Technical SBC Bellhousing ID
Discussion in 'The Hokey Ass Message Board' started by Artiki, Sep 22, 2021.
  1. Bob Lowry
    Bob Lowry
    Hard to tell without seeing the valve covers........
    alanp561 and Artiki like this.
  2. warhorseracing
    warhorseracing
    from cameron wv
    Post #23 confirms it.
    Bob Lowry likes this.
  3. gimpyshotrods
    gimpyshotrods
    Truck bell. There is an Iron one, with side mounts, takes a starter that bolts to the bell, and has the conventional Muncie/Saginaw pattern.
    As far as I remember, 168-tooth flywheel. 1962-67-ish.
    3815891, I think.
    Fordors and Artiki like this.
  4. Fordors
    Fordors
    96E02C39-51EA-490F-8954-F0A0D92CD4E3.jpeg CCF2309C-46B3-49D9-9D10-03E27117C5F7.jpeg 238958F9-3D6F-4DFD-ADC9-2A2EFE55598F.jpeg
    Here are photos of the ‘55-57 p***enger car bell, notice the proximity of the fork pivot to the register diameter in the second photo.
    0CBA71F6-DAF4-40CE-A75C-999AF9BA816E.jpeg 2579FD95-2330-40A3-B619-A7F119C772C0.jpeg These two photos are of a pickup truck bell as mentioned by @gimpyshotrods . He called out a casting number (or is that a part number?) but they will be found with a variety of casting numbers. The important thing to look for in a pickup bell like this is the space from the edge of the fork pivot to the register diameter, some pickup bells will look the same but have the larger register for the heavy duty truck four speed.
  5. Artiki
    Artiki
    from Brum...
    So it's literally the bell that came with this engine?
    Hahahahaha...
    I told you the beer coaster was small!
    Brilliant. Thanks men.
    Fordors and gimpyshotrods like this.
  6. gimpyshotrods
    gimpyshotrods
    There is that. Now you need a bigger coaster.
    alanp561, Fordors and Artiki like this.
