Technical ***October 2021 Banger Meet Thread - Happy Halloween***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 1, 2021.
  1. 51 mercules
    51 mercules
    Thanks. I'm going to keep the timing cover. If I ever get rid of it I'll let you know!
  2. RussTee
    RussTee
    I will be about Phone 3327293 39 cashmere view st
    97 likes this.
  3. Binger
    Binger
    from wyoming
    Checking in from Cheyoming! Nothing really going on here.
    Jet96 likes this.
  4. Jet96
    Jet96
    from WY
    Checking in -I'm sorry to hear about Rich Fox, I got some good info and parts from him...
  5. V4F
    V4F
    from middle ca.
    your to kind john ...................... thanks
  6. V4F
    V4F
    from middle ca.
    front are 205 x 16 ........ rears are 31" tall (gear ratio help)
    my car is basically ridge , no rub anywhere
  7. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Out with the blown out Babbitt A motor, And In with the Balanced, Inserted B....
    Texas36, Lil'Alb, Stogy and 7 others like this.
  8. wheeltramp brian
    wheeltramp brian
    Checking in, nothing new to report except when I pulled the tarp off the car the seat was covered in cat hair. The local cats have been using it as a hang out I guess. Guess I need to drive it more
    Stogy likes this.
  9. hardtimesainit
    hardtimesainit
    stubbsrodandcustom likes this.
  10. hardtimesainit
    hardtimesainit
    What you need, is the coyote that has taken up residence in our rear yard ! He/she has cleared the immediate area of pussies that like to occupy car seats !!
    Had a bead on it three times, then thot…. Hey haven't stepped in cat ****, while mowing. Well truth is that Mrs is mowing till after my body work this Friday. Boy howdy does she light up when stepping in cat poo !!!
    So, Im planning menu to keep my new dawg happy to stay put for awhile….lol
    Jet96 and Old Dawg like this.
  11. burl
    burl
    from Minnesota
    Checking in for the month gettin a few things done on beater #2. Had to make a id od adapter bushing to mount this wheel to the model a steering,got the windshield frame pieced together from a couple different ones and cut down,got the bus seat cut down to fit and stuck an aluminum radiator in the shroud so I can cool this thing. Progress one bite at a time B8F8948D-5FF8-4D55-8600-83848207FF97.jpeg 8B8C98AD-591F-481F-9D21-CD1A66EF5828.jpeg 84687139-B01A-4E53-BEBF-7E0738EBF784.jpeg 0D1A1031-9695-4BDC-A042-DA6E74A8DA50.jpeg
    Lil'Alb, Stogy, brjnelson and 9 others like this.
  12. Joebrownvw
    Joebrownvw
    First banger post here for me.
    Almost ready to fire up after a rebuild
  13. 51 mercules
    51 mercules
    One day my Riley 4 port will on this instead of the Lion Speed Head! [​IMG]
  14. Kevin Pharis
    Kevin Pharis
    from Califunny
    I’m right there with you! Stay the course and keep at it. Good things come to those who wait...!
    Carter, Stovebolt, winduptoy and 4 others like this.
  15. 51 mercules
    51 mercules
    Nice!
  16. winduptoy
    winduptoy
    So I am on the hunt for a replacement rod bearing(s) in a engine I have. It needs freshening up.
    The rods have a shell bearing that was made by Vandervell and has a stamped number 403936
    The crank journal mics at 1.83590" and the shell is .080" thick and 1.065 wide. No oil groove.
    Any ideas? Any help is appreciated
    Dannerr likes this.
  17. Hmm.
    check the bore diameter in the rod, if 2.000 more than likely a Volvo B14 bearing.
    if 2.021 dia, more than likely a TR4 bearing. I suspect it is the TR4 as your crank dim is not standard undersize and fits the bearing better.
    J
    Old Dawg, Dannerr, burl and 1 other person like this.
  18. winduptoy
    winduptoy
    Wow, that was fast.. thank you,
    It is 2.000
    Dannerr likes this.
  19. Yeah, good luck with this
    Vandervell #675 or 535 '47-'64 Bx4 motor
    Clevite CB539P
    it should be noted, crank journal should be 1.8735-1.8740 standard, less .040 1.8335-1.8340
    Let us know how you make out, J
    Old Dawg and Dannerr like this.
  20. Can anyone help decipher this for me.
    Got a decent hot flathead, would this be suitable?
    709C0147-7946-428E-A898-3EF1C4D0FE28.jpeg D92FA342-CAED-401F-A95B-80B200E36B16.jpeg A1024A7E-00FB-4897-9D8C-CED0F74185C2.jpeg 2C817C78-D60C-4AF2-B3E7-A7FD57C5AB5D.jpeg 31BD38B4-0E83-403D-B639-DE4D3A2B7176.jpeg 899772DB-D03A-44D3-B96A-05D3FBC89929.jpeg BAFC8770-74C8-4C80-A9CF-CE6B16AEDDAB.jpeg
    guitarguy, 97 and Dannerr like this.
  21. Saw your IG mess., will reply there later.
    But based on the gray paint, it could be one off an old Danish Civil Defence eingine, usually used for pumps at a certain rpm - therefore the cut-out with centrifugal weight below the rotor, which has to be removed, or you will not exeed the set (to low) rpm.
    Looks to be in good condition, but... test it! Put it in a vice or (preferably) a spare head with spark plugs added, heat it with a heat gun and drive it with a hand drill - the heat lowers the magnets effect, similar to when running it on the engine.
    Set up right, starting is easy:
    guitarguy, Jet96 and Old Dawg like this.
  22. railcarmover
    railcarmover
    Note to self: don't be lazy and crimp the overflow tube behind the radiator side bracket when the solder breaks and say 'good enough'...its not.. and when the tube vibrates and cracks the solder joint at the bottom of the top tank you'll be doing more work than you ever want to.. then again its a model a, you always have to do more work on it than you want to..
    Dannerr, Jet96 and Old Dawg like this.
  23. I plan to! Unfortunately the mag is on the east coast as we speak. I was thinking of chucking it into a vice, using a distributor lower shaft in a drill, and see how much spark it makes.
    The tag shows 400-0* 1340 - 8* which most likely means it has 16* of advance at 1340rpm, is that enough?
  24. winduptoy
    winduptoy
    Banger on the road to the Roc
    It's getting a workout...
  25. That's how I did it - video must be on FB, can't find it on my yo'tube channel.
    I wouldn't know - I just put it in the car in the suburb parking lot in '09, and never really looked back. The mag and the Weber is about the only constant in that engine compartment, since I installed them.
    guitarguy likes this.
  26. Airborne34
    Airborne34
    from Texas
    Folks, Who are you “Go To” vendors for the basic Model B parts. Things like rear main drain tube, oil fill/breather tube, gaskets, etc.
  27. denis4x4
    denis4x4
    from Colorado
    Bert's Model A Store south of Denver. 1-800-321-1931 Closed Mondays
  28. Savage Coupe
    Savage Coupe
    from Washington
    Back in the North West from RPM nationals. Had to take the girl for a beach cruise. 85512E24-7C1F-47CA-8CCF-B4274D8BB2B4.jpeg 5FF9CB4A-CBD8-442C-9531-11E4061ADE81.jpeg 2B88CE47-39DD-4878-9E9D-06AC42213E73.jpeg 161B721A-5CF6-46A3-AEF3-11D4D7333A80.jpeg
  29. railcarmover
    railcarmover
    Under the red neon of a dive bar on old hwy 40..."That aint no prom date son, that's a ****tail waitress with a Dolly Parton wig"
    Dannerr, Jet96, Dustyp489 and 4 others like this.
  30. 97
    97
    ain't she cool, that's the kind I dig,........yes a bit Wild, but Not trashy at all. :cool: . and I am talking about your hotrod!
    Jet96, Dustyp489 and Old Dawg like this.
