Technical A V8 what combination of ....
Discussion in 'The Hokey Ass Message Board' started by ABONES, Sep 27, 2021.
  1. What combination of water pumps ,pulleys , generator and fan give you the shortest length 8BA . Trying to not modify firewall or move radiator ahead .
  2. Building a 31 pickup using an F1 crossmember.
  3. rusty valley
    rusty valley
    the shortest way is to get rid of that "girlie" distributor and put the crab and shorter water pumps all associated with a 59 series block.
  4. Model A Gomez
    Model A Gomez
    I used 52 F1 water pumps, 12 volt generator with a 37 pulley and fan, had the front pulley machined off the crank pulley. Still running the stock distributor and a single fan belt. Has early heads but is an 8RT out of a 52 F3. Had to put a small notch in the firewall to clear the fuel pump C motor 012.JPG !cid__Photo03061434.jpg fh1.jpg plugs.jpg
    ABONES and stillrunners like this.
  5. rusty valley
    rusty valley
    Somewhere here is a thread by the late, great Bruce Lancaster, I believe it may be called "flathead dimensions" or something similar, he states you gain an inch ana half by switching to the old style front set up. To use that dizzy all the pulleys and belts are further forward so the belts clear the dizzy.
    Tman and ABONES like this.
