Technical Tech Week how to fill trim holes
Discussion in 'The Hokey Ass Message Board' started by 55willys, Oct 4, 2015.
  1. 55willys
    55willys
    I use a Whitney hand punch to make 16 gauge 1/4" plugs. I just use masking tape to hold the plug in place if I can't smash it to fit. Normally with a 1/4" hole and 16 gauge plug, a couple of whacks with the body hammer against the dolly will expand the plug to hold tight.
    stillrunners likes this.
  2. To dredge up a slightly old thread... to hopefully add a bit to it. Just found this video and it had an excellent DIY way to achieve what I did with a Jewelers disc cutter. Hope it helps someone out.
    David Gersic likes this.
  3. blue 49
    blue 49
    from Iowa
    Where I used to work, we used these to punch shim stock so we just called it a "shim punch". I have one in my tool box.
    Gary
  4. NoelC
    NoelC
    Just thought I'd mention for clarity and understanding the cheap stuff used for gas welding has an AWS cl***ification of R-45, isn't a deoxidized wire and should be used for gas welding low carbon steel only as a best practice.
    The GTAW wire your using from Italy, AWS cl***ification ER70s-2, it's a deoxized wire and one of a few in that cl*** of wires that would be suitable.
    Using the R-45 for GTAW will result in a porous, porosity filled weld when ground down.
    55willys likes this.
