 64 like this.
  26. Joe H
    Joe H
    Bad camshafts leave micro size bits of iron and steel, not chunks, they wear off a little at a time. Stick a magnet in the old oil and see wha type of metal it is. I like a large magnet on the bottom of the filter and one at the drain plug on the bottom of the pan. Pull the magnet off the pan before draining so the oil flushes any contaminates out. You would have a misfire if it was the camshaft or valve train.
    Dino 64 likes this.
  27. dirt car
    dirt car
    from nebraska
    The Mexico built small blocks had an issue with I believe the cam or crank moving front to back changing the timing & also creating metal chips, Paul at the "Cars" rod shop in Omaha correctly diagnosed the issue.
    lothiandon1940 and Dino 64 like this.
