Technical New fuel sender original 32 Tank?
Discussion in 'The Hokey Ass Message Board' started by Duke, Sep 28, 2021.
  1. Duke
    Duke
    Has anyone added a fuel sender for a Stewart Warner gauge to an original 1932 ford tank? Is there a sender that is close to the right size? I don’t want to cut this nice original tank. Thanks
  2. $um Fun
    $um Fun
    from Nor Cal
    I thought Stewart Warner made a fuel sender for a 32 back in the day. I see them every once in a while at swap meets.
  3. Deuce Lover
    Deuce Lover
    The issue with the 32-34 tanks is the fuel pickup. I've not seen a modern sender that fits these tanks that has both.
    micksmith likes this.
  4. Duke
    Duke
    I was thinking of adding a pickup to the modern sender
  5. 325w
    325w
    Thought all that was needed was the correct hole pattern and correct Ohms . Set the float arm.
  6. krylon32
    krylon32
    from Nebraska
    Just buy a new tank. Sell the original or store it away for your auction.
    Tman likes this.
  7. alchemy
    alchemy
    I redrilled the new SW sender pattern in the top of the original sender 32 hole. But, I had to weld two bungs in the top of the tank also, one for the pickup and one for the vent.
  8. hotrodA
    hotrodA
    Cl***ic Instruments p/n SN33.
    Combo pickup and sending unit, 240/33 ohm, 5 hole. Adjustable sending unit and arm. Shorten the tube.
    I redrilled and tapped my stock tank.
  9. Duke
    Duke
    Did you add a vent to the sender? Thank you
  10. hotrodA
    hotrodA
    Nope. Just a vented cap. No problems, but it’s a stock 59AB flathead and fuel pump.
  11. Duke
    Duke
    Thank you, do you know what fitting the fuel line takes? Seems to be some confusion in the reviews.
    Thanks
  12. 19Eddy30
    19Eddy30
    from VA
    I do not recall ever seeing a aftermarket for original gas tank.
    That what I would do & have done ,
    Made my own , bolt in Original tank using Original pick up pattern.
    No big deal , time ,thinking it out ,
    Silver Solider, braze , weld .
    Original tanks are nicer "fit "the only advantage you have over aftermarket would be an extra few gallons, & t******* required.
  13. hotrodA
    hotrodA
    Old age memory lapse, but I used a regular inverted flare male/female 90* elbow and inverted flare nut with steel brake line. Made it so I could slide the tank to the rear far enough to clear the body and access the sender. Pic is from the build thread a couple of years ago.
  14. Duke
    Duke
    Thank you! I have the sender on order.
  15. nochop
    nochop
    from norcal
    I found a generic standard replacement sender probably from napa. The only problem is it reads full to half, half being empty. I’m guessing I didn’t adjust the float right.
  16. Duke
    Duke
    Should I add a vent into the sender? Does the vented cap leak? I am running a 283 Chevy.
    Thanks
  17. John McLeod
    John McLeod
    from Boyne City
    Welding a Bung in with the proper 5 bolt hole pattern is best and there are numerous sending unit options for sneing units...Float style and tube style...Call our tech line at 231-582-0461 and we can ***ist if you need further help, but I see you had lots of help and I am late to the party.
    John
  18. Duke
    Duke
    I picked up SN33, will be going in soon. Thank you
