Technical The upholstery thread to end all threads
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 5, 2021.
  1. Roothawg
    Roothawg
    They use it on all marine stuff. So the foam doesn’t mold. Sail Rite has a lot of good videos on YouTube.
    3quarter32 and loudbang like this.
  2. reyn
    reyn
    Uwe Grosse has a great video on adjustments to a Juki or Consew. If this link doesn't work do a search for his name on you tube.
    loudbang, 1-SHOT and Roothawg like this.
  3. 1-SHOT
    1-SHOT
    from Denton
    Thank’s for taking the time to post this information. Frank
  4. jakesbackyard
    jakesbackyard
    from ND
    I have used silk film for many years for furniture cushions and seat back rests. It works great on the backrest of a split back bench seat. Rest the backrest by the arm on a table top, d**** silk film over the whole thing, stick a vacuum wand up from underneath and inside the springs, turn on, it ****s it down and you slip the cover on. Position cover, take vacuum out, and tear out as much silk film as you can. It’s slick!
  5. Whoamel
    Whoamel
    from So Cal
    Whoops!
    This panel is one of three trim panels for the back of my '40 Ford Coupe. I used 1/8" foam and (clearly) I fubar'd this one up. These panel clips are on the top side underneath the foam and vinyl.
    Should I maybe have used 1/4" or 3/8" foam and hollowed out the foam underneath the clips?
    Any tips suggestions greatly appreciated!
    Thanks!
  6. 3quarter32
    3quarter32
    What kind of clips are those, christmas tree type? I like the Auveco 808 clips and use a bit of duct tape to smooth out the clip tops and keep them in place.
    fauj and loudbang like this.
  7. Whoamel
    Whoamel
    from So Cal
    Yes, it has a different p/n, but it is as you described. Suprisingly, it has a very low crown top, and it appears mostly flat when you look at them. They look huge under the vinyl, though :)
  8. 3quarter32
    3quarter32
    Maybe make a hole in your foam large enough to accept the head and cover the top of hole with tape to prevent your vinyl from ****ing down into the hole. Is the foam glued to both panel and vinyl? I have used a bit of heat to release the glue.
  9. Roothawg
    Roothawg
    So, don’t look too close but mama and I decided to try our first real project. We needed a console to hold our cups, but the 35 cab is made for little skinny folks from the depression that didn’t get to eat as much.
    We made some mistakes and learned a lot. It’s pretty simple, but it’s project number 1. Now we just have to do 20 more to make it pay for itself.
    The seat was previously done by a professional. I always order more materials than I need, for reasons just like this.
    Nothing fancy, but a year ago I would have just stapled some vinyl on it an hoped for the best.
    Let the hazing begin.
    brEad, engine138, Just Gary and 14 others like this.
  10. 57 Fargo
    57 Fargo
    Nothing wrong with that Root! Looks good
  11. Roothawg
    Roothawg
    Thanks. It has plenty of room for improvement, but it’s a start.
  12. 1-SHOT
    1-SHOT
    from Denton
    If you use two layers of fiber board or what ever you are using and put the clips in the first layer and then glue the second layer over it you won’t have that problem
    loudbang and fauj like this.
  13. Whoamel
    Whoamel
    from So Cal
    It is an aluminum panel that I am recovering. I ended up gluing a piece of 1/8" foam on it, then I carefully recessed the clips into the foam so everything was very close to the same height. I then added a second layer of 1/8" foam over it which came out nice. I checked the trash and noticed the original foam was 1/4" so that was my "ah-ha!" moment.
    I'm going to cover it tomorrow, and it should be just fine.
    Thanks again for the tips. I appreciate the help.
  14. Lloyd's paint & glass
    Yeah, take the clips out, put them in your strong hand, and throw them in the garbage. Go buy a roll of industrial velcro. Works great.
    Lone Star Mopar and fauj like this.
  15. Lloyd's paint & glass
    Lmao! The only way you learn is by doing it man! And it's not easy, that's been the easiest lesson so far. It'd be a lot easier if you had somebody standing there that you can show your mistakes to, that could say "this is why that happened". Yours looks great, and you'll only get better. Figured out that when applying welt, if you are stretching the material while you're sewing on the welt, it gives you the pucker in your welting. I had to get my wife to stop "pulling" the material, and let the machine do the work lol
    loudbang, fauj and Roothawg like this.
  16. ZZ Top Chop
    ZZ Top Chop
    Sorry for the lousy photo, but why is my s***ch as crooked as a politician?
  17. stanlow69
    stanlow69
    @ZZ Top Chop If you look closely at the right s***ch line, you will see the knot. It needs to be centered between the two layers of material when sewed together. You should not be able to see the knot from the bottom side or from the topside. So loosen the tension on the top side or tighten the thread tension on the bottom side.
  18. ZZ Top Chop
    ZZ Top Chop
    Thank you, I'll give it a try. Also I may have found out why my s***ch length is not long enough. I took the wick try off and looking down at the feed collar, the screw is broken. Been looking online for one, I'll post a pic.
  19. ZZ Top Chop
    ZZ Top Chop
    I think this maybe the reason my s***ch length is off. The screw that attaches to the feed collar is broken. (Consew 206RB-1). Can someone point me the right direction on where to find one? I don't know the correct name either. Update: part name is Consew #18011 Screw. Still can't find one for sale 20210930_150951.jpg
  20. She is feeding you outta dog bowls now?
  21. Roothawg
    Roothawg
    Yep, but to be traditional I need to carve them out of a cypress log.
  22. 3quarter32
    3quarter32
    If you think it is still a good machine and have all the screw pieces, a good machine shop could make one. Even try a gun smith shop.
    loudbang and ZZ Top Chop like this.
  23. K13
    K13
    Have you contacted Consew to ask them where you might find it?
  24. junkyardjeff
    junkyardjeff
    Singer parts might work since I heard they are exact copies of Singers.
  25. Mimilan
    Mimilan
    I have not read this whole thread , [so this could already be answered] but usually the crooked s***ching is the machinist, not the machine.
    If the machine is feeding OK with the correct foot pressure , you need to change your technique.
    My husband Kerry can sew arrow straight ,and do a pair of single s***ches that look consistent with a twin needle machine.
    His technique is to lead with one hand behind the machine and the other in front [basically holding the fabric like a "hacksaw"]
    This allows him to feel the s***ch length, and hold consistent tension on the fabric.
    A real handy technique when sewing a piece of bias cut fabric to another piece cut straight on the "warp or weft", and also if you have an issue with stretching along seams ,Is to use cellotape on the fabric. [this perforates and can be peeled off later]
    Cellotape is a must on soft leathers and sheepskin
    Consew [Juki heavy industries] is metric.
  26. ZZ Top Chop
    ZZ Top Chop
    It's not me, it's the machine out of adjustment. The holes are straight, s***ch is crooked
  27. ZZ Top Chop
    ZZ Top Chop
    I emailed them this morning, we'll see.
    K13 and loudbang like this.
  28. loudbang and Roothawg like this.
  29. Roothawg
    Roothawg
    loudbang and Tman like this.
  30. F-head
    F-head
    Here’s a seat I just finished up for my 47/1 coupe C5B31E1F-E8F4-4207-B666-1BF876CEBC9B.jpeg F5E0411F-5E26-436D-9B38-EC182466E9D3.jpeg 154306E1-0BE6-4B49-BAEB-77229E897B65.jpeg E60FEE47-F8A6-4C66-980B-07D55FEC743C.jpeg
