Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. Roger Loupias
    Roger Loupias
    Really nice work with attention to detail. Going full or fenderles?
    Elvis100 likes this.
  2. Elvis100
    Elvis100
    Thanks.
    picked up a decent set of fenders a few months ago and traded a set of top irons for some new running boards. Going to be full fenderd. Got a couple other projects going on, but hope to be fitting them by the end of the year
  3. Elvis100
    Elvis100
    On my way back from Hershey…got some great parts for the car and future projects. The thumbscrews are for the roadster and the castings will be patterns for reproduction to go with the cabriolet top irons I’m making.
    I’ll post pictures of the whole haul
    heavydumper, Stogy, el Roach and 5 others like this.
  4. nunattax
    nunattax
    way to go buddy
    Stogy, Elvis100 and loudbang like this.
  5. Elvis100
    Elvis100
    I have been real busy these last few months with a few other projects. I’ll be back working on this car now. I have been eyeing a some ideal aircraft levers on eBay to use as door safety latches for some time now. I’ve seen a couple people use them, and they look great. The main problem is they want $275 each .
    I found these levers for a fraction of that and made a fixture to mount them. I drilled out the pivot hole for a shoulderd bolt and mounted it to a threaded bung that I welded to heavy gauge sheet metal. The lever is spring loaded with three positions indexed and sliding in another part that came with the levers. I drilled holes in the levers for clevises that allow a rod to swivel in a pillow block.
  6. RodStRace
    RodStRace
  7. loudbang
    They will look good. :)
    brady1929 and rusty valley like this.
  8. cadillacmike48
    cadillacmike48
    Nice work
    Stogy and loudbang like this.
  9. Roger Loupias
    Roger Loupias
    Impressive work, and how something latent like this involve so many hour's of craftsmanship. I respect your skill.
  10. Elvis100
    Elvis100
    RodStRace likes this.
  11. Elvis100
    Elvis100
    Thanks
  12. Elvis100
    Elvis100
    Thanks
  13. Elvis100
    Elvis100
    Thanks, it’s already a few years
    loudbang and Stogy like this.
  14. Elvis100
    Elvis100
    Made a few patch panels to replace rusty metal on the decklid inner. Going to end up being fore patches to get it all
    Squablow, loudbang, nunattax and 4 others like this.
  15. rusty valley
    rusty valley
    By golly you sure are good at making the dies to stamp out the correct shape part. I'd like to see the trunk die for fun. For the audience, I bought some parts from Elvis, the lower cowl feet, they are beautiful.
    Squablow, Elvis100, loudbang and 3 others like this.
  16. Elvis100
    Elvis100
    I’m not sure where the dies went for the decklid, probably back in the s**** bin. Here are some others I have made. I’ll cut a positive and negative leaving some room for the metal bend
  17. Elvis100
    Elvis100
    Got the patches welded in. I have a nice new skin from SAR
    Stogy, brEad, RodStRace and 4 others like this.
  18. Elvis100
    Elvis100
    Mounted the door safety latch
    Kreepea_1, Stogy, brEad and 4 others like this.
  19. ziffer
    ziffer
    from michigan
    This is an amazing thread. Lots to learn here. Did you make the front door edges with the multiple steps that fit into the jamb or can they be purchased from someone? Thanks
  20. Elvis100
    Elvis100
    I had a set fabricated. I believe TomBay is making them now, I know he is doing the door tops. I made the bottom 6 or 8 inches from multiple pieces on several doors. On the next set of doors I’ll make them out of one piece.
    Stogy, loudbang and cactus1 like this.
  21. uncle buck
    uncle buck
    Yes, Tom Bay is making these now
  22. Elvis100
    Elvis100
    Got sidetracked working on the cowl for the body I have for sale….
  23. rusty valley
    rusty valley
    Holy smokes!! there's a lot going on in that part, nice job!
  24. Elvis100
    Elvis100
    Long wait, but worth it.
  25. Elvis100
    Elvis100
    Built a cart for the rear end. This will help with rebuilding it… next big project I’ll be working on after the new year
    Stogy, brEad, loudbang and 2 others like this.
  26. Elvis100
    Elvis100
    With the Halibrand rearend now going in the 33 I had to rebuild this stock 34 rearend for this project. Got it all dis***embled and inspected. Happy that the gears were good and with a nice surprise that they are 3:54 ratio. I have all new bearings and will have to replace one axle. The threads are ******ed up.
    I made a jackscrew to push the pinion gear and bearings out.
    brEad, loudbang, Squablow and 4 others like this.
  27. Elvis100
    Elvis100
    Refurbished the rear spring and started rebuilding the brakes before Christmas
    brEad, bct, loudbang and 4 others like this.
  28. Elvis100
    Elvis100
    All day cleaning disgusting sludge out of the rear end. I also got the backing plates put back together
  29. heavydumper
    heavydumper
    That early style thumbscrew is rare and hard to find. I think they were used in '32 and '33, possibly as late as '34. The more common are the bell shaped. Good find!
  30. Elvis100
    Elvis100
    I’m planning on casting a few in bronze and having them chromed. Just need to find the time. I did end up getting a few sets of the cabriolet header mounts that came with the thumb screws machined from stainless steel
    HairyCanary, cactus1, brEad and 5 others like this.
