Hot Rods '56 GMC on my drive,
Discussion in 'The Hokey Ass Message Board' started by dentisaurus, Jun 5, 2017.
  1. 59chev
    59chev
    Rusted headlight eyebrows are common. The explanation I got from my Grandpa ( he had one when it was new ) was that mud would get kicked up off the tires, and pack in between the headlight and the fender and rust the fender from the inside. The other common spots are the cab corners, driver and p***enger floorboards, and the front of the rear fenders. That truck looks pretty solid. I had almost a foot of metal missing in one of my cab corners. Check out the earlier pics in my build thread as mine had rust in all those areas. I drove my truck for almost 5 years with a 261 - 6 cylinder and the stock 3-speed and rear end. The column shift was wore out so I put a Hurst truck shifter on the original transmission. Biggest problem was the the rear end had the stock 3.90s in it which meant it would top out at around 50 MPH.
  2. dentisaurus
    dentisaurus
    from Boston
    [​IMG][​IMG][​IMG]
    Spent a bit of time pulling the gas tank today. Seat looks like it will be fine with just a new cover but the tank is history. Only the paint holding it together, nothing left of the pickup tube and sender float!
  3. flatford39
    flatford39
    If those are the original floors you are very lucky and way ahead of the game. Nice truck.
  4. sololobo
    sololobo
    score - I love these trucks, the big back window is way cool. If that 270 runs it would be a nice daily with a split manifold and some twice pipes.
  5. 59chev
    59chev
    Floors look great!! I had big holes in mine that I had to patch.
  6. 59Apachegail
    59Apachegail
    from New York
    Floors are spotless!
  7. 56sedandelivery
    56sedandelivery
    When it comes to the overdrives these trucks, and cars, came with, is it almost costs as much now for the relay, wiring harness, and switches, as the cost of one of the Muncie 319 overdrive transmissions. That says something about making your own setup to control the overdrive. I happen to have THREE of the Muncie 319 overdrives on hand. I never cared for the "CARS" movies style front grille and bumpers on the early GMC's. Chevrolet grilles bolt in, from what I hear, and patch panels for these trucks are available. Years ago, I had an Ex-NAVY, 58 Chevrolet 3/4 ton, with the aircraft carrier length bed. It was still NAVY gray/grey. Somewhere in it's life, someone had installed a 55, 4 barrel, 265. I snapped the input shaft on the transmission one day leaving a stop sign, normally; it snapped right where the input shaft necks down at the end of the throwout bearing/retaining collar. I had another Muncie 318 transmission from a p***enger car that I replaced the broken one with. Always thought it odd the top two transmission to bellhousing bolts thread into the bellhousing, but the two lower go from the bellhousing into threaded holes on the transmission. P***enger cars are't that way, only trucks (???). Anyone have an idea of why that is? Nice start for an old truck; should have kept mine, but it's been 40 years now. I am Butch/56sedandelivery.
  8. dentisaurus
    dentisaurus
    from Boston
    Got a little bit done to the truck this week. Gas tank and floor are done, mixed my own Rustomleum to something close to the original GMC gray. Brakes are almost finished and I scored a 3 speed with overdrive complete with the original relay, kick down switch and lock out lever. Result.
  9. squirrel
    looking good!
    Stogy likes this.
  10. Atwater Mike
    Atwater Mike
    Rare ******... Say, guys. What is a 'NAPCO' setup? (I'm more of a Ford guy, is it something GMC exclusive?)
  11. squirrel
    NAPCO is the company that converted Chevy pickup trucks into 4x4s. Chevy started building their own 4x4s in 57, I think NAPCO continued for a couple years then quit.
    Hamtown Al and olscrounger like this.
  12. Atwater Mike
    Atwater Mike
  13. s55mercury66
    s55mercury66
    from SW Wyoming
    Yes, Chevy began building 4WD trucks in 1957, using NAPCO supplied parts through 1959. With the redesign for 1960, that came to an end.
    olscrounger likes this.
  14. wvenfield
    wvenfield
    Find a Pontiac 316.
  15. dentisaurus
    dentisaurus
    from Boston
    316 not really an option right now. The 270 seems to be in good shape and I have a soft spot for straight 6's but I'll bear it in mind should I need a new motor
  16. dentisaurus
    dentisaurus
    from Boston
    Been a while. As usual life got in the way.
    Finally got my truck running this week, the 6 purrs along .
    I got my brakes working , spent ages fiddling about to get the adjustable rod between the master and the booster the right length.
    Took it for the maiden spin around the block, not quite what i was hoping for.
    Initially I thought the brakes were still dragging but no, busted rear axle!
    Nasty clunk from the rear and the truck wanted to stall out as I pulled away.
    Jacked it up and when i spin one rear wheel, the other remains stationary.
    Might be time to go find a 10 bolt with 6 lugs. Any one know of a similar size rear axle that might work?
    Guess I should open it up and take a peek. Not tonight I'm afraid.
  17. squirrel
    bummer. 1960s trucks had a similar size rear axle, Chevys usually had coil springs and a truck 12 bolt, GMCs usually had a ****er 44 or 60 (yours might have a ****er 40?)
    Stogy likes this.
  18. dentisaurus
    dentisaurus
    from Boston
    Been a long time since I posted an update. Or even signed in on the H.A.M.B.!
    Been puttering around on the stock drive line for a few years and decided to change things up. I scored a complete 76 XJ6 so time for independent suspension and a cross flow head
    Front suspension and engine are mounted. Need to build a trans mount next. Also messing about with a home made triple carb set up using a set of Harley carbs. I liking it so far.
    41 GMC K-18 and '28phonebooth like this.
  19. jimmy six
    jimmy six
    Crazy but kool..Stick a GM sticker some where and tell folks it’s one of the cammers from the 90’s. I’ve seen 3 S&S’s on a 261 Chevrolet 6 so y-not. What’s the trans? Keep the photos coming..
    41 GMC K-18 likes this.
  20. Downplay the IFS so the site poelese don't bump you
  21. Motorwrxs
    Motorwrxs
    Would love to see a pic as the how the hood badge is fastened to the hood. My 1957 GMC that I just got about a month ago and some sheet metal brackets holding the stainless steel insert to the hood…rattles like nobody’s business…
  22. dentisaurus
    dentisaurus
    from Boston
    Sure , though I got the how to on this from this very site so hopefully it won’t be a issue
  23. dentisaurus
    dentisaurus
    from Boston
    I’ll get some pictures of what I have tomorrow
    Motorwrxs likes this.
  24. dentisaurus
    dentisaurus
    from Boston
    Stock jag auto trans for now but eventually it’ll get a T5
    jimmy six likes this.
  25. dentisaurus
    dentisaurus
    from Boston
  26. Motorwrxs
    Motorwrxs
    Thanks for the pic…are those tabs attached to the hood or are they part of the hood and just bent around the insert? Thanks again for posting the pic.
  27. lcfman
    lcfman
    from tn
    I like your build and probably many others do also as was said watch out for Barney Fife he is lurking around.
  28. dentisaurus
    dentisaurus
    from Boston
    Looks like the tabs are part of the hood sheet metal.
  29. Motorwrxs
    Motorwrxs
    Appreciate you taking the the time to help me out… have to see what I can come up with.
