Projects 1952 Pontiac Catalina Hardtop Build
Discussion in 'Traditional Hot Rods' started by 1959Nomad, Sep 8, 2021.
  1. Bruce A Lyke
    Bruce A Lyke
    So, I am no longer the guy with the 1959 Nomad, it was sold last month.
    I am now the guy with the 1951 Pontiac hardtop, still trying to determine exactly what it is offically called. It is starting form a much better place that the Nomad did, but will need work to complete to a solid driver.
    Okie Pete, Ford52PU, brEad and 23 others like this.
  2. Malibu406
    Malibu406
    Very nice and upscale looking. You will need to wear your Sunday’s best driving her.
    -Brent-, Bruce A Lyke and Chief 64 like this.
  3. fyrffytr1
    fyrffytr1
    That's a whole lot better than what I got!
    1959Nomad likes this.
  4. Bruce A Lyke
    Bruce A Lyke
    harpo1313 and fyrffytr1 like this.
  5. stillrunners
    stillrunners
    from dallas
    kidcampbell71 and 1959Nomad like this.
  6. Bruce A Lyke
    Bruce A Lyke
    Yep
    kidcampbell71 and loudbang like this.
  7. wvenfield
    wvenfield
    Looks ready to go to me.
    loudbang and 1959Nomad like this.
  8. Bruce A Lyke
    Bruce A Lyke
    Spent the day going over the car and the bins of loose parts.
    Will need need rear shoes and drums, some more wiring and a lot of clean up. but it will be fun to get it done.
    Spooky, wvenfield and loudbang like this.
  9. stillrunners
    stillrunners
    from dallas
    Yep - the "Patina Cl***ics" guy has been posting it on his for sale Instagram account.
  10. jimmy six
    jimmy six
    Well looking them up I found Chieftain Super Deluxe,
    and Chieftain Deluxe. Catalina was the sport coupe model like you have; as far as I can tell both engines were available in all models. Leather or vinyl was available also
    If it’s a Chieftain Super Deluxe Catalina Coupe with an 8 there were 1382 built in 1951.
    On the vin.. 2537D is a Catalina DLX and 2537SD is a Catalina Super DLX……….A 6 or an 8 designated the engine. I’m sure there is a sequence also.
    You can’t go wrong with “ Tin Indian” :rolleyes:
  11. Bruce A Lyke
    Bruce A Lyke
    Thanks Jimmy Six
    The tag is partially covered by the battery holder (12 volt conversion) but the glove box say's its a 8
    Will see for sure in a few days, its lower on the list for now
  12. Bruce A Lyke
    Bruce A Lyke
    Okay, had to know... it is a 2537SD
    Where did you find the 1382 production number? Interested in that and any other sites with info like this.
    Thanks again!
  13. jimmy six
    jimmy six
    I was playing on the net looking under 1951 Pontiac vin number. It was accidental and I don’t remember which one. It was quoted on one that was for sale.
    The vin starts with a letter then a single number, either a 6 or an 8 the ending is what at you’ve shown from what I read. I guess there is something in between.
    Is the engine out?
    1959Nomad and loudbang like this.
  14. Ben38
    Ben38
    from Minnesota
    Pretty cool Bruce!
  15. Bruce A Lyke
    Bruce A Lyke
    The original Flathead straight 8 is long gone, the SBC is in and it can be driven.
    Rear brakes need to be replaced before it is driven much.
  16. Bruce A Lyke
    Bruce A Lyke
    Trying to get the speedometer working and looks like some modifications will ne needed, as the TH400 is not set up for a cable. A
    ***uming the part on the shaft that was used to send the electrical signal need to be removed, right?
  17. Bruce A Lyke
    Bruce A Lyke
    Lots of parts on order brake drums and shoes arrived yesterday
    Will post a few update pictures later
    Think I have the transmission figured out and the parts are on the way
  18. Bruce A Lyke
    Bruce A Lyke
    It is looking like the engine and ****** are from 1974 (still need to verify on the TH400) and looks like it was a "350 T400 police" Version
    Still trying to spot the casting date on the 3970010 block, but a K1223CMJ 350 is 1974
    The rear brakes are done, so its on to the carb and vacuum lines, seems to be running rich and slow to warm up.
    Got a gas pedal from a 1976 Monte Carlo at U-Pul-it that I can mount the kick down switch for the TH400
  19. Bruce A Lyke
    Bruce A Lyke
    Wondering if anyone can help with the ID, cant find anything for a LRA tag on line TH400 1.jpg
  20. Bruce A Lyke
    Bruce A Lyke
    Turns out it is a TH400 as suspected, but a later version that was called a " 3L80" as part of a effort by GM to standardize the nomenclature. 3 (speed) L (Longitudinal, rear wheel drive) 80 (8000 LB), so likely was from a truck and perhaps was a replacement from the originally in the1974 350/TH400 "t400 Police" package.
    Spooky likes this.
  21. Bruce A Lyke
    Bruce A Lyke
    Lots of progress today. Went to replace the plugs, cap and rotor, which all needed it... only to discover that the distributor clam was tight, but was not on the ring[​IMG]
    It was easy to turn and suspect it had been slowly moving. running much better and sounds like a 350 should.
    Still need to switch the plugs, but just had to give it a try, it needed almost a 1/4 turn, and from struggling to idle to a fairly hi RPM.
  22. Nice score! I regret selling my '50 Catalina, good running straight 8 with hydramatic. Last I heard it was in Franklin, Tn. 457386-1364850463-a577193359b33d239cf1de5d7c5bc957.jpg 457387-1364850463-26c99289fc332887b417d744dccce09f.jpg EbayPictures004.jpg EbayPictures008.jpg EbayPictures005.jpg
  23. Bruce A Lyke
    Bruce A Lyke
    1stGrumpy, very nice car, appreciate the pictures, especially of what was under the hood, so I can see what was once there:rolleyes:
    1stGrumpy, loudbang and 41 GMC K-18 like this.
  24. Bruce A Lyke
    Bruce A Lyke
    Slightly different look under the hood:rolleyes:
    -Brent-, sololobo, Ford52PU and 6 others like this.
  25. J. A. Miller
    J. A. Miller
    from Central NY
    Just lower it a little and shoot some flake on the roof and you'd be stylin'.:D
    Spooky and Bruce A Lyke like this.
  26. Bruce A Lyke
    Bruce A Lyke
    Making progress on the Catalina, drove it to a small car show last night.:cool: 51 PCSDC.jpg
    tommyd, R A Wrench, sololobo and 13 others like this.
  27. Bruce A Lyke
    Bruce A Lyke
    Found the article and it looks like that was for the Canadian build Hardtops
    loudbang and guthriesmith like this.
  28. guthriesmith
    guthriesmith
    Really like your new Poncho Bruce!
    Bruce A Lyke and loudbang like this.
  29. Atwater Mike
    Atwater Mike
    Wow... 'Just in Time'!
  30. Bruce A Lyke
    Bruce A Lyke
    Made some trim pieces to fill the gaps from the switch to a one piece windshield
    tommyd, brEad, deathrowdave and 3 others like this.
