Hot Rods Model A coupe drivetrain facelift
Discussion in 'The Hokey Ass Message Board' started by mdimages, Oct 2, 2021.
  1. mdimages
    mdimages
    Hey everyone my names Matt,
    I built this 1930 ford coupe about two years ago now. Its a mild banger motor with other then that, a stock drivetrain. I went thru the whole car, boxed the frame, did a 40s juice brake conversion, 35 wheels, 34 front end, etc. the usual. probably since I built it, I put about 2k on the invisible speedo.
    Really my only complaint with this car is the gearing of the trans, which leads me to this mod.... It fun in its own way, but I feel a swap will make it all around a nicer driving car. So after spending many nights looking over this forum I pulled the trigger on a T-5. Got lucky and found an old timer that was goin to do a close driveshaft conversion but sold his car. Ironically he had printed the same threads and info I ac***ulated from the internet over the past couple weeks. He made an adapter off an AA belhousing and tuned down a flywheel to work with a s-10 clutch and pressure plate. I feel simliar to the V-8 clutch mod. I feel I'm goin to run with this setup and work my way back. I already got in contact with a couple members here on some info and parts to make it happen.
    If anyone else has done the close drive t-5 conversion that wants to chime in, feel free! Im all ears to tips and tricks. I have viewed/saved many of the threads on the site with ppl doin similar mods. I guess this is just a way to keep that info goin for the future guys in line, while also brainstorming with you fellas.
    Thanks!
    Matt
    210superair, catdad49 and Budget36 like this.
  2. mdimages
    mdimages
    pics
  3. mdimages
    mdimages
    13-52-191 is the trans data tag code
    its a GM 1989 T-truck 2.5L L4
    gear ratios: 3.76/4.03/2.37/1.49/1.00/.72
    catdad49 likes this.
  4. oldiron 440
    oldiron 440
    Cool ride!
    mdimages likes this.
  5. mdimages
    mdimages
    Thanks dude! It’s a glorified go kart!
  6. catdad49
    catdad49
    Great A, let us know how it goes with the new trans!
  7. mdimages
    mdimages
    Sounds good I will keep you posted
  8. JWL115C
    JWL115C
    Typo - 4.03 for 2nd? Maybe 3.03?
  9. mdimages
    mdimages
    the book says 4.03 I thought the same thing. Seems the same as many other models
