1952-59 Ford 1956 2 dr. sedan vs '56 Crown Vic frame
Discussion in 'Off Topic Hot Rods & Customs' started by Joe Tx, Sep 8, 2021.
  1. Joe Tx
    Joe Tx
    I have a '56 Crown Vic and the frame was butchered and needs all front suspension replaced also. It also had some terrible welding done to it......I also have a '56 2 dr. sedan with an excellent frame that has been gone through and has had all suspension parts replaced. Are these frames interchangeable? I was looking on the web for a body to frame bushing kit and found a couple on ebay. The seller says that his kit (B5A-5001 -- "55 56 1955 1956 FORD 2 & 4 DOOR SEDAN BODY MOUNT KIT") will not fit a Crown Vic??? If so, does this mean that I can't use the sedan frame under my Crown vic?
    The Crown vic has power steering (leaking terribly) and the sedan does not have PS. . I was thinking of doing away with the PS and go to manual steering on my Vic when using the sedan frame. Here's a picture of the sedan frame I wanted to use.
    How about some recommendations on finding a body mount kit that will work for me. Thanks, Joe.
  2. frnkeore
    frnkeore
    If you get a factory shop manual for the '56 Ford (you really should have one for a frame up restore), that info will be in it.
    They have a section on frames with drawings of the frames, for all models, mounting points and dimensions as well as differences for them. I only have ones for the 52-53 & the 54 supplement. The next one I have is for the '60 so, I can't help but, maybe someone has the '56 manual that could help you.
  3. Dave Covey
    Dave Covey
    Frames are the same. Although there are some additional brackets. I have a 55 Victoria and the body to frame kits for a standard Fairlane are short like 10 bushings/bolts. I would set the frames side by side and transfer the brackets from your old frame to the one you are going to use. Anyway that's my opinion.
    Dave
    danman55 likes this.
  4. jimmy six
    jimmy six
    I can’t imagine the basic frame being different but the mounts probably are. If your going to change the frames. You’ve take the coupe body off so you know what’s needed. Place the 2 frames side by side and move body mounts as needed. As said above. Good luck..
    Kustomline54 likes this.
  5. Dos Cincos
    Dos Cincos
    Victoria's and Convertibles definitely have an extra support on each side where there is no B pillar. Not sure if the Crown has that extra support or not.
  6. okiedokie
    okiedokie
    from Ok
    Sunliner frame has full X member, don’t know about Victoria.
  7. Joe Tx
    Joe Tx
    Thanks for all the input, good info, and Okie, the Crown vic frame is almost identical to the yellow sedan frame pictured above. No X member.
  8. frnkeore
    frnkeore
  9. Will_K
    Will_K
    X frame is convertible only, Crown Vic is treated as a hardtop.
  10. frnkeore
    frnkeore
    That brings up a question that I've had, for a long time. Is the "Crown" area, across the side window, a door post or, is it just ginger bread?
  11. Joe Tx
    Joe Tx
    I have that manual but the frame section only mentions that the Victoria and Crown vic have some extra body mounting brackets and capping strips are welded to the bottom 20210917_200645.jpg 20210917_200720.jpg of the members.
  12. Paul2748
    Paul2748
    There is a body post behind the chrome piece
  13. Joe Tx
    Joe Tx
    Well, don't know about ginger bread, but I've always thought that this car was basically a 2 door post, except that the B pillar was slant forward! 20180428_104428 (2).jpg 20180428_104428.jpg
  14. T Hudson
    T Hudson
    Hmmm, a post car with a hardtop door.
    Joe Tx likes this.
  15. frnkeore
    frnkeore
    This is the area of the manual that I'm referring Frame.JPG to.
    fordsbyjay likes this.
