when I built my 55 I bought Posies rear springs. I am thinking that I will replace them to raise the rear of the car some. Trying to decide if I should have the originals redone at our local spring shop or buy new ones. I talked with the local guys who will put them back together with the original cloth inserts for $165. Also spoke with General Spring guy who said that theirs would come with the same, $260 a pair. I kind of ***umed that the cloth could be replaced with plastic sliders but they seem to indicate not. What has been your experience?
I used the plastic sliders on mine. If you're having your originals re-arched, just provide the plastic liners to the shop. Or, have the shop re-arch each spring then give them back to you. Put 'em back together yourself with a couple of C-clamps and install the plastic liners. Plastic rear spring liners
I took mine apart cleaned them painted them put them back together with the plastic sliders did both my 55 Victoria an my wagon same way
The ones i used are round fit on the very back of the spring there is a round place in the spring where they fit mine are called anti-squeak pads from Dennis Carpenter may not be what you call sliders
I took my originals apart and cleaned /painted them. I had the spring shop put them back together with plastic sliders and stainless steel bands holding it all together.
6 come in each set............. https://www.dennis-carpenter.com/trucks/suspension/shackle-kits/8a-5334-s-rear-spring-clamp-liner
May be just me, but I can't see how a 60 year old spring can be re-arched and expected to last very long. The '57 forum guys, like me, have pretty much used McVeigh's Truck Springs for the rear leaf springs. I believe their eBay name is Spring King.
I agree Rich. I tried to buy a pair from KC Spring but they said on back order. I thought they were made in house but they said not 55/56. So had our local spring shop redo mine. In the past they have been excellent but not so now. When I called them they said $165, I asked if that was reached, painted with new clamps and sliders, they said yes. When I picked them up they were almost $300, $165 was labor only. Lesson learned late. Plus they are about 1/8” different in height. New only now.
