Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. seb fontana
    seb fontana
    from ct
    I found where wire #120 on the fuse block goes to by scrutinizing my wiring diagram and then checking in the car, Horn relay. Success!
    alanp561 and TA DAD like this.
  2. X-cpe
    X-cpe
    Have you thought about making an extension for the handle. It can be made at any angle from the existing handle as long as it moves the hand grip area further away from the pivot point.
    TA DAD and LAROKE like this.
  3. Blue One
    Blue One
    from Alberta
    A balmy sunny 59 F day so I’m out putting some kilometres on the RPU.
    CE1D79A9-1696-4BAB-B5D9-E6AC4B5153A2.jpeg 0363D0EB-2AAD-434A-A9FB-04CCC7426FC0.jpeg
  4. 57 Fargo
    57 Fargo
    I put about 90 miles on the big Chrysler convertible yesterday in about the same temperatures…with the top down of course.
    61Cruiser, blowby, Blues4U and 4 others like this.
  5. A 2 B
    A 2 B
    from SW Ontario
    DSC06940.JPG I came to the conclusion that it made no sense having running boards on a channeled A. It made it too hard to get in and out of the car. Decided to eliminate them. I made up a set of rocker panels that will resemble 32 frame rails and configured the fenders to fit. More to do before the lead work but the end result can be visualized. A bit different and seems to compliment the narrowed front fenders. This car is deceiving in the pics. I am 5'10" and the roof is at armpit height. If I decide to chop it will only be 2" and will be the last thing I do before paint. DSC06933.JPG
  6. LAROKE
    LAROKE
    That's a good idea. I might try that. The last time I tried to use it, a friend lent me his professional tool which worked for me. I compared the two, side-by-side, and was puzzled by the reduced leverage geometry of the newer types.
    TA DAD likes this.
  7. 57 Fargo
    57 Fargo
    Started out the day stressed about life, decided to drive the Fargo to work as some stress relief. Mission accomplished.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So great to finally meet you and check out your projects. I can't wait to put those brakes to work on the front of the roadster!
    gimpyshotrods likes this.
  9. Blues4U
    Blues4U
    from So Cal
    Good decision
  10. blowby
    blowby
    from Nicasio Ca
    Primered my shoes. Got some on the car too. Then went to the annual church rummage sale, bought a dwell tach and a shift knob for $5. 20210916_170652.jpg 20210916_134120.jpg
    Blues4U, High test 63, A 2 B and 4 others like this.
  11. gimpyshotrods
    gimpyshotrods
    Today I knocked out a quick EGR block off plate for my Falcon.
    The previous one leaked a little.
    A 2 B, TA DAD, j hansen and 1 other person like this.
  12. topher5150
    topher5150
    Just a friendly reminder when you're disconnecting your 100' air hose use two hands and don't put your face over the air compressor.
    alanp561, WalkerMD and Elcohaulic like this.
  13. 325w
    325w
    Finally got my speedo corrected to within 1 mph of what the GPS says. Next is to get the steering wheel centered to where the turn signal switch is happy
    Blues4U, A 2 B, j hansen and 2 others like this.
  14. gimpyshotrods
    gimpyshotrods
    It's the little things that drive a man crazy.
    I must have my wheel correct!
    Lil32 and alanp561 like this.
  15. gimpyshotrods
    gimpyshotrods
    I need to do that. My ignition timing is controlled by non-traditional means.
    My timing mark is almost always obscured by the water pump, nowhere near the tab.
    Elcohaulic likes this.
  16. Elcohaulic
    Elcohaulic
    LOL It only took me three years to do this one..
    alanp561 and gimpyshotrods like this.
  17. alanp561
    alanp561
    Started running brake lines, all the while sitting there making "Vrooom, vroom" noises.:) 20210918_144057.jpg
    LAROKE, High test 63, A 2 B and 6 others like this.
  18. topher5150
    topher5150
    DOOOOOIUBLE PUMPEEEEEER
    LAROKE, High test 63, TA DAD and 4 others like this.
  19. blowby
    blowby
    from Nicasio Ca
    Took the wife out for breakfast. First drive that wasn't a test drive! I did adjust the carbs though..
  20. Almostdone
    Almostdone
    I have and still use the same dwell/tach - bought it new in the late 1970s. Don’t have a shift knob like that one though. Good day for you.
    John
    blowby likes this.
  21. chromedRAT
    chromedRAT
    Put a new transmission in the T truck last night (my little boy worked the jack- he's a good hand) and drove the hell out of it today.
  22. David Gersic
    David Gersic
    from DeKalb, IL
    Drove about an hour south to the only place I could find that had CO2/argon MIG gas in stock. Seems to be a shortage of gas now for some reason.
    Since it was an evening trip through the cornfields, and it’s harvest time, I also killed a ****load of bugs. At times it looked like a Star Wars movie with the headlights reflecting off all the bugs.
    Guess I’m washing the car tomorrow. Maybe I’ll also get back to the project I needed the MIG gas for.
    Lil32 likes this.
  23. TA DAD
    TA DAD
    from NC
    Is this a test ? dual line - single accelerator pump vacuum secondaries.
  24. TA DAD
    TA DAD
    from NC
    How does it go ? " I get by with a little help from my friends " my push rods were to long , so after getting 5 different length ones from a couple buddies I ordered a set that will get me where I want to be on the valve tip ( I hope ) checked TDC . I gave the heads one more bath and set them in place only to find that the springs won't allow me on one bolt. So now to find a couple bolts to solve that issue. studebaker build 003.JPG studebaker build 007.JPG studebaker build 005.JPG
    Dogberg, LAROKE, A 2 B and 4 others like this.
  25. alanp561
    alanp561
    Aw, c'mon man. You're gonna break his heart like that. You should have PM'd him with that answer;)
    hammer-time likes this.
  26. topher5150
    topher5150
    I'm just so devastated I don't know how I'll carry on with this lie
    blowby likes this.
  27. jimmy six
    jimmy six
    Went to a Picnic 800 of my closest hot rod friends and about 500 cars. Missed on the $2500 50/50. Photos don’t mean much it’s tough to get high enough. Tri-tip, beans, potato salad, & roll. 35AA2750-6349-473C-91C0-8D6032CD996B.jpeg 3FAFD964-4E6D-445D-AA89-6640C18DEA99.jpeg 5F3ABE95-E8A1-4C31-A343-356515CC8905.jpeg 4B1BDF39-FEF4-4C79-88AA-1F010C8621FC.jpeg
  28. dana barlow
    dana barlow
    from Miami Fla.
    Rained nearly all day,so did what I had been putting off,now that I had the parts (new mount) just hanging around for a few weeks for my black 28A.
    I worked in the shop ,replace my hot rods ****** tailshaft rubber mount.
    I really should of turned on the shop AC,but low on $ and that it should not take long,stopped me from being smart.
    It was hot as hell,so I opened the big door,nope wind n rain made that way to cool off shop the wrong thing.
    Did get it done,after fooling around for 2 hr. on what should of been a 20 min. job. I had to take a shower after an a nap !
    I don't take in my age on timing thinking,79YO ,I should though,but it go the other way to my head thinking I'm as good as I was @ 30 .
    billybones, Dave Mc, Blues4U and 17 others like this.
  29. Lil32
    Lil32
    having trouble with a brand MSD getting spark to new coil,rod will to fire
    mate has taken away for testing,he is thinking module
  30. Deuces
    Deuces
    Me???.... Looked at it and smiled....:):D:)
