Projects 1939 Packard Custom
Discussion in 'Traditional Customs' started by CadMad, Apr 15, 2020.
  1. 57 Fargo
    57 Fargo
  2. CadMad
    CadMad
    Up one second… down the next.
  3. CadMad
    CadMad
  4. loudbang
    Smoooottth operation. :rolleyes:
    41 GMC K-18 likes this.
  5. 41 GMC K-18
    41 GMC K-18
    Cl***ic style with precision !
    mgtstumpy and loudbang like this.
  6. gatz
    gatz
    Very Nice !!
  7. 1-SHOT
    1-SHOT
    from Denton
  8. pwschuh
    pwschuh
    Dude, you're killin' it down under there.
  9. 40FORDPU
    40FORDPU
    Keeps getting better all of the time.
    Well done!
    41 GMC K-18 and loudbang like this.
  10. GordonC
    GordonC
    I'm loving all the small details your putting into this build. Nice work!
  11. brEad
    brEad
    Very slick!
  12. chopolds
    chopolds
    from howell, nj
    Long time admirer! Amazing work! Great eye for style as well!
  13. CadMad
    CadMad
    So after a bit of trial and error I got the whole sequence working as it should.
  14. CadMad
    CadMad
    Thanks to Rik Hoving for uploading the videos.
  15. j hansen
    j hansen
  16. X38
    X38
    Great perseverance, great result!
  17. 41 GMC K-18
    41 GMC K-18
    Truly amazing to watch the progress of this build!
    This is indeed a well choreographed, automotive mechanical ballet! It takes a lot of time and patience, to get the sequencing and timing just right!
  18. ne'erdowell
    ne'erdowell
    I follow a number of threads and this is the one I look to most. You have one incredible skill set and I appreciate that you do this in a shop that is not, um, tidy.
  19. blowby
    blowby
    from Nicasio Ca
  20. 57 Fargo
    57 Fargo
    Holy **** that’s cool.
    VANDENPLAS and TrailerTrashToo like this.
  21. loudbang
    Does it now all happen with the touch of one ****on or are you controlling the different events?
  22. CadMad
    CadMad
    I have to thank Marie Andersson in Sweden for sending me a wiring diagram of how she manualised the top pump solenoids separate from the computer module.
    I use three momentary switches ( one for each solenoid) and a forward reverse toggle.
    To raise the roof is 5 operations. To lower it is 3.
    Eg some need three ****ons pushed together, some 2 , pulling the rear bow right at the end is only one ****on.
    I’ll make a little stainless faceplate and punch the sequence like Braille.
    the sequence is a bit like playing piano or guitar chords.
    “Baby, it’s Jazz!”
    It’s probably makes sense to mount it on the p***enger side door. So you open door and stand beside it to operate it.
    Sandgroper, ClarkH, Hnstray and 10 others like this.
  23. CadMad
    CadMad
    So my next project is the two flaps that cover the void where the top mechanism resides. These are tricky. The original Saab flaps pushed forward into the rear armrest but as I’ve now got the b pillar there they won’t work.
    I originally had the flaps opening sideways but I’ve decided to change them to hinge them 6171E3E3-96D4-454D-9407-7D75A121932F.jpeg 078B803E-6D76-45EA-B750-9DC012685365.jpeg off the hard boot.
    My daughter has a Merc clk 230 convert and the flaps are on the hard boot operated by cables that pull the flaps open when the top is raised and release them when the top is lowered.
    I went to the hardware yesterday and found some nice SS spring loaded gate hinges.
    Can’t wait to have a play over the weekend.
  24. Squablow
    Squablow
    Overhead view of this car is spectacular. Pretty neat someone already figured out how to make that top operate without a computer ***ist, that's definitely a time-saver.
  25. X38
    X38
    The overhead shot confirms the right-on proportions!
    Outback, Hnstray, 41 GMC K-18 and 6 others like this.
  26. GordonC
    GordonC
    That is some cool **** right there! Great job on getting all that moving mechanical stuff in the proper sequence.
    Hnstray, 41 GMC K-18 and loudbang like this.
  27. CadMad
    CadMad
    Did a late night shift again and finally I have a fully operational hardboot.
    I decided to make the flaps manual like the 53 Eldo. Down the track I may still make it fully automatic operating off cables… however each flap will require two separate cables so for now I think I will defer to simple manual operation. Everything works as it should and nothing fouls. Very happy.
    https://youtube.com/shorts/eOLdcoe_v8Y?feature=share
  28. CadMad
    CadMad
  29. brEad
    brEad
    You have some incredible visionary skills!
  30. 41 GMC K-18
    41 GMC K-18
    " The pursuit of mechanical precision, is it's own reward "
    loudbang and TrailerTrashToo like this.
