Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Tim
    Tim
    from KCMO
    Making progress.
    super crazy couple of weeks. I’m gonna just post it all at once at the end I think :)
    drdave, loudbang, Dan Hay and 3 others like this.
  2. -Brent-
    -Brent-
    HOW DARE YOU!
    Give us some sneak peaks. We like seeing people make some progress around here.
    Stogy, Thor1, loudbang and 2 others like this.
  3. Tim
    Tim
    from KCMO
    brEad, Stogy, Thor1 and 3 others like this.
  4. Six Ball
    Six Ball
    from Nevada
    That looks like a stock Ford ignition tool set. :rolleyes:
    brEad, Stogy, loudbang and 3 others like this.
  5. -Brent-
    -Brent-
    ^^^ This man knows "percussion tuning" tools! Haha
    Stogy, loudbang, Thor1 and 4 others like this.
  6. Tim
    Tim
    from KCMO
    Well I was going to wait for my two weeks to be over to post an over view of what got done but life kinda ramped up. So for the moment I figured I’d do a photo dump and get some of the stuff up to speed.
    One of the first things done I get my new master cylinders taped and painted and the holes to mount them drilled.
    well as much as I could, a few holes go into the plate behind the firewall where an existing hole doesn’t exist so I drilled threw the firewall and into the plate enough to be an easy spot to find when it lands in the drill press
    minuses centering lunches but where it wasn’t going to work with only two hands I made a cereal box template and used that B4CCF40E-5606-4D23-A2DC-AFD322B438C7.jpeg F3442768-861D-48E5-801B-D592B74612AC.jpeg B2E92E5E-6DFE-4DD8-B9E2-B1967AB5B5B3.jpeg 3E5E4D5D-4C2D-436E-847A-5EF3759272F5.jpeg E6A9D283-F025-474E-97C8-C2A740E0F7B7.jpeg DEBB8CE3-3F0A-4547-814D-DD8FFEEAF73F.jpeg F6D7F6DB-09A1-433B-BC61-B22573BA607A.jpeg 8E0B4400-BCAC-4BB4-8D9B-D6BBC1D58E30.jpeg
    brEad, Joe Blow, loudbang and 4 others like this.
  7. Tim
    Tim
    from KCMO
    At the same time I drilled the holes and mounted the oil filter. The photo with the vice grips is there to show exactly why I’m welding nuts to the back side of the firewall. I hate having to figure out how to be in two places at once for bolts like that 1D7FFF34-EBDA-4D12-BA0F-1BEB16EB6ACF.jpeg 8D4000AB-1A83-49C5-9BB4-19FDFE7FB8C1.jpeg DF7267E6-9DBD-4EB3-BA68-A28F8F133AE3.jpeg 57283555-638F-4239-A245-DAE8F949057F.jpeg E9F1CA27-C1AE-47A8-8E59-1E127C0CC678.jpeg
    Joe Blow, drdave, loudbang and 4 others like this.
  8. Tim
    Tim
    from KCMO
    Drilled, indexed and trimmed all the floor gussets 75324289-9376-453E-9459-BF9D09A7F3A0.jpeg 93088251-FFD7-47C9-AD3C-4BCF6FD1E280.jpeg 6753A4AB-F708-4E9E-A66A-A352A5652DEE.jpeg
  9. Tim
    Tim
    from KCMO
    Trimmed the air cleaner bottom and painted it. Also painted the rear lower shock mounts - cut and welded/ evened out 46 Ford pieces E9FD0A2C-7CEA-4D43-8447-6AF4DEA32377.jpeg F01ABCAC-1061-4426-8DE8-6D839B9FB894.jpeg 8E357506-AD65-40F5-8BBE-41CC208BDC7A.jpeg F7953ED7-7B9F-412C-B2FD-89E83447C6CC.jpeg BEDF0FB5-CB67-4D03-8E37-0C0ABDE51C7D.jpeg DBD86D7A-3212-43AA-800D-3643C10ADC18.jpeg D6A3021B-B6AE-48EB-89C2-1CA3987A44F5.jpeg
    brEad, Joe Blow, drdave and 4 others like this.
  10. Tim
    Tim
    from KCMO
    Got my air cleaner top back from being brazed together and the spreader bar back welded.
    ended up using the stock ends of the spreader bar with new pipe in between. In retro spect a heavy wall pipe may have been better as it was difficult to weld the thunder tube to the very thick Ford ends
    painted them both C39F0705-ED2B-43D7-9399-3C1AA689A00F.jpeg 17C289F3-50AE-4711-9550-5355FFC32318.jpeg 10099ECA-327F-4539-9E32-34EA0C4BE8EE.jpeg 133F944F-B2B4-4436-B17A-73296AA72C94.jpeg 61345DE7-0384-4CC4-A669-195F03D2112F.jpeg
    random photo of knick knacks that belong to the project seems to got included. Oh well lol
    brEad, Joe Blow, drdave and 5 others like this.
  11. Tim
    Tim
    from KCMO
    No real photos after that point FBCAD8F6-61F9-4DAA-8525-150766703C7A.jpeg car has a killer rake in person. I’ve been cutting/ adjusting my tacked in sub frame getting it dialed in to have the rest of it final welded soon and working on drilling body mount holes.
    I spent for ****ing ever marking them out and 5/6 top holes are dead on but the bottom holes- I’m drilling threw box tubing with a hand drill- drifted on a lot of them.
    I drilled the holes under sized for partially this reason. Current plan is to oval the holes to get everything lined up and then when we weld in crush tubes fill what ever gaps may exist
    going to try to get to oval-ing them this afternoon and then I think the spreader bar to frame irons will get cleaned up one way or another and the column drop mounting holes drilled.
    then I think I’ll pull the tank off and correct the misalignment in the firewall/cowl bracing and drill the master cylinder/ pedal box while it’s apart
    Anyhow. Plenty to come, stay tuned
  12. Six Ball
    Six Ball
    from Nevada
    Man that is a lot of component prep. I'm trying to do some of that too. Remind me why you went with a remote oil filter. I'm doing that too and in some ways it seems silly when the screw on is right there and is easy. Mine may interfere with the front mounts but I could change that. Mostly I'm doing it for looks.
    drdave, loudbang, Stogy and 2 others like this.
  13. Tim
    Tim
    from KCMO
    Yup. I was contemplating doing it then I found this 40’s dodge unit for like $2 or something and when I bolted it on the ****ty paint even matched! Figured it was a sign
    brEad, loudbang, Stogy and 3 others like this.
  14. Six Ball
    Six Ball
    from Nevada
    You are doing a great job here and I am paying a lot of attention to how you are making this Chevy 4 an A engine.
    Thor1, drdave, loudbang and 2 others like this.
  15. Tim
    Tim
    from KCMO
    Thanks man, a lot of this will get repainted but for now it’s helpful to keep it rust free, see where it needs some more work, and shoot it just looks cool back on the car!
    Thor1, Stogy, drdave and 2 others like this.
  16. Tim
    Tim
    from KCMO
    Got the body mount holes 99% drilled tonight. Need a tiny bit more tweaking and they’ll be there. D1048D6A-30CF-481C-BF85-6E41C6640E3E.jpeg also mocked up my spreader bar with the plate mount EE5188FA-8B9C-4F22-B03D-D519F73CA45F.jpeg dropping the light was worth it 97C22F15-D383-4AED-A3BE-D16A082790C3.jpeg 382665DC-FEBA-4275-ACDC-499FC9CF9F48.jpeg Doesn’t lay flat like I want it to get but it’s nothing a little fine tuning won’t take care of 8DCF34EE-E2F9-4177-8855-2F1051C0A090.jpeg a lot of effort just to have that little webbed gusset lol C9E9A3E3-C696-4D18-B703-99F165882863.jpeg oh well. Progress.
    gonna try to buy some bolts Wednesday. Thinking a trip to a tractor supply for some low grade bolts by the pound are in order. Not sure what size and length I’m really going to use so no since being bent over at ace for them.
    really need to find a spot to order good bolts at a bulk rate for when this goes together for the final time
  17. drdave
    drdave
    I bought all the stainless bolts for the Chevy motor by the box from McMaster Carr. I thought they were real reasonable. Obviously, they have regular bolts as well. Been thinking about stocking myself with various sizes of regular as well as some grade 8’s just to have on hand.
    Exciting to see so many things coming together here all at once. Looking good!!!
    Thor1, loudbang, Six Ball and 2 others like this.
  18. Six Ball
    Six Ball
    from Nevada
    Why not just weld tabs for the plate & light to the spreader bar?
    Stogy, Thor1 and loudbang like this.
  19. Tim
    Tim
    from KCMO
    @Six Ball just like the way the clamps look and they offer a lot of fine tuning should I want it to sit differently.
    But mostly I like the way they look
    Stogy, Thor1, drdave and 2 others like this.
  20. rjgideon
    rjgideon
    I bought a grade 8 lot from ebay that came in bags. I sorted them into Harbor Freight plastic bins and labeled them with a label maker. I hated running for bolts all the time and I figured that it wouldn't hurt to have them in stock.
    Stogy, Thor1, Six Ball and 2 others like this.
  21. There are sellers on Ebay that sell polished stainless bolt kits. For the price you could just buy a couple and use them as needed. I did one for my old 348
    Stogy, Thor1, loudbang and 1 other person like this.
  22. Tim
    Tim
    from KCMO
    Excellent:)
    Stogy and loudbang like this.
  23. patmanta
    patmanta
    from Woburn, MA
    I usually go to BoltDepot.com when I need nice hardware.
    loudbang, Tim, Stogy and 1 other person like this.
  24. Six Ball
    Six Ball
    from Nevada
    Not finding fault just think; what I'm going to do.
    I had a really nicely organized ***ortment of nuts, bolts & washers until the pack rats found them. It's hell carving an empire out of the wilderness. :D
    brEad, drdave, loudbang and 2 others like this.
  25. Tim
    Tim
    from KCMO
    Together apart together apart….. B753ECBF-4DF0-439E-9BF8-43BFD734FB09.jpeg car is bolted to the frame. Updates in the next couple weeks should see it outside :)
    drdave, patmanta, Six Ball and 5 others like this.
  26. Tim
    Tim
    from KCMO
    Thought:
    my air cleaner has the “lid” on the bottom side so the wing it faces the ground.
    thinking I need a way to keep it on with out making it a pain in the *** to take off.
    thinking drill the stud for a cotter pin. It won’t let the wing nut loosen enough to do more than rattle and very easy to pull and replace with no tools to replace the filter.
    thoughts? 6582CB64-0E63-498C-AEA9-EE12891BE32A.jpeg sneak peek at progress. It’s got latches!
    Stogy, loudbang, drdave and 2 others like this.
  27. Cotter key is a simple fix, do it
  28. Thor1
    Thor1
    You might want to use a small hair pin. It would be easier to put on and off...
    Stogy, loudbang, drdave and 3 others like this.
  29. Tim
    Tim
    from KCMO
    Hair pin! There it is.
  30. Six Ball
    Six Ball
    from Nevada
    Bailing wire. It's traditional where I came from.
    dumprat, Stogy, loudbang and 2 others like this.
