Projects HotRod Rebuild
Discussion in 'Traditional Hot Rods' started by ModelARon, Mar 18, 2021.
  1. ModelARon
    ModelARon
    I put up temporary walls to hang plastic. Used a 24" fan to exhaust the fumes out the back of the garage. I cracked the bottom of the garage door to let air in and covered the crack with a cheep filter.
    I need to keep the dust and bugs off the paint. Also keep my garage clean. IMG_1940 (1).jpg
  2. ModelARon
    ModelARon
    The base coat went down real good . I find the clear coat takes more skill and practice.
    After buffing the clear coat on the trunk i burned through one edge. I had more orange peel than i wanted. I picked up a new Devilbiss GTI pro lite gun, to get a flatter finish on the clear.
    I waited too long to buff out the clear coat. If the clear dries too long it is real hard to wet sand and buff out. I am planning to wet sand and shoot more clear coats. I fixed the burn through and shot the new clear. Here is the trunk after i buffed it out. IMG_2134.jpeg
  3. ModelARon
    ModelARon
  4. ModelARon
    ModelARon
    The car came with four Cragar GT wheel caps . I have never seem these before.
    After some research Cragar made a GT wheel in the 1960's. I guess it was not a big seller.
    I like the fact that you don't see these caps. I cleaned them up and installed them on a new set of rims.
    The old rims were shot. IMG_3068.jpeg 63832102265__0281E2A4-B7EE-47F8-B897-34CBDD0017D3.jpeg
  5. AHotRod
    AHotRod
    Cool
    Stogy and loudbang like this.
  6. loudbang
    You are making great progress rapidly. :)
    Stogy, brady1929 and dana barlow like this.
  7. oldiron 440
    oldiron 440
    I don't know how I could like this rod more, your doing a great job of refreshing!
  8. ModelARon
    ModelARon
    Made a bracket to mount the parking brake handle on the trans. IMG_3232.jpeg IMG_3130.jpeg IMG_3134.jpeg
  9. ModelARon
    ModelARon
    I needed to make more leg room so i moved the roll bar and seat back a few inches. IMG_0982.jpeg
  10. ModelARon
    ModelARon
    I am waiting for some warmer weather so i can finish spraying the clear coat.
  11. ModelARon
    ModelARon
  12. oldiron 440
    oldiron 440
    I'm digging the tire selection!
    outagas1961 and loudbang like this.
  13. ModelARon
    ModelARon
    Thanks. This is my first build and there are too many choices. I am learning tons about these cars and having a great time with this car.
    oliver westlund, AHotRod and loudbang like this.
  14. ModelARon
    ModelARon
    I am having a hard time deciding on the front bumper or chrome spreader.
  15. loudbang
    Looks VERY GOOD and an added bonus FORD power. :)
    34 5W Paul, Stogy, brady1929 and 2 others like this.
  16. ModelARon
    ModelARon
    That seems to be the common theme. People like that it's not the common Chevy small block.
    chryslerfan55, Stogy and loudbang like this.
  17. 38ford
    38ford
    Love the car, you are actually very talented, nice work .
  18. SS327
    SS327
    Nice chromed up stock bumpers. I know a lot of people won’t like them, but with stock fenders I think they look great!
  19. dumprat
    dumprat
    from b.c.
    Unless you can come up with some real neat nerf bars with your initials in them.
    oliver westlund, guitarguy and Tim like this.
  20. ModelARon
    ModelARon
    Thanks for the nice comments. When i first started this build i thought i could have this finished in about one year. Three years latter I have made lots of progress but there is still lots to finish.
    I took a break for a while and worked on another car .
    I think the break helps me refocus on the build.
  21. ModelARon
    ModelARon
    The air cleaner did not fit , it was hitting the fire wall so i had to cut a piece off the back .
  22. ModelARon
    ModelARon
    I welded a plate and a nut for the shoulder belt, it will be hidden behind the cloth interior.
    I saved all the interior fabric pieces to use as templets when i install the new interior.
  23. I was going to write my own reply to this thread... but 57 Fargo summed it up perfectly so I'll leave it at that :) Holy **** Indeed !!
    Stogy, 57 Fargo and loudbang like this.
  24. alanp561
    alanp561
    Not the John Deere dealer who sells all those cute little riding mowers. You need to find a John Deere Implement Dealer who sells manly farm equipment. ;) Their corn head grease won't be cheap but it's the best thing around for what you're gonna use it for.
  25. ModelARon
    ModelARon
    I removed the old juice brakes and installed the Lincoln style for better stopping power IMG_3431.jpeg
  26. ModelARon
    ModelARon
    The weather is now warmer so i can finish applying the clear coats. I am using a process called flow coating. It is a way to get a flatter finish . Flow coating is basically applying coats of clear and letting it dry a few weeks . Then wet sand and apply more coats. I upgraded to a better Matrix clear finish.
    IMG_3574.jpeg IMG_3575.jpeg IMG_3577.jpeg IMG_4832.jpeg IMG_3585.jpeg Last fall i applied two coats of clear but i could not finish because of the cold weather.
    I removed the body so i can wet sand the clear coats. I will apply two more coats and then i can start the final ***embly of the car. I finished the doors and grill.
  27. ModelARon
    ModelARon
  28. set me on fire
    set me on fire
    thats a bad *** hotrod!
    and knowing the history and owner = 100% awsome !
  29. oldiron 440
    oldiron 440
    I've been flow coating clear since about 1980, I did it with lacquer first. It makes for a very nice finish.
    oliver westlund, Stogy and loudbang like this.
  30. ModelARon
    ModelARon
    I finished painting the body. Set the body back on the ch***is. I am reusing/rebuilding the components the original builder used when he built this car. Hope they all work together well.
    Master cylinder from a truck , front brakes from an early ford, rear brakes from a 1960 ford galaxy.
    I finished the brake lines and the line to the clutch slave cylinder.
    Brake feels good but the clutch feels IMG_4395.jpeg IMG_4419.jpeg IMG_4417.jpeg stiff.
